Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Dynamic mapping using XSDEcoreBuilder
[Teneo] Dynamic mapping using XSDEcoreBuilder [message #71113] |
Thu, 08 February 2007 22:37  |
I've been trying to use XSDEcoreBuilder to generate the EPackages rather than use the generated Java implementation classes. I've run into a bunch of problems doing this and wondered if anyone else has done this successfully and has a recipe for success.
My learning experience has been that I need to make sure that the same package is not presented twice to Teneo's HbDataStore.setEPackages() method. When doing so, I ran into several null pointer exceptions. I have 3 XSDs that are imported by 3 other XSDs. When I use XSDEcoreBuilder.generate(), it returns each of the imported XSDs in addition with each call to generate on the XSDs that import them.
I'm still having a set of issues that may or be related to each other. The first is that after the mapping is complete, I tend to see 4 instances of the same table, but with "1"'s appended for each of the duplicates. This occurs for every type in the imported namespaces. For example:
ziptypes_device, ziptypes_device1, ziptypes_device11, and ziptypes_device111
I'm presuming that the problem is has to do with how the ecore packages are getting created making each of the dependent packages look like unique packages even though the namespaces and all of the underlying objects are the same.
When an instance of one of these schemas is loaded and then persisted using Teneo/hibernate, I get the following NPE. I'm presuming that it is caused by this same issue with the packages but I am unsure.
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.emf.ecore.impl.EClassImpl.getFeatureID(EClassImp l.java:857)
at org.eclipse.emf.ecore.impl.DynamicEObjectImpl.eDerivedStruct uralFeatureID(DynamicEObjectImpl.java:215)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:592)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:587)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:582)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenGet(BasicEO bjectImpl.java:640)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:599)
at org.eclipse.emf.teneo.hibernate.mapping.property.EReferenceP ropertyHandler.get(EReferencePropertyHandler.java:92)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.getPropert yValue(AbstractEntityTuplizer.java:277)
at org.hibernate.persister.entity.AbstractEntityPersister.getPr opertyValue(AbstractEntityPersister.java:3514)
at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
at org.hibernate.event.def.AbstractSaveEventListener.cascadeBef oreSave(AbstractSaveEventListener.java:412)
at org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:261)
at org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:180)
at org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:108)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:186)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:175)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:98)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
at org.hibernate.engine.CascadingAction$1.cascade(CascadingActi on.java:217)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
at org.hibernate.event.def.DefaultSaveEventListener.saveWithGen eratedOrRequestedId(DefaultSaveEventListener.java:33)
at org.hibernate.event.def.DefaultSaveEventListener.performSave OrUpdate(DefaultSaveEventListener.java:27)
at org.hibernate.impl.SessionImpl.fireSave(SessionImpl.java:535 )
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:523)
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:519)
at org.ziptie.persist.cs3800Load.doLoadDoc(cs3800Load.java:122)
at org.ziptie.persist.cs3800Load.main(cs3800Load.java:47)
Any advice on how to handle dynamically loading packages and using them within Teneo are greatly appreciated. Everything thing seems to be working OK using the generated Java packages.
Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71132 is a reply to message #71113] |
Fri, 09 February 2007 06:22   |
Brian,
I think Ed can best answer the questions related to how to import related epackages from multiple
xsd's. My impression (but I am not sure) is that the XSDEcoreBuilder does not register the epackage
in the global epackage registry. This is at least required for Teneo.
Related to the table naming, can you upload the generated hibernate mapping?
gr. Martin
> example:
> ziptypes_device111
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Brian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71152 is a reply to message #71113] |
Fri, 09 February 2007 06:46   |
Brian,
Comments below.
It sounds like you want to call "Collection<Object>
generate(Collection<URI> uris)" so that a single resource set is used to
process all the schemas and hence a single set of packages representing
them all will be produced.
> For example:
> ziptypes_device111
Yes, it sounds likely that you are getting duplicate packages if you are
calling "Collection<EObject> generate(URI uri)" multiple times.
With regard to Martin's comment about global registration, the
XSDEcoreBuilder has a constructor that allow you to pass in an
ExtendedMetaData instance. The default constructor just creates a new
empty instance of it. So if you use new
XSDEcoreBuilder(ExtendedMetaData.INSTANCE), the packages should be
registered in the global registry as a side effect of generating them...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71256 is a reply to message #71152] |
Sat, 10 February 2007 18:24   |
The trick to get this to work was to use the generate(Collection<URI> uris) method and not individual calls to generate(uri).
