Home » Archived » XML Schema Definition (XSD) » convert ecore to xsd
convert ecore to xsd [message #70970] Sun, 17 December 2006 17:15 Go to next message
Originally posted by: elena.tibrea.gmail.com
When converting ecore to xsd, I would like not to have any ecore types in
my output xsd file.
e.g
not <xsd:attribute name="b" type="ecore:EString"/>
but <xsd:attribute name="b" type="xsd:string"/>
Can you give me a clue?
Thank you!
elena
Re: convert ecore to xsd [message #70993 is a reply to message #70970] Mon, 18 December 2006 06:59 Go to previous message
Elena,
If in your model you use data types from the XMLTypePackage, i.e.,
XMLTypePackage.Literals.STRING, rather data types from the EcorePackage,
then you'll get what you want.
> in my output xsd file.
> e.g not <xsd:attribute name="b" type="ecore:EString"/>
> Thank you!
> elena
Re: convert ecore to xsd [message #599275 is a reply to message #70970] Mon, 18 December 2006 06:59 Go to previous message
Elena,
> Thank you!
> elena
Previous Topic:convert ecore to xsd
Next Topic:Trouble getting XSD sample running
Current Time: Fri Jul 18 02:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
