Home » Language IDEs » ServerTools (WTP) » JSF Support in JSP Editor
JSF Support in JSP Editor [message #71119] Wed, 02 February 2005 19:16 Go to next message
Originally posted by: robwms63.yahoo.com
I didn't see this on the roadmap anywhere. Even if it just recognized EL
expressions, that would be huge. If someone could point me to that
part of the code, I'd be happy to look at doing that. Would think that
you would just have to parse the expression, get the name of the class
from the faces-config, then wire it into completion code that already
exists. Actually, that isn't going to work because in JSF EL, you do
bean.attr and JSF adds the get in front. Anyway, probably doable
nonetheless.
Re: JSF Support in JSP Editor [message #71217 is a reply to message #71119] Thu, 03 February 2005 01:30 Go to previous messageGo to next message
Since EL is part of JSP 2.0, it is in our plan, albeit at a Low
priority. Providing highlighting and content assist for EL is
likely not something we'll get to in M3. Keep an eye on
http://www.eclipse.org/webtools/development/milestone_plans/ reports/report-milestone-overview.html.
- Nitin
Re: JSF Support in JSP Editor [message #71408 is a reply to message #71119] Thu, 03 February 2005 14:09 Go to previous messageGo to next message
Rob,
We're still working on opening up our highlighting and content
assist so that it's easy for others to tap into them, but we could
use whatever sample files you can provide. EL's pretty new apart
from JSF and we don't have many tests cases for it, so far.
- Nitin
Re: JSF Support in JSP Editor [message #71577 is a reply to message #71408] Fri, 04 February 2005 09:15 Go to previous messageGo to next message
You just want some JSP files that have JSF EL expressions in them? Where
should I send them?
Nitin Dahyabhai wrote:
> Rob,
> We're still working on opening up our highlighting and content assist so
> that it's easy for others to tap into them, but we could use whatever
> sample files you can provide. EL's pretty new apart from JSF and we
Re: JSF Support in JSP Editor [message #71691 is a reply to message #71577] Fri, 04 February 2005 11:19 Go to previous message
> should I send them?
You can send them to me for now. We're still working on defining a
clean way for adding in custom highlighting and content assist.
- Nitin
Previous Topic:Web application
Next Topic:Newb with a possible bug..
Current Time: Fri Jul 25 23:27:15 EDT 2025
Powered by FUDForum. Page generated in 0.03425 seconds
