Home » Archived » M2M (model-to-model transformation) » [ATL] How to call a called rule.
[ATL] How to call a called rule. [message #70844] |
Tue, 08 January 2008 11:10  |
I tried to call a called rule without entrypoint marked in the
imperative section, but error always occurred. Actually, I don't know syntax
about how to call a called rule. If you have idea about that, please inform
me. Strangely, in the ALT Manual, there is no such syntax. I hope the author
can add it later on. Thanks.
Michael.
Re: [ATL] How to call a called rule. [message #70864 is a reply to message #70844] |
Tue, 08 January 2008 11:15   |
Originally posted by: mikael.barbero.gmail.com
Can you give us an excerpt of your transformation? Especially your
called rule and where you tried to call it. Also, what kind of error do
you have?
Mikael
Michael wrote:
> Michael.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] How to call a called rule. [message #70904 is a reply to message #70884] |
Tue, 08 January 2008 11:41   |
You should prefix the call by "thisModule.":
thisModule.NewName(ap.name)
Hope this helps.
Mikael
Michael wrote:
> here is the excerpt:
> module A2B; -- Module Template
> create bperson : B from aperson : A;
> rule APerson2BPerson {
> from
> ap:A!APerson
> to
> bp:B!BPerson(
> do{
> NewName(ap.name); -- call the rule.
> rule NewName(name:String){ -- a called rule
> to
> bn:B!BName(
> value<-name
> Thanks.
> Michael.
> "Mikaël Barbero" <mikael.barbero@gmail.com> wrote in message
> news:fm07je$aq4$1@build.eclipse.org...
>> Can you give us an excerpt of your transformation? Especially your called
>> rule and where you tried to call it. Also, what kind of error do you have?
>> Regards,
>> Mikael
>> Michael wrote:
>>> Hi,
>>> syntax about how to call a called rule. If you have idea about that,
>>> please inform me. Strangely, in the ALT Manual, there is no such syntax.
>>> I hope the author can add it later on. Thanks.
>>> Michael.
Re: [ATL] How to call a called rule. [message #70924 is a reply to message #70904] |
Tue, 08 January 2008 12:36   |
You should better call the called rule in the "to" part of your
APerson2BPerson rule:
from
ap:A!APerson
to
bp:B!BPerson(
name <- thisModule.NewName(ap.name)
but then you should better do this (and do not use called rules):
from
ap:A!APerson
to
bp:B!BPerson(
name <- bpname
bpname : B!BName (
name <- ap.name
Mikael
On Jan 8, 2008 5:59 PM, Yang, Mikai <my25@hw.ac.uk> wrote:
> Thanks for your help. I have solved the problem .Now the
following rules work, however, I come up with another problems. In the
imperative section, I call the called rules to assign the newly
generated 'Name' to reference of source element. And I looked into the
generated .xmi file. The name is successfully generated, but, there is
no relationship between the two generated model element. I don't know
why. Do you have any idea about this?
> Bye the way, the source metamodel is simple: APerson with an
attribute 'name' . The target metamodel is also simple, BPerson with a
one-way reference to Bname, which has an attribute 'value' .
> The generated .xmi file is as follows:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <xmi:XMI xmi:version="2.0"
xmlns:TargetModel="http://www.macs.hw.ac.uk/my25">
> <TargetModel:BPerson/>
> <TargetModel:BName value="Michael"/>
> </xmi:XMI>
> Thank you again.
> Michael.
> from
> ap:A!APerson
> to
> bp:B!BPerson(
> do{
> bp.name <- thisModule.NewName(ap.name);
> rule NewName(n:String){ -- a called rule
> to
> bn:B!BName(
> value<-n
> Hope this helps.
> Mikael
> Michael wrote:
>> from
>> ap:A!APerson
>> to
>> bp:B!BPerson(
>> do{
>> to
>> bn:B!BName(
>> value<-name
>> Thanks.
>> Michael.
>>> Hi,
>>> do you have?
>>> Regards,
>>> Mikael
>>> Michael wrote:
>>>> Hi,
>>>> know syntax about how to call a called rule. If you have idea about
>>>> that, please inform me. Strangely, in the ALT Manual, there is no
>>>> such syntax. I hope the author can add it later on. Thanks.
