Can't make VE working [message #70804] |
Tue, 09 November 2004 12:22  |
Hi all!
I installed VE but it does't work as expected.
It is OK to select that I want to create a new Visual Class. I select
e.g. Swing>Frame and I press Finish. A new class is generated but I
can't see anything in the top window (visual editor). I cant see any
panel with widgets to drag and drop onto the application.
I can see the JavaBeans view in the left bottom corner but nothing there
and I also can't see Properties view.
Can anybody help me?
I tried to reinstall eclipse (3.0.1) then EMF-XDO-XSD SDK-2.0.1,
GEF-3.0.1 SDK e VE runtime 1.0.1.1 but it did not help.
I have JDK 5.0, Win XP Pro
Below is the content of workspace/.metadata/.log
Wenca
!SESSION XI 09, 2004 18:11:48.687
eclipse.buildId=M200409161125
java.version=1.5.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
!ENTRY org.eclipse.core.runtime 4 2 XI 09, 2004 18:11:48.687
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl$NamespaceSuppor t.declarePrefix(XMLHelperImpl.java:1023)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.addPrefix(XMLHe lperImpl.java:903)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startPrefixMapping (XMLHandler.java:851)
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startPrefixMapping (SAXWrapper.java:64)
at com.icl.saxon.aelfred.SAXDriver.attribute(SAXDriver.java:687 )
at com.icl.saxon.aelfred.XmlParser.parseAttribute(XmlParser.jav a:1090)
at com.icl.saxon.aelfred.XmlParser.parseElement(XmlParser.java: 1005)
at com.icl.saxon.aelfred.XmlParser.parseDocument(XmlParser.java :510)
at com.icl.saxon.aelfred.XmlParser.doParse(XmlParser.java:163)
at com.icl.saxon.aelfred.SAXDriver.parse(SAXDriver.java:320)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:129)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:155)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:884)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.de mandLoad(ProjectResourceSetImpl.java:69)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.ge tResource(ProjectResourceSetImpl.java:229)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$DefaultVEContributor.contributePalleteCats(JavaVisu alEditorPart.java:927)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$5.run(JavaVisualEditorPart.java:1307)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$CreateRegistry.run(JavaVisualEditorPart.java: 1298)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:48.737
!MESSAGE Error loading
file"platform:/plugin/org.eclipse.ve.jfc/overrides/javax/swing/ "
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter$1.run(BeaninfoClassAdapter.java:532)
org.eclipse.jem.internal.beaninfo.core.BeaninfoPlugin.applyO verrides(BeaninfoPlugin.java:493)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocTo(BeaninfoClassAdapter.java:523)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:519)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:437)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:394)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectProperties(BeaninfoClassAdapter.java:666)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEStructuralFeatures(BeaninfoClassAdapter.java:588)
org.eclipse.jem.java.impl.JavaClassImpl.getEStructuralFeatur es(JavaClassImpl.java:346)
org.eclipse.jem.java.impl.JavaClassImpl.getProperties(JavaCl assImpl.java:1243)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:751)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllProperties(BeaninfoClassAdapter.java:596)
org.eclipse.jem.java.impl.JavaClassImpl.getAllProperties(Jav aClassImpl.java:1284)
org.eclipse.ve.internal.java.codegen.java.rules.ThisReferenc eRule.useInheritance(ThisReferenceRule.java:115)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.create ThisIfNecessary(TypeVisitor.java:113)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:162)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:406)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:372)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:877)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.88
file"platform:/plugin/org.eclipse.ve.jfc/overrides/java/awt/ "
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:756)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.118
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.148
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.178
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.258
!MESSAGE Error loading file"platform:/plugin/org.eclipse.jem/overrides/"
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:513)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.268
file"platform:/plugin/org.eclipse.ve.java.core/overrides/"
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.288
file"platform:/plugin/org.eclipse.jem/overrides/java/lang/"
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.298
file" platform:/plugin/org.eclipse.ve.java.core/overrides/java/lan g/ "
!STACK 0
!ENTRY org.eclipse.ve.java.core 4 0 XI 09, 2004 18:11:49.869
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.getExpDecoderFeature(ExpressionDecoderFactory.java:65 )
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.getExpDecoder(ExpressionDecoderFactory.java:97)
org.eclipse.ve.internal.java.codegen.model.BeanPart.setEObje ct(BeanPart.java:474)
org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.java:846)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:693)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:774)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:881)
!ENTRY org.eclipse.ve.java.core 4 0 XI 09, 2004 18:11:49.889
!STACK 0
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.ge tEObject(ProjectResourceSetImpl.java:152)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:620)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$10.run(JavaVisualEditorPart.java:1523)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Can't make VE working [message #71008 is a reply to message #70846] |
Wed, 10 November 2004 03:39  |
Yeah! Great, that's it! Thanks
Wenca
Jeff Myers wrote:
> Wenca wrote:
>> Hi all!
>> there and I also can't see Properties view.
>> Thanks
>> Wenca
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
> <snip>
> Hi Wenca,
> It looks like your Java installation is using some strange XML parser
> that is not the standard one included with Java and it's failing to
> parse some XML files properly. Does com.icl.saxon.aelfred.SAXDriver
> sound familiar? You may have installed an xml processing library into
> the lib\ext directory of your Java installation.
> - Jeff
Re: Can't make VE working [message #602867 is a reply to message #70804] |
Tue, 09 November 2004 12:43  |
Wenca wrote:
> Hi all!
> Thanks
> Wenca
> java.version=1.5.0
> !STACK 0
> at
> at
> at
> at
> at
<snip>
Hi Wenca,
- Jeff
Re: Can't make VE working [message #602907 is a reply to message #70846] |
Wenca
Jeff Myers wrote:
> Wenca wrote:
>> Hi all!
>> Thanks
>> Wenca
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
> <snip>
> Hi Wenca,
> - Jeff
FUDForum. Page generated in 0.26898 seconds
