Home » Eclipse Projects » Remote Application Platform (RAP) » problem with images
problem with images [message #70943] Mon, 21 January 2008 10:36 Go to next message
Originally posted by: wen.ai.gillardon.de
Hi all rap committers and developers,
I have a Problem with Images. I would like to create an image-object
from an external data resource programmatically, just like this code:
InputStream is = ...;
Image image = Graphics.getImage("test", is);
label.setImage(image);pThis image-object "image" should be deleted
after viewing it.
My problem:
1. How can I dispose this "image"?
2. The Image-Object "image" would finally be saved in a HashMap "images"
(in ResourceFactory.java). Would the HashMap "images" completely be
stored in cache? If so, can I delete such an image-object "image" from
the HashMap "images"? Otherwise, more and more images will be saved in it.
3. How can I change the size of the image-object, if I change the size
of the outside window?
Thank you for your help in advance.
Greetings
Wen
Re: problem with images [message #71136 is a reply to message #70943] Wed, 23 January 2008 03:47 Go to previous messageGo to next message
Can anyone help me to fix the problem?
Thanks a lot:-))
Wen
> after viewing it.
> My problem:
> Greetings
> Wen
Re: problem with images [message #71156 is a reply to message #70943] Wed, 23 January 2008 04:30 Go to previous messageGo to next message
Wen,
It's common practice to use something like JFace's ImageRegistry for
caching reusable images. But it's also reasonable to have a dispose
listener on your control (perhaps on the label, on the composite holding
the label, or specializing the dispose method of a higher level part)
and disposing the image then. I don't think images are normally resized
since that doesn't generally produce pretty results.
> after viewing it.
> My problem:
> "images" (in ResourceFactory.java). Would the HashMap "images"
> completely be stored in cache? If so, can I delete such an
> image-object "image" from the HashMap "images"? Otherwise, more and
> Greetings
> Wen
Re: problem with images [message #71858 is a reply to message #71156] Mon, 28 January 2008 04:17 Go to previous messageGo to next message
in our application birt chart works for the graphical representation. If
RAP has offered such a mechanism for cleaning up the images (without
reusing them) from ResourceFactory, please let me know, or resizing the
image without rendering again, or RAP + Birt work already together......
Thanks a lot.
Wen
Ed Merks schrieb:
> Wen,
>> after viewing it.
>> My problem:
>> Greetings
>> Wen
Re: problem with images [message #72610 is a reply to message #71858] Fri, 01 February 2008 07:41 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
as RAP shares images between user sessions, it is currently not possible to
dispose of a single image instance. But RAP stores the images on disk and
does not buffer the images in memory. The registry only contains a link
where the file is located. So memory inpact is pretty low.
Ciao
Frank
"Wen Ai" <wen.ai@gillardon.de> schrieb im Newsbeitrag
news:fnk6jp$p2j$1@build.eclipse.org...
> Thanks a lot.
> Regards
> Wen
> Ed Merks schrieb:
>> Wen,
>> the label, or specializing the dispose method of a higher level part) and
>>> This image-object "image" should be deleted after viewing it.
>>> My problem:
>>> it.
>>> Greetings
>>> Wen
Re: problem with images [message #72638 is a reply to message #72610] Fri, 01 February 2008 07:58 Go to previous messageGo to next message
--------------050300020701040906060500
Frank,
I see! I've had problems building up composed images with transparent
overlays. Is that a know problem?
Frank Appel wrote:
> Ciao
> Frank
>> Thanks a lot.
>> Regards
>> Wen
>> Ed Merks schrieb:
>>> Wen,
>>>> My problem:
>>>> it.
>>>> Greetings
>>>> Wen
<html>
<head>
</head>
Frank,<br>
<br>
I see!&nbsp; I've had problems building up composed images with transparent
overlays.&nbsp; Is that a know problem?<br>
<br>
<br>
Frank Appel wrote:
<blockquote cite="mid:fnv42d$ql4$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
Ciao
Frank
"Wen Ai" <a class="moz-txt-link-rfc2396E" href="mailto:wen.ai@gillardon.de">&lt;wen.ai@gillardon.de&gt;</a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:fnk6jp$p2j$1@build.eclipse.org">news:fnk6jp$p2j$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
Thanks a lot.
Wen
Ed Merks schrieb:
</pre>
<pre wrap="">Wen,
Wen Ai wrote:
</pre>
<pre wrap="">Hi all rap committers and developers,
My problem:
it.