>>>> Michael.
Re: [ATL] How to call a called rule. [message #70963 is a reply to message #70944] |
Wed, 09 January 2008 05:06   |
I don't think I understand your problem very well. Do you mean that the
xmlns:TargetModel="http://www.macs.hw.ac.uk/my25" is not defined
automatically in the output of the transformation and that you have set
it by hand? Can you paste here what you have as an output and what you
expected? Thanks.
Mikael
Michael wrote:
> Thank you very much. The problem is gone. I got the following output.
> However, the generated file has specified the metamodel location. And each
> time I have to manually add the metamodel location. It is not convenient. Do
> you know how to automatically generate the metamodel location?
> <xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> <TargetModel:BPerson name="/1"/>
> </xmi:XMI>
> Thanks.
> Best regards.
> Michael.
> news:fm0cb7$19t$1@build.eclipse.org...
>> from
>> ap:A!APerson
>> to
>> bp:B!BPerson(
>> from
>> ap:A!APerson
>> to
>> bp:B!BPerson(
>> name <- bpname
>> bpname : B!BName (
>> name <- ap.name
>> Regards,
>> Mikael
>>> Hi,
>> imperative section, I call the called rules to assign the newly generated
>> 'Name' to reference of source element. And I looked into the generated
>> .xmi file. The name is successfully generated, but, there is no
>> relationship between the two generated model element. I don't know why. Do
>>> </xmi:XMI>
>>> Thank you again.
>>> Michael.
>>> from
>>> ap:A!APerson
>>> to
>>> bp:B!BPerson(
>>> do{
>>> to
>>> bn:B!BName(
>>> value<-n
>>> Hope this helps.
>>> Regards,
>>> Mikael
>>> Michael wrote:
>>>> Hi,
>>>> from
>>>> ap:A!APerson
>>>> to
>>>> bp:B!BPerson(
>>>> do{
>>>> to
>>>> bn:B!BName(
>>>> value<-name
>>>> Thanks.
>>>> Michael.
>>>>> Hi,
>>>>> you have?
>>>>> Regards,
>>>>> Mikael
>>>>> Michael wrote:
>>>>>> Hi,
>>>>>> Michael.
Re: [ATL] How to call a called rule. [message #71025 is a reply to message #70963] |
Wed, 09 January 2008 06:52   |
------=_NextPart_000_0087_01C852B6.1226FE50
Content-Type: text/plain;
charset="ISO-8859-1"
Hi,=20
The output is like:=20
<?xml version=3D"1.0" encoding=3D"ISO-8859-1"?>
<xmi:XMI xmi:version=3D"2.0" =
xmlns:xmi=3D"http://www.omg.org/XMI" =
xmlns:TargetModel=3D"http://www.macs.hw.ac.uk/my25">
<TargetModel:BPerson name=3D"/1"/>
<TargetModel:BName value=3D"Michael"/>
</xmi:XMI>
I cannot use Sample Reflective Ecore Model Editor to edit this =
model because error occurs, and have to use text editor to open it. If =
I mannually modify this output to the following. See the bold words, =
then I can use the Sample Reflective Ecore Model Editor to open it. I =
put the metamodels in a different folder, say metamodels.=20
=20
xmlns:TargetModel=3D"http://www.macs.hw.ac.uk/my25" =
xsi:schemaLocation=3D"http://www.macs.hw.ac.uk/my25 =
.../metamodels/B.ecore" >
</xmi:XMI>
Thanks.=20
Michael.=20
=20
"Mika=EBl Barbero" <mikael.barbero@gmail.com> wrote in message =
news:fm26bb$up2$1@build.eclipse.org...
>I don't think I understand your problem very well. Do you mean that the =
> xmlns:TargetModel=3D"http://www.macs.hw.ac.uk/my25" is not defined=20
> automatically in the output of the transformation and that you have =
set=20
> it by hand? Can you paste here what you have as an output and what you =
> expected? Thanks.