The problem had nothing to do with the registration. I had been registering the packages manually. I had taken care to not register the same namespace more than once, but that didn't seem to matter. I also changed it to use the ExtendedMetaData.INSTANCE argument to the builder constructor and got the same incorrect results.
While I have it working correctly today, I'd like to understand how I could do this more "dynamically" in the future as opposed to having to batch up all of the potential namespaces in a single call to generate(). More specifically, I'd like my server to be handed a URI to an XSD while it is running and then "magically" do the appropriate registrations and such to then persist new documents using that XSD. I'd like to do this without having to restart the server.
At present, I have two obstacles. One, Teneo only has a setPackages() method that can be called on the datastore. The packages are mapped when the datastore is initialized. While I haven't tried it, I figure that to be able to dynamically add new packages after the server is up and running, I'd have to destroy the current datastore and create a new one with the new packages that were added. Not the best answer, but it sounds doable. I'm presuming I can make it work somehow.
However, the second problem is with the global registry. If I can't add new packages on the fly, is there a similar (or better) way to rebuild the list of packages in the global registry? If not, is there some reason why separate generate() calls could not reuse any dependent packages that are already in the global registry?
Brian
Ed Merks wrote:
> Brian,
> Comments below.
>> For example:
>> ziptypes_device111
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71277 is a reply to message #71132] |
Sun, 11 February 2007 03:33   |
Martin & Ed,
I got past the original issues by implementing Ed's suggestion to generate all of the ecore mappings at once using a collection instead of generating each individually. I have been able to persist XML documents of various XSDs without the need to generate and compile supporting Java classes.
However if I try to load these objects using a hibernate query, I get a null pointer exception. I've run two variations of the program exactly equal but with one difference - one utilizes the Java classes when registering the packages with Teneo and the other uses the packages generated using the XSDEcoreBuilder (this time using the generate(collection) method that works for persisting the same XML documents).
In looking at the stack trace, it gets a long ways down the query path before it hits an NPE in a Teneo setter method from the hibernate tuplizer. It is tripping in the convert() method in EAttributePropertyHandler over a null instanceClass. The actual type is an attribute on a simple type that extends long. The attribute has an enumerated list of potential values.
In trying to determine what was different between the dynamic version and the one using the generated Java classes, I found the following:
1) The order of the registered packages passed to Teneo varied between the two.
2) After forcing the order of the packages to be the same in both, I found that the hibernate mappings varied in many ways.
2a) The names in the typedef elements were frequently (but not always) different. In particular, in the working version where the java classes are used, the names typically started with the NsPrefix of the package. In the auto-generated version, it used a transformed version of the fully qualified namespace.
2b) Some of the property mappings were different. In fact, it appears that almost all of the mappings that were different were those that were dealing with the elements or attributes that had restrictions of Strings with an enumeration list.
It is 2b above that I think is causing me my trouble: Here is an example of the type mapping (in this case, it is the one that the NPE is being thrown, but it is the first one that the mapping has run up against):
In the case where it is using the generated Java classes:
<property name="unit" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`unit`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass">org.ziptie._1._0.basictypes.UnitType1</param >
</type>
</property>
In the case where it is dynamically created:
<type name="org.eclipse.emf.teneo.hibernate.mapping.DynamicENumUserType ">
<param name="eclassifier">UnitType1</param>
<param name="epackage">http://www.ziptie.org/1.0/basictypes</param>
</type>
</property>
Notice that the type mapping is quite different. In the second case, the method called by the tuplizer gets an NPE.
I'm not sure if ecore is treating these as different or if Teneo is not handling a particular ecore mapping properly. I'm presuming that there is some issue with Teneo handling the dynamic enum case since no class is there to implement it directly.
I noticed a couple of statements about problems with enumerates on the Teneo troubleshooting page. I didn't see any issues w.r.t. dynamic mapping vs. using generated java classes so it wasn't clear that there is any relation (especially since it appears to work using the generated java).
Brian
Martin Taal wrote:
> Brian,
> related epackages from multiple xsd's. My impression (but I am not sure)
> is that the XSDEcoreBuilder does not register the epackage in the global
> mapping?