Greetings
Wen
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050300020701040906060500--
Re: problem with images [message #72691 is a reply to message #72638] Fri, 01 February 2008 08:17 Go to previous messageGo to next message
------=_NextPart_000_01BB_01C864DD.2CDB03C0
charset="iso-8859-1"
Yes this should be difficult with the current possibilities. But =
hopefully there will be a solution to this available soon, since we have =
to provide image decorators and if I'm not mistaken this is based on =
composed images.
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:fnv52d$uq6$2@build.eclipse.org...
Frank,
I see! I've had problems building up composed images with transparent =
Frank Appel wrote:=20
as RAP shares images between user sessions, it is currently not possible =
to=20
dispose of a single image instance. But RAP stores the images on disk =
and=20
does not buffer the images in memory. The registry only contains a link=20
Ciao
Frank
"Wen Ai" <wen.ai@gillardon.de> schrieb im Newsbeitrag=20
in our application birt chart works for the graphical representation. If =
RAP has offered such a mechanism for cleaning up the images (without=20
reusing them) from ResourceFactory, please let me know, or resizing the=20
Thanks a lot.
Wen
Ed Merks schrieb:
Wen,
It's common practice to use something like JFace's ImageRegistry for=20
caching reusable images. But it's also reasonable to have a dispose=20
listener on your control (perhaps on the label, on the composite holding =
the label, or specializing the dispose method of a higher level part) =
and=20
disposing the image then. I don't think images are normally resized=20
I have a Problem with Images. I would like to create an image-object=20
InputStream is =3D ...;
Image image =3D Graphics.getImage("test", is);
My problem:
2. The Image-Object "image" would finally be saved in a HashMap "images" =
(in ResourceFactory.java). Would the HashMap "images" completely be=20
stored in cache? If so, can I delete such an image-object "image" from=20
the HashMap "images"? Otherwise, more and more images will be saved in=20
it.
3. How can I change the size of the image-object, if I change the size=20
Greetings
Wen=20
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16587" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Yes this should be difficult with the =
current=20
possibilities. But&nbsp;hopefully there will be a solution to this =
available=20
soon, since we have to provide image decorators and if I'm not=20
mistaken&nbsp;this is based on&nbsp;composed images.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
schrieb im Newsbeitrag <A=20
href=3D"news:fnv52d$uq6$2@build.eclipse.org">news:fnv52d$uq6$2@build.ecli=
pse.org</A>...</DIV>Frank,<BR><BR>I=20
see!&nbsp; I've had problems building up composed images with =
transparent=20
overlays.&nbsp; Is that a know problem?<BR><BR><BR>Frank Appel wrote:=20
<BLOCKQUOTE cite=3Dmid:fnv42d$ql4$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi,
to=20
and=20
Ciao
Frank
"Wen Ai" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:wen.ai@gillardon.de">&lt;wen.ai@gillardon.de&gt;</A> =
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fnk6jp$p2j$1@build.eclipse.org">news:fnk6jp$p2j$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
Thanks a lot.
Wen
Ed Merks schrieb:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Wen,
and=20
Wen Ai wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi all rap committers =
and developers,
My problem:
it.
Greetings
Wen=20
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE><PRE =
wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_01BB_01C864DD.2CDB03C0--
Re: problem with images [message #72725 is a reply to message #72691] Fri, 01 February 2008 08:46 Go to previous messageGo to next message
--------------020900050106010508030403
Frank,
That's what I suspected. Yes decorators as supported by the workbench
navigators are based on composing icons with overlays. Is there a
bugzilla I could track?
> But hopefully there will be a solution to this available soon, since
> we have to provide image decorators and if I'm not mistaken this is
> based on composed images.
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> schrieb im
> Newsbeitrag news:fnv52d$uq6$2@build.eclipse.org...
> Frank,
> transparent overlays. Is that a know problem?
> Frank Appel wrote:
>> Ciao
>> Frank
>>> Hi,
>>> Thanks a lot.
>>> Regards
>>> Wen
>>> Ed Merks schrieb:
>>>> Wen,
>>>>> My problem:
>>>>> it.
>>>>> Greetings
>>>>> Wen
<html>
<head>
</head>
Frank,<br>
<br>
That's what I suspected.&nbsp; Yes decorators as supported by the workbench
navigators are based on composing icons with overlays.&nbsp; Is there a
bugzilla I could track?<br>
<br>
<br>
Frank Appel wrote:
<blockquote cite="mid:fnv65d$60e$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16587" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Yes this should be difficult with
the current possibilities. But&nbsp;hopefully there will be a solution to
this available soon, since we have to provide image decorators and if
I'm not mistaken&nbsp;this is based on&nbsp;composed images.</font></div>
<div>&nbsp;</div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt; schrieb im
Newsbeitrag <a moz-do-not-send="true"
href="news:fnv52d$uq6$2@build.eclipse.org">news:fnv52d$uq6$2@build.eclipse.org</a>...</div>
Frank,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
Ciao
Frank
"Wen Ai" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
<pre wrap="">Hi,
Thanks a lot.