>=20
> Mikael
>=20
> Michael wrote:
>> Thank you very much. The problem is gone. I got the following output. =
>> However, the generated file has specified the metamodel location. And =
each=20
>> time I have to manually add the metamodel location. It is not =
convenient. Do=20
>>=20
>> <xmi:XMI xmi:version=3D"2.0" xmlns:xmi=3D"http://www.omg.org/XMI" =
>> </xmi:XMI>
>> Thanks.
>> Best regards.
>> Michael.
>>=20
>> "Mika=EBl Barbero" <mikael.barbero@gmail.com> wrote in message=20
>>> You should better call the called rule in the "to" part of your=20
>>> from
>>> ap:A!APerson
>>> to
>>> bp:B!BPerson(
>>> from
>>> ap:A!APerson
>>> to
>>> bp:B!BPerson(
>>> name <- bpname
>>> bpname : B!BName (
>>> name <- ap.name
>>> Regards,
>>> Mikael
>>>> Hi,
>>> following rules work, however, I come up with another problems. In =
the=20
>>> imperative section, I call the called rules to assign the newly =
generated=20
>>> 'Name' to reference of source element. And I looked into the =
generated=20
>>> .xmi file. The name is successfully generated, but, there is no=20
>>> relationship between the two generated model element. I don't know =
why. Do=20
>>> attribute 'name' . The target metamodel is also simple, BPerson with =
a=20
>>> xmlns:xmi=3D"http://www.omg.org/XMI"=20
>>>> </xmi:XMI>
>>>> Thank you again.
>>>> Michael.
>>>> from
>>>> ap:A!APerson
>>>> to
>>>> bp:B!BPerson(
>>>> do{
>>>> to
>>>> bn:B!BName(
>>>> value<-n
>>>> Hope this helps.
>>>> Regards,
>>>> Mikael
>>>> Michael wrote:
>>>>> Hi,
>>>>> from
>>>>> ap:A!APerson
>>>>> to
>>>>> bp:B!BPerson(
>>>>> do{
>>>>> to
>>>>> bn:B!BName(
>>>>> value<-name
>>>>> Thanks.
>>>>> Michael.
>>>>>> Hi,
>>>>>> Can you give us an excerpt of your transformation? Especially =
your=20
>>>>>> called rule and where you tried to call it. Also, what kind of =
error do=20
>>>>>> you have?
>>>>>> Regards,
>>>>>> Mikael
>>>>>> Michael wrote:
>>>>>>> Hi,
>>>>>>> I tried to call a called rule without entrypoint marked in =
the=20
>>>>>>> imperative section, but error always occurred. Actually, I don't =
know=20
>>>>>>> syntax about how to call a called rule. If you have idea about =
that,=20
>>>>>>> please inform me. Strangely, in the ALT Manual, there is no such =
>>>>>>> Michael.
>>>>>> --=20
>>>>>> Mika=EBl Barbero - PhD Candidate
>>>>>> 2, rue de la Houssini=E8re
>>> --=20
>>> http://www.sciences.univ-nantes.fr/lina/atl/=20
>>=20
>>=20
>=20
>=20
>=20
> --=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.3243" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi, </FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2> =20
The output is like: </FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2> &nbs=
p; &nbs p; =20
<?xml version=3D"1.0"=20
encoding=3D"ISO-8859-1"?><BR>  =
=20
<xmi:XMI xmi:version=3D"2.0" xmlns:xmi=3D"</FONT><A=20
href=3D"http://www.omg.org/XMI"><FONT face=3DArial=20
size=3D2>http://www.omg.org/XMI</FONT></A><FONT face=3DArial size=3D2>"=20
xmlns:TargetModel=3D"</FONT><A =
href=3D"http://www.macs.hw.ac.uk/my25"><FONT=20