> gr. Martin
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71297 is a reply to message #71256] |
Sun, 11 February 2007 08:39   |
Brian,
If you look at the two generate methods, you'll see that they
effectively just create a resource set, load one or more schema
resources, and then call generate(XSDSchema) for each schema. So you
could define a derived builder that maintains a resource set as a field
and keeps reusing it for each call (perhaps just by overriding
createResourceSet to return the same one each time).
> Brian
> Ed Merks wrote:
>> Brian,
>> Comments below.
>>> that import them.
>> to process all the schemas and hence a single set of packages
>> representing them all will be produced.
>>> ziptypes_device111
>> are calling "Collection<EObject> generate(URI uri)" multiple times.
>>> I am unsure.
>> new empty instance of it. So if you use new
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71317 is a reply to message #71277] |
Sun, 11 February 2007 14:24   |
Brian,
The npe has been solved and committed to cvs (we also encountered it this week).
gr. Martin
Brian Vetter wrote:
> Martin & Ed,
> classes.
> documents).
> the two.
> <type
> <param
> </type>
> </property>
> <type
> <param
> </type>
> </property>
> java).
> Brian
> Martin Taal wrote:
>> Brian,
>> sure) is that the XSDEcoreBuilder does not register the epackage in
>> mapping?
>> gr. Martin
The Netherlands
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71396 is a reply to message #71297] |
Mon, 12 February 2007 18:59   |
Ed,
I've implemented things this way and it worked for the case when I load up a bunch of XSDs at once. However, if I want to create a dynamic package and add it to this list, how exactly would I do it? There is no ResourceSet for the dynamic calls (at least I didn't see it, but then I'm pretty blind these days).
Is there some special api/trick to registering the dynamic package I created so that it is included with the others?
The particular issue I'm having is that when I combine the dynamic package with the others that are loaded, Teneo is giving me an exception complaining about a null EClass. The error message is:
Passed eclass is null.This can occur if epackages which refer to eachother are placed in different ecore/xsd files and they are not read using one resource set. The reference from one epackage to another must be resolvable by EMF.
My generated packages are referring to types in the ones loaded from the file uri.
Brian
Ed Merks wrote:
> Brian,
>> Thanks,
>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71414 is a reply to message #71396] |
Tue, 13 February 2007 08:18   |
Brian,
It's not entirely clear to me the relationship between the dynamic
packages created (generated?) by the XSDEcoreBuilder and these other
dynamic ones or how these other ones are created. When you say the
"generated" packages refer to types in the one loaded from the file
URI. Do you really mean a static generated package or a dynamic one
created by the XSDEcoreBuilder? It doesn't seem possible for a
generated static package to refer to a dynamic one, so that's confusing.
Maybe you could paint a very simple scenario so that I understand better
the question you are asking...
Brian Vetter wrote:
> Ed,
> the file uri.
> Brian
> Ed Merks wrote:
>> Brian,
>> field and keeps reusing it for each call (perhaps just by overriding
>>> generate(uri).
>>> server.
>>> Thanks,
>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71433 is a reply to message #71414] |
Tue, 13 February 2007 08:57   |
Sorry for the confusing terms. Everything was dynamic. Here's the
steps/scenario:
I have a list of xsds in the file system that I load and generate the
ecore model using a subclass of the XSDEcoreBuilder.
In addition, I need to create a new EPackage and associated EClasses
that contain EReferences to types that are defined in the previously
generated ECore classes using EMF's dynamic APIs.
When I try to use Teneo to help persist instance of these packages, it
urps out an error message saying that they must be created in the same
resource.
Besides the basic registration with the package registry (which didn't
work), how do I register or associate the package created using the
dynamic APIs with the ones generated using the XSDEcoreBuilder class?
I've maintained the ResourceSet but I couldn't see how I could associate
it with the package I created using createEPackage(). Is there a
different factory I should use? A different registration function?
Brian
Ed Merks wrote:
> Brian,
> Brian Vetter wrote:
>> Ed,
>> the file uri.
>> Brian
>> Ed Merks wrote:
>>> Brian,
>>>> generate(uri).
>>>> server.
>>>> Thanks,
>>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71471 is a reply to message #71433] |
Tue, 13 February 2007 11:03   |
--------------030803020707030600040503
Brian,
I'm not sure specifically what's causing Teneo to hiccup, so I'm not
sure what the best way to avoid that is...
