Large Application - No data is available for display [message #70907] |
Mon, 15 May 2006 23:52  |
Profiling a small application seems to work without a problem. With a
large, Swing-based application I get only:
"No data is available for display.
The object selected in the Profiling Monitor view does not contain this
type of information. .."
On any of the panels that I can access with "Open With" (pressing the
"Link With Viewer" seems to have no effect).
I've tried a number of different profiling options, but is we consider
just "Basic Memory Analysis". Now consider the "Memory Statistics" tab.
For the small application I see useful things, for the large application,
just the error message. I'm running the same "profiling set" in both
cases and as far as I can tell, everything is the same except the nature
of the applications.
Are there some parameters that need to be tweaked to debug large
application (or Swing?). Is there something obvious that I'm missing?
In case it's useful the application runs more than a factor of 10 slower
than when just debugging.
Jim
Re: Large Application - No data is available for display [message #71045 is a reply to message #71007] |
Tue, 16 May 2006 14:04  |
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0063431985257170_=
Content-Type: text/plain; charset="US-ASCII"
Are you profiling to a file by any chance? In your launch configuration,
when you click on the destination tab, is the 'send profiling data to a
file' checked?
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Are you profiling to a file by any chance?
In your launch configuration, when you click on the destination tab,
is the 'send profiling data to a file' checked?</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0063431985257170_=--
FUDForum. Page generated in 0.10089 seconds