face=3DArial size=3D2>http://www.macs.hw.ac.uk/my25</FONT></A><FONT =
face=3DArial=20
size=3D2>"><BR> &=
nbsp; & nbsp; =20
<TargetModel:BPerson=20
name=3D"/1"/><BR>  =
;   ; =20
<TargetModel:BName=20
value=3D"Michael"/><BR>  =
;   ; =20
</xmi:XMI></FONT></DIV>
<DIV><FONT face=3DArial size=3D2> I =
cannot use=20
Sample Reflective Ecore Model Editor to edit this model because error =
occurs,=20
and have to use text editor to open it. If I mannually modify this =
output=20
to the following. See the bold words, then I can use the =
Sample=20
Reflective Ecore Model Editor to open it. I put the =
metamodels=20
in a different folder, say metamodels. </FONT></DIV>
size=3D2> </FONT><FONT=20
face=3DArial size=3D2> </FONT></DIV>
size=3D2> &nbs=
p; &nbs p;=20
;   ; =20
face=3DArial=20
size=3D2>" <STRONG>xsi:schemaLocation=3D"</STRONG ></FONT><A=20
href=3D"http://www.macs.hw.ac.uk/my25"><FONT face=3DArial=20
size=3D2><STRONG>http://www.macs.hw.ac.uk/my25</STRONG></FONT></A><FONT =
face=3DArial=20
size=3D2><STRONG> ../metamodels/B.ecore"</STRONG> ><BR> =20
<TargetModel:BPerson name=3D"/1"/><BR> <TargetModel:BName =
value=3D"Michael"/><BR></xmi:XMI></FONT ></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2> Thanks.=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Michael. </DIV>
<DIV><BR></DIV></FONT>
size=3D2> &nbs=
p; &nbs p; </FONT></DI=
V>
<DIV><FONT face=3DArial size=3D2>"Mika=EBl Barbero" <</FONT><A=20
href=3D"mailto:mikael.barbero@gmail.com"><FONT face=3DArial=20
size=3D2>mikael.barbero@gmail.com</FONT></A><FONT face=3DArial =
size=3D2>> wrote in=20
message </FONT><A href=3D"news:fm26bb$up2$1@build.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:fm26bb$up2$1@build.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>>I don't think I =
understand=20
your problem very well. Do you mean that the <BR>>=20
face=3DArial=20
size=3D2>" is not defined <BR>> automatically in the output of the=20
transformation and that you have set <BR>> it by hand? Can you paste =
here=20
what you have as an output and what you <BR>> expected? =
Thanks.<BR>>=20
<BR>> Mikael<BR>> <BR>> Michael wrote:<BR>>> Thank you =
very much.=20
The problem is gone. I got the following output. <BR>>> However, =
the=20
generated file has specified the metamodel location. And each =
<BR>>> time=20
I have to manually add the metamodel location. It is not convenient. Do=20
<BR>>> you know how to automatically generate the metamodel=20
location?<BR>>> <BR> >> & ;nbsp; =
<?xml=20
version=3D"1.0" =
encoding=3D"ISO-8859-1"?><BR>>> =20
size=3D2>http://www.omg.org/XMI</FONT></A><FONT face=3DArial size=3D2>" =
<BR>>>=20
face=3DArial=20
size=3D2>"><BR> >> & ;nbsp; =20
name=3D"/1"/><BR> >> & ;nbsp; =20
value=3D"Michael"/><BR>>> =20
</xmi:XMI><BR>>> Thanks.<BR>>> Best =
regards.<BR>>>=20
Michael.<BR>>> <BR>>> "Mika=EBl Barbero" <</FONT><A=20
message <BR>>> </FONT><A =
href=3D"news:fm0cb7$19t$1@build.eclipse.org"><FONT=20
face=3DArial =
size=3D2>news:fm0cb7$19t$1@build.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...<BR>>>> You should better call the called rule in =
