Home » Archived » BIRT » working with ArrayList n Iterator in Scripted Data Source
working with ArrayList n Iterator in Scripted Data Source [message #70950] Thu, 01 September 2005 18:25 Go to next message
Originally posted by: sai.yelamanchili.gmail.com
Hi ,
One of my reports uses a scripted data source ( accesses two java files,
one a java object and other is a class that has a function that returns
ArrayList of the above object,) which returns an ArrayList of the
above JavaObject. Any ideas on how to work with this. Looking for sample
code in Open and fetch . I tried using iterator but ended up with some
syntax errors. I guess can't use java objects as they are in BIRT scripting.
Help appreciated.
Sai
Got it! [message #70972 is a reply to message #70950] Thu, 01 September 2005 18:35 Go to previous message
This helps!
http://eclipse.org/birt/wiki/index.php?n=FAQ.DataAccess
Sai Yelamanchili wrote:
> Hi ,
> scripting.
> Help appreciated.
> Thanks
> Sai
Previous Topic:Re: BIRT Web Viewer Error
Next Topic:PDF Layout
Current Time: Tue Jul 22 21:21:10 EDT 2025
Powered by FUDForum. Page generated in 0.04201 seconds