If you look at this method in the XSDEcoreBuilder, you'll see that it
puts the EPackage into resources:
public Collection<Resource> generateResources(Collection<URI> uris)
ResourceSet resourceSet = createResourceSet();
for (URI uri : uris)
Resource resource = resourceSet.getResource(uri, true);
if (!resource.getContents().isEmpty() &&
resource.getContents().get(0) instanceof XSDSchema)
generate((XSDSchema)resource.getContents().get(0));
for (EPackage ePackage : targetNamespaceToEPackageMap.values())
if (ePackage.eResource() == null)
Resource ecoreResource =
resourceSet.createResource(URI.createURI("*.ecore"));
ecoreResource.setURI(URI.createURI(ePackage.getNsURI()));
ecoreResource.getContents().add(ePackage);
return new ArrayList<Resource>(resourceSet.getResources());
You don't necessarily have to call this method nor do you necessarily
have to put the packages in the same resource set as the schemas.
Perhaps all that's needed is for the packages to be registered in the
package registry of the resource set that you are using for your
manually constructed dynamic models. Given these constructors:
public XSDEcoreBuilder()
this(new BasicExtendedMetaData(new EPackageRegistryImpl()));
public XSDEcoreBuilder(ExtendedMetaData extendedMetaData)
this.extendedMetaData = extendedMetaData;
populateTypeToTypeObjectMap(XMLTypePackage.eINSTANCE);
populateTypeToTypeObjectMap(XMLNamespacePackage.eINSTANCE);
one way to do that would be to do new XSDEcoreBuilder(new
BasicExtendedMetaData(dynamicEPackageResourceSet.getPackageR egistry())).
The XSDEcoreBuilder will as a side effect register the EPackages it
creates in that package registry.
> steps/scenario:
> resource.
> associate it with the package I created using createEPackage(). Is
> there a different factory I should use? A different registration
> function?
> Brian
> Ed Merks wrote:
>> Brian,
>> confusing. Maybe you could paint a very simple scenario so that I
>> understand better the question you are asking...
>> Brian Vetter wrote:
>>> Ed,
>>> the file uri.
>>> Brian
>>> Ed Merks wrote:
>>>> Brian,
>>>> you could define a derived builder that maintains a resource set as
>>>> a field and keeps reusing it for each call (perhaps just by
>>>> overriding createResourceSet to return the same one each time).
>>>>> generate(uri).
>>>>> results.
>>>>> restart the server.
>>>>> Thanks,
>>>>> Brian
<html>
<head>
</head>
Brian,<br>
<br>
sure what the best way to avoid that is... <br>
<br>
puts the EPackage into resources:<br>
<blockquote><small> public Collection<Resource>
generateResources(Collection<URI> uris)</small><br>
<small> {</small><br>
<small> ResourceSet resourceSet = createResourceSet();</small><br>
<small> for (URI uri : uris)</small><br>
<small> Resource resource = resourceSet.getResource(uri, true);</small><br>
<small> if (!resource.getContents().isEmpty() &&
resource.getContents().get(0) instanceof XSDSchema)</small><br>
<small> generate((XSDSchema)resource.getContents().get(0));</small> <br>
<small> }</small><br>
<b><br>
<small> for (EPackage ePackage :
targetNamespaceToEPackageMap.values())</small><br>
<small> if (ePackage.eResource() == null)</small><br>
<small> Resource ecoreResource =
resourceSet.createResource(URI.createURI("*.ecore"));</small ><br>
<small>
ecoreResource.setURI(URI.createURI(ePackage.getNsURI()));</small ><br>
<small> ecoreResource.getContents().add(ePackage);</small><br>
<small> }</small></b><br>
<small> <b>}</b></small><br>
<br>
<small> return new
ArrayList<Resource>(resourceSet.getResources() ); </small><br>
</blockquote>
have to put the packages in the same resource set as the schemas. <br>
<br>
manually constructed dynamic models. Given these constructors:<br>
<blockquote><small> public XSDEcoreBuilder()<br>
{<br>
this(new BasicExtendedMetaData(new EPackageRegistryImpl()));<br>
}<br>
<br>
public XSDEcoreBuilder(ExtendedMetaData extendedMetaData)<br>
{<br>
this.extendedMetaData = extendedMetaData;<br>
populateTypeToTypeObjectMap(XMLTypePackage.eINSTANCE);<br>
populateTypeToTypeObjectMap(XMLNamespacePackage.eINSTANCE);<br >
}</small><br>
</blockquote>
creates in that package registry.<br>
<br>
<br>
Brian Vetter wrote:
<blockquote cite="mideqsg16$f6t$1@utils.eclipse.org" type="cite">Sorry
steps/scenario:
<br>
<br>
<br>
<br>
<br>
<br>
resource.