the "to"=20
part of your <BR>>>> APerson2BPerson=20
rule:<BR>>>><BR>>>> rule APerson2BPerson=20
{<BR> >>> &n bsp; =20
from<BR> >>> &n bsp;  =
; =20
ap:A!APerson<BR> >>> &n bsp; =20
to<BR> >>> &n bsp; &=
nbsp;=20
bp:B!BPerson(<BR> >>> &n bsp; &n=
bsp; =20
name <-=20
thisModule.NewName(ap.name)<BR> >>> &n bsp; =
=20
)<BR>>>> }<BR>>>><BR>>>> but then you should =
better=20
do this (and do not use called rules):<BR>>>><BR>>>> =
rule=20
APerson2BPerson =
; =20
nbsp;=20
bsp; =20
name <-=20
bpname<BR> >>> &n bsp; &nb=
sp;=20
),<BR> >>> &n bsp; =
bpname=20
: B!BName=20
(<BR> >>> &n bsp; &n =
bsp; =20
name <-=20
ap.name<BR> >>> &n bsp; &n=
bsp;=20
)<BR>>>> }<BR>>>><BR>>>> =
Regards,<BR>>>>=20
Mikael<BR>>>><BR>>>> On Jan 8, 2008 5:59 PM, Yang, =
Mikai=20
<</FONT><A href=3D"mailto:my25@hw.ac.uk"><FONT face=3DArial=20
size=3D2>my25@hw.ac.uk</FONT></A><FONT face=3DArial size=3D2>>=20
wrote:<BR>>>>>=20
Hi,<BR> >>>> &nbs p; Thanks for =
your=20
help. I have solved the problem .Now the<BR>>>> following rules =
work,=20
however, I come up with another problems. In the <BR>>>>=20
generated=20
<BR>>>> 'Name' to reference of source element. And I looked =
into the=20
generated <BR>>>> .xmi file. The name is successfully =
generated, but,=20
there is no <BR>>>> relationship between the two generated =
model=20
element. I don't know why. Do <BR>>>> you have any idea about=20
this?<BR> >>>> &nbs p; Bye the way, the =
source=20
metamodel is simple: APerson with an<BR>>>> attribute 'name' . =
The=20
target metamodel is also simple, BPerson with a <BR>>>> one-way =
reference to Bname, which has an attribute 'value'=20
..<BR> >>>> &nbs p; The generated .xmi =
file is=20
as=20
follows:<BR> >>>> &nbs p; &nb=
sp; =20
encoding=3D"ISO-8859-1"?><BR> >>>> &nbs p; &=
nbsp; & nbsp; & n=
bsp;=20
<xmi:XMI xmi:version=3D"2.0"<BR>>>> xmlns:xmi=3D"</FONT><A=20
<BR>>>> xmlns:TargetModel=3D"</FONT><A=20
size=3D2>http://www.macs.hw.ac.uk/my25</FONT></A><FONT face=3DArial=20
size=3D2>"><BR> >>>> &nbs p; &nb=
sp; &nb sp; =20
<TargetModel:BPerson/><BR> >>>> &nbs p; &=
nbsp; & nbsp; =20
value=3D"Michael"/><BR> >>>> &nbs p; &=
nbsp; =20
</xmi:XMI><BR> >>>> &nbs p; Thank =
you=20
again.<BR>>>>>=20
Michael.<BR>>>>><BR>>>>> <BR>>>>> =
module A2B;=20
-- Module Template<BR>>>>> create bperson : B from aperson : =
A;<BR>>>>><BR>>>>> rule APerson2BPerson=20
{<BR> >>>> &nbs p; =20
from<BR> >>>> &nbs p; &=
nbsp; =20
ap:A!APerson<BR>>>>><BR> >>>> &nbs p;&nb=
sp; =20
to<BR> >>>> &nbs p; &nb=
sp; =20
bp:B!BPerson(<BR>>>>><BR> >>>> &nbs p;&n=
bsp; &n bsp;=20
)<BR> >>>> &nbs p; =20
do{<BR> >>>> &nbs p; =
bp.name=20
<-=20
thisModule.NewName(ap.name);<BR> >>>> &nbs p; &=
nbsp;=20
}<BR>>>>><BR>>>>>=20
}<BR>>>>><BR>>>>> rule =
NewName(n:String){ --=20
a called=20
rule<BR> >>>> &nbs p; =
sp; =20
bn:B!BName(<BR> >>>> &nbs p; =
=20
value<-n<BR> >>>> &nbs p; =
=20
)<BR>>>>> }<BR>>>> Mika=EBl Barbero=20
wrote:<BR>>>>> You should prefix the call by=20
"thisModule.":<BR>>>>>=20
