java.lang.NullPointerException --> org.eclipse.ajdt.ui [message #70918] |
Thu, 29 November 2007 09:48 |
I have a lot of aspects to weave in several of my eclipse plug'ins. And
I get a lot of errors in the "Error Log" view that looks like that:
!ENTRY org.eclipse.ajdt.ui 4 0 2007-11-29 14:42:29.000
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.findFile( UIMessageHandler.java:437)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.tryToFind Resource(UIMessageHandler.java:413)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.locationT oResource(UIMessageHandler.java:384)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.access$2( UIMessageHandler.java:364)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler$1.run(UIM essageHandler.java:248)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1779)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showMessa ges(UIMessageHandler.java:336)
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showOutst andingProblems(UIMessageHandler.java:204)
org.eclipse.ajdt.internal.builder.UIBuildListener.postAJBuil d(UIBuildListener.java:163)
org.eclipse.ajdt.core.builder.AJBuilder.postCallListeners(AJ Builder.java:833)
at org.eclipse.ajdt.core.builder.AJBuilder.build(AJBuilder.java :241)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:624)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:166)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:197)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:246)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:249)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:302)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:334)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:137)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:235)
!SUBENTRY 1 org.eclipse.ajdt.ui 4 0 2007-11-29 14:42:29.000
!MESSAGE
org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.findFile( UIMessageHandler.java:447)
!SUBENTRY 1 org.eclipse.ajdt.ui 1 1 2007-11-29 14:42:29.000
!MESSAGE org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler@10495de
!SUBENTRY 2 org.eclipse.ajdt.ui 1 0 2007-11-29 14:42:29.000
!MESSAGE ignoring=class java.util.ArrayList@567912420
!MESSAGE problems=class java.util.ArrayList@1153419963
!MESSAGE affectedResources=class java.util.HashSet@204782412
!MESSAGE otherProjectMarkers=class java.util.HashMap@0
!MESSAGE lastBuildWasFull=class java.lang.Boolean@1231
It seems to be User Interface errors but is there any solution to avoid
this ?
Regards.
Mickael.
FUDForum. Page generated in 0.22889 seconds