<br>
<br>
<br>
<br>
function?
<br>
<br>
Brian
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Brian,
<br>
<br>
<br>
<br>
<br>
Brian Vetter wrote:
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
the file uri.
<br>
<br>
Brian
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Brian Vetter wrote:
<br>
<blockquote type="cite">The trick to get this to work was to
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Brian
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030803020707030600040503--
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #71488 is a reply to message #71471] |
Tue, 13 February 2007 16:14  |
Thanks. Getting them registered with the correct package registry did the trick.
Brian
Ed Merks wrote:
> Brian,
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602399 is a reply to message #71113] |
Brian,
gr. Martin
> example:
> ziptypes_device111
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Brian
The Netherlands
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602410 is a reply to message #71113] |
Brian,
Comments below.
> For example:
> ziptypes_device111
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602441 is a reply to message #71152] |
Brian
Ed Merks wrote:
> Brian,
> Comments below.
>> For example:
>> ziptypes_device111
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602448 is a reply to message #71132] |
Martin & Ed,
</type>
</property>
</type>
</property>
Brian
Martin Taal wrote:
> Brian,
> mapping?
> gr. Martin
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602455 is a reply to message #71256] |
Brian,
> Brian
> Ed Merks wrote:
>> Brian,
>> Comments below.
>>> that import them.
>>> ziptypes_device111
>>> I am unsure.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602460 is a reply to message #71277] |
Brian,
gr. Martin
Brian Vetter wrote:
> Martin & Ed,
> classes.
> documents).
> the two.
> <type
> <param
> </type>
> </property>
> <type
> <param
> </type>
> </property>
> java).
> Brian
> Martin Taal wrote:
>> Brian,
>> mapping?
>> gr. Martin
The Netherlands
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602483 is a reply to message #71297] |
Ed,
Brian
Ed Merks wrote:
> Brian,
>> Thanks,
>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602494 is a reply to message #71396] |
Brian,
Brian Vetter wrote:
> Ed,
> the file uri.
> Brian
> Ed Merks wrote:
>> Brian,
>>> generate(uri).
>>> server.
>>> Thanks,
>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602498 is a reply to message #71414] |
steps/scenario:
resource.
Brian
Ed Merks wrote:
> Brian,
> Brian Vetter wrote:
>> Ed,
>> the file uri.
>> Brian
>> Ed Merks wrote:
>>> Brian,
>>>> generate(uri).
>>>> server.
>>>> Thanks,
>>>> Brian
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602510 is a reply to message #71433] |
Brian,
> steps/scenario:
> resource.
> function?
> Brian
> Ed Merks wrote:
>> Brian,
>> Brian Vetter wrote:
>>> Ed,
>>> the file uri.
>>> Brian
>>> Ed Merks wrote:
>>>> Brian,
>>>>> generate(uri).
>>>>> results.
>>>>> restart the server.
>>>>> Thanks,
>>>>> Brian
<html>
<head>
</head>
Brian,<br>
<br>
<br>
<b><br>
<small>
<br>
<small> return new
</blockquote>
<br>
{<br>
}<br>
<br>
{<br>
}</small><br>
</blockquote>
<br>
<br>
steps/scenario:
<br>
<br>
<br>
<br>
<br>
<br>
resource.
<br>
<br>
<br>
<br>
function?
<br>
<br>
Brian
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Brian Vetter wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
the file uri.
<br>
<br>
Brian
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Brian Vetter wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Brian
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: [Teneo] Dynamic mapping using XSDEcoreBuilder [message #602515 is a reply to message #71471] |
Brian
Ed Merks wrote:
> Brian,
Current Time: Mon Jul 14 05:00:59 EDT 2025
Powered by FUDForum. Page generated in 0.59087 seconds