thisModule.NewName(ap.name)<BR>>>>> <BR>>>>> Hope =
this=20
helps.<BR>>>>><BR>>>>> =
Regards,<BR>>>>>=20
Mikael<BR>>>>><BR>>>>> Michael=20
wrote:<BR>>>>>>=20
Hi,<BR> >>>>> here is the=20
excerpt:<BR>>>>>><BR>>>>>>=20
------------------------------------------------<BR>>>>>>&=
nbsp; & nbsp; =20
module A2B; -- Module Template<BR>>>>>> create bperson : =
B from=20
aperson : A;<BR>>>>>><BR>>>>>> rule=20
APerson2BPerson {<BR>>>>>> =20
from<BR> >>>>> =20
ap:A!APerson<BR>>>>>> =20
to<BR> >>>>> =20
bp:B!BPerson(<BR>>>>>><BR > >>>>> =
=20
)<BR> >>>>> =20
do{<BR> >>>>> =20
NewName(ap.name); -- call the=20
rule.<BR> >>>>> =
}<BR>>>>>>=20
}<BR>>>>>><BR>>>>>> rule=20
NewName(name:String){ -- a called =
rule<BR>>>>>> =20
to<BR> >>>>> =20
bn:B!BName(<BR> >>>>> =20
value<-name<BR> >>>>> =20
)<BR>>>>>> }<BR>>>>>>=20
----------------------------------------------<BR>>>>>>&nb=
sp;=20
Thanks.<BR>>>>>><BR>>>>>>=20
Michael.<BR>>>>>><BR>>>>>> <BR>>>>&=
gt;><BR>>>>>><BR >>>>>><BR>>>>&g=
t;><BR>>>>>><BR >>>>>><BR>>>>>=
;>=20
"Mika=EBl Barbero" <</FONT><A =
href=3D"mailto:mikael.barbero@gmail.com"><FONT=20
face=3DArial size=3D2>mikael.barbero@gmail.com</FONT></A><FONT =
face=3DArial=20
size=3D2>> wrote in message <BR>>>>>> </FONT><A=20
href=3D"news:fm07je$aq4$1@build.eclipse.org"><FONT face=3DArial=20
size=3D2>news:fm07je$aq4$1@build.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...<BR>>>>>>>=20
Hi,<BR>>>>>>><BR >>>>>>> Can you give =
us an=20
excerpt of your transformation? Especially your =
<BR>>>>>>>=20
called rule and where you tried to call it. Also, what kind of error do=20
<BR>>>>>>> you=20
have?<BR>>>>>>><BR >>>>>>>=20
Regards,<BR>>>>>>>=20
Mikael<BR>>>>>>> <BR>>>>>>> Michael=20
wrote:<BR>>>>>>>>=20
Hi,<BR> >>>>>>>& ;nbsp; I tried to =
call a=20
called rule without entrypoint marked in the =
<BR>>>>>>>>=20
imperative section, but error always occurred. Actually, I don't know=20
<BR>>>>>>>> syntax about how to call a called rule. =
If you=20
have idea about that, <BR>>>>>>>> please inform me. =
<BR>>>>>>>>=20
syntax. I hope the author can add it later on.=20
Thanks.<BR>>>>>>>>=20
Michael.<BR>>>>>>> <BR>>>>>>> --=20
<BR>>>>>>> Mika=EBl Barbero - PhD=20
Candidate<BR>>>>>>> ATLAS Group (INRIA & LINA) -=20
University of Nantes<BR>>>>>>> 2, rue de la=20
Houssini=E8re<BR>>>>>>> 44322 Nantes Cedex 3 -=20
France<BR>>>>>>> tel. +33 2 51 12 58 08 /\ cell.+33 6 =
07 63 19=20
00<BR>>>>>>> email: </FONT><A=20
href=3D"mailto:Mikael.Barbero@{gmail.com"><FONT face=3DArial=20
size=3D2>Mikael.Barbero@{gmail.com</FONT></A><FONT face=3DArial =
size=3D2>,=20
univ-nantes.fr}<BR>>>>>>> </FONT><A=20
href=3D"http://www.sciences.univ-nantes.fr/lina/atl/"><FONT face=3DArial =
size=3D2>http://www.sciences.univ-nantes.fr/lina/atl/</FONT></A><BR><FONT=
=20
face=3DArial=20
size=3D2>>>>>><BR>>>>> <BR>>>>><BR>=
>>><BR>>>><BR>>>>=20
-- <BR>>>> Mika=EBl Barbero - PhD Candidate<BR>>>> =
ATLAS Group=20
(INRIA & LINA) - University of Nantes<BR>>>> 2, rue de la=20
Houssini=E8re<BR>>>> 44322 Nantes Cedex 3 - =