Wen
Ed Merks schrieb:
</pre>
<pre wrap="">Wen,
Wen Ai wrote:
</pre>
My problem:
it.
Greetings
Wen
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020900050106010508030403--
Re: problem with images [message #72741 is a reply to message #72725] Fri, 01 February 2008 09:12 Go to previous message
------=_NextPart_000_0054_01C864E4.EBA8F9E0
charset="us-ascii"
Hi again,
I've created bug #217437 to track the progress. Hope that's what you
need :-)
Ciao
Frank
_____
Von: Ed Merks [mailto:merks@ca.ibm.com]
Bereitgestellt: Freitag, 1. Februar 2008 14:46
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: problem with images
Betreff: Re: problem with images
Frank,
composed images.
Frank,
to
and
Ciao
Frank
"Wen Ai" <mailto:wen.ai@gillardon.de> <wen.ai@gillardon.de> schrieb im
Newsbeitrag
Thanks a lot.
Wen
Ed Merks schrieb:
Wen,
and
My problem:
it.
Greetings
Wen
charset="us-ascii"
<HTML><HEAD>
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.6000.16587" name=3DGENERATOR></HEAD>
<DIV dir=3Dltr align=3Dleft><FONT face=3DArial color=3D#0000ff =
size=3D2><SPAN=20
class=3D128341014-01022008>Hi again,</SPAN></FONT></DIV>
size=3D2><SPAN=20
class=3D128341014-01022008></SPAN></FONT>&nbsp;</DIV >
size=3D2><SPAN=20
class=3D128341014-01022008>I've created bug #217437 to track the =
progress. Hope=20
that's what you need :-)</SPAN></FONT></DIV>
size=3D2><SPAN=20
size=3D2><SPAN=20
size=3D2><SPAN=20
class=3D128341014-01022008>Ciao</SPAN></FONT></DIV>
size=3D2><SPAN=20
class=3D128341014-01022008>Frank</SPAN></FONT></DIV>
size=3D2><SPAN=20
class=3D128341014-01022008></SPAN></FONT>&nbsp;</DIV ><BR>
<DIV class=3DOutlookMessageHeader lang=3Dde dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>Von:</B> Ed Merks =
[mailto:merks@ca.ibm.com]=20
<BR><B>Bereitgestellt:</B> Freitag, 1. Februar 2008 =
14:46<BR><B>Bereitgestellt=20
in:</B> eclipse.technology.rap<BR><B>Unterhaltung:</B> problem with=20
images<BR><B>Betreff:</B> Re: problem with=20
images<BR><BR></FONT></DIV>Frank,<BR><BR>That's what I suspected.&nbsp; =
Yes=20
decorators as supported by the workbench navigators are based on =
composing icons=20
with overlays.&nbsp; Is there a bugzilla I could track?<BR><BR><BR>Frank =
Appel=20
wrote:=20
<BLOCKQUOTE cite=3Dmid:fnv65d$60e$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
current=20
available=20
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>&gt; schrieb im =
Newsbeitrag <A=20
href=3D"news:fnv52d$uq6$2@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fnv52d$uq6$2@build.eclipse.org</A>...</DIV>=
Frank,<BR><BR>I=20
transparent=20
overlays.&nbsp; Is that a know problem?<BR><BR><BR>Frank Appel =
wrote:=20
to=20
and=20
Ciao
Frank
href=3D"mailto:wen.ai@gillardon.de" =
moz-do-not-send=3D"true">&lt;wen.ai@gillardon.de&gt;</A> schrieb im =
Newsbeitrag=20
href=3D"news:fnk6jp$p2j$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:fnk6jp$p2j$1@build.eclipse.org</A>...
</PRE>
Thanks a lot.
Wen
Ed Merks schrieb:
</PRE>
and=20
Wen Ai wrote:
</PRE>
and developers,
My problem:
it.
Greetings
Wen=20
wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BODY ></HTML>
------=_NextPart_000_0054_01C864E4.EBA8F9E0--
Previous Topic:Hyperlink disabled for messages in Forms
Next Topic:Problem with patch fragments
Current Time: Thu Jun 05 00:32:15 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
