Home » Archived » BIRT » Any way of referencing multiple datasets from a report object?
Any way of referencing multiple datasets from a report object? [message #70891] Thu, 01 September 2005 16:49 Go to next message
For a table i would like to display dynamic query data in the header. For
example, i have a column labeled with a month of the year and the number of
"selling days" for that month (ie. "January (21)"). The value 21 needs to
come from a database query that is independent of the dataset used to render
the rows. Any ideas? Is there a technical reason why only one dataset can
be used per table?
A similar issue exists for the text widget. I would like to have the
ability to display data from multiple resultsets. I have had to resort to
creating an additional dataset to join all the data needed by text widget.
It works, but i would rather use the existing set of datasets.
Re: Any way of referencing multiple datasets from a report object? [message #70912 is a reply to message #70891] Thu, 01 September 2005 17:02 Go to previous messageGo to next message
Marko,
You could always override the create method for the control and make a POJO
call or use another Data set that will set a global variable.
Jason Weathersby
BIRT PMC
"Marko" <mmilicevic@pssd.com> wrote in message
news:df7pc6$fal$1@news.eclipse.org...
> of
> render
> can
> be used per table?
Re: Any way of referencing multiple datasets from a report object? [message #71404 is a reply to message #70912] Fri, 02 September 2005 13:25 Go to previous messageGo to next message
Thanks Jason. Can you point me to any sample code that demonstrates
building another dataset from script? Presumably i create new dataset from
a datasource? I don't see where the object model support this?
Thank you.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:df7q8f$gel$1@news.eclipse.org...
> Marko,
POJO
> Jason Weathersby
> BIRT PMC
For
> > of
to
> > render
> > can
> > be used per table?
to
widget.
Re: Any way of referencing multiple datasets from a report object? [message #71560 is a reply to message #71404] Fri, 02 September 2005 15:04 Go to previous messageGo to next message
Marko,
Attached is a report that creates two data sets.
One for offices and one for orders.
In the reports initialize method I create a global variable test.
I add two tables to the report one for each data set.
I set the visibility of the offices one to hide, this is so the query gets
called. In the offices data set methods I override the onFetch method to
set my global variable to
test = row["OFFICECODE"];
Then in the second table I set the header value to the global variable test.
There are probally better ways to do this, but here it is.
Jason Weathersby
BIRT PMC
news:dfa1r3$9vi$1@news.eclipse.org...
> from
> Thank you.
>> Marko,
> POJO
>> Jason Weathersby
>> BIRT PMC
> For
>> > number
>> > of
> to
>> > render
>> > can
>> > be used per table?
> to
> widget.
Re: Any way of referencing multiple datasets from a report object? [message #71772 is a reply to message #71560] Fri, 02 September 2005 17:31 Go to previous message
Thanks for the workaround Jason.
But it sure feels like a very awkward solution? I will make an enhancement
request that data aware widgets be able to configure their dataset,
regardless if they are a child of another data widget. I'm still unclear if
there is a technical reason why this is not the case.
Also, it would be nice if you script could have created the dataset without
the need of for hidden tables. I wonder if there is a technical reason why
that is not possible?
Thanks again Jason.
Marko.
news:dfa7nr$hqi$1@news.eclipse.org...
> Marko,
test.
> Jason Weathersby
> BIRT PMC
> > from
> > Thank you.
> >> Marko,
> > POJO
> >> Jason Weathersby
> >> BIRT PMC
> > For
> >> > number
> >> > of
needs
> > to
> >> > render
dataset
> >> > can
> >> > be used per table?
resort
> > to
> > widget.
Previous Topic:An OutOfMemory error
Next Topic:BIRT Stats
Current Time: Wed Jul 23 08:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.15158 seconds