France<BR>>>> tel.=20
+33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00<BR>>>> email: =
</FONT><A=20
size=3D2>,=20
univ-nantes.fr}<BR>>>> </FONT><A=20
size=3D2>http://www.sciences.univ-nantes.fr/lina/atl/</FONT></A><FONT =
face=3DArial=20
size=3D2> <BR>>> <BR>>> <BR>> <BR>> <BR>> <BR>> =
--=20
<BR>> Mika=EBl Barbero - PhD Candidate<BR>> ATLAS Group (INRIA =
& LINA) -=20
University of Nantes<BR>> 2, rue de la Houssini=E8re<BR>> 44322 =
Nantes Cedex=20
3 - France<BR>> tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 =
00<BR>>=20
email: </FONT><A href=3D"mailto:Mikael.Barbero@{gmail.com"><FONT =
face=3DArial=20
size=3D2>,=20
univ-nantes.fr}<BR>> </FONT><A=20
size=3D2>http://www.sciences.univ-nantes.fr/lina/atl/</FONT></A></BODY></=
HTML>
------=_NextPart_000_0087_01C852B6.1226FE50--
Re: [ATL] How to call a called rule. [message #71047 is a reply to message #71025] |
Wed, 09 January 2008 07:21  |
The schemaLocation is an option to pass to the save() method of a
resource and ATL does not specify it by default. You should add it
manually as you do or modify some source code of ATL.
Another solution is to register your metamodel in the EMF registry.
There is an contextual action that is provided by the AM3 project
(http://www.eclipse.org/gmt/am3/). You can right click on a .ecore file
and select "Register metamodel". Then you will be able to use the ecore
reflective editor to edit your model. Don't forget to re-register your
metamodel each time you modify it.
Hope this helps.
Mikael
Michael wrote:
> The output is like:
> </xmi:XMI>
> xmlns:TargetModel="http://www.macs.hw.ac.uk/my25" *xsi:schemaLocation="**http://www.macs.hw.ac.uk/my25**
> ../metamodels/B.ecore"* >
> </xmi:XMI>
> Thanks.
> Michael.
> <mailto:mikael.barbero@gmail.com>> wrote in message
> > expected? Thanks.
> > Mikael
> And each
> convenient. Do
> >> </xmi:XMI>
> >> Thanks.
> >> Best regards.
> >> Michael.
> >>> from
> >>> ap:A!APerson
> >>> to
> >>> bp:B!BPerson(
> >>> from
> >>> ap:A!APerson
> >>> to
> >>> bp:B!BPerson(
> >>> name <- bpname
> >>> bpname : B!BName (
> >>> name <- ap.name
> >>> Regards,
> >>> Mikael
> <mailto:my25@hw.ac.uk>> wrote:
> >>>> Hi,
> the
> generated
> why. Do
> >>>> </xmi:XMI>
> >>>> Thank you again.
> >>>> Michael.
> >>>> from
> >>>> ap:A!APerson
> >>>> to
> >>>> bp:B!BPerson(
> >>>> do{
> >>>> to
> >>>> bn:B!BName(
> >>>> value<-n
> >>>> Hope this helps.
> >>>> Regards,
> >>>> Mikael
> >>>> Michael wrote:
> >>>>> Hi,
> >>>>> from
> >>>>> ap:A!APerson
> >>>>> to
> >>>>> bp:B!BPerson(
> >>>>> do{
> >>>>> to
> >>>>> bn:B!BName(
> >>>>> value<-name
> >>>>> Thanks.
> >>>>> Michael.
> >>>>>> Hi,
> error do
> >>>>>> you have?
> >>>>>> Regards,
> >>>>>> Mikael
> >>>>>> Michael wrote:
> >>>>>>> Hi,
> don't know
> that,
> >>>>>>> Michael.
> <mailto:Mikael.Barbero@{gmail.com>, univ-nantes.fr}
> > email: Mikael.Barbero@{gmail.com <mailto:Mikael.Barbero@{gmail.com>,
> univ-nantes.fr}
Current Time: Thu Jul 17 16:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.11783 seconds
