Home » Modeling » GMF (Graphical Modeling Framework) » How to create a rectangle-with-dog-ear figure? Gallery anywhere?
How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #70713] Fri, 27 October 2006 07:41 Go to next message
What's an elegant way to create a figure like the ones used for notes
(the sheet with a dog-ear, i.e. a triangle bent down in the upper
right)? Is there a gallery or resource that one can import for that?
With "elegant" I also mean, that the figure should nicely resize,
provide a reflowing label, etc. etc,
I didn't find any such figure in the standard galleries
(platform:/plugin/org.eclipse.gmf.graphdef/models/basic.gmfg raph,
platform:/plugin/org.eclipse.gmf.graphdef/models/classDiagra m.gmfgraph,
platform:/plugin/org.eclipse.gmf.graphdef/models/stateDiagra m.gmfgraph),
but apparently it's around somewhere, since the created diagram plugins
all provide a "Note" palette entry.
Michael
Re: How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #70898 is a reply to message #70713] Fri, 27 October 2006 10:41 Go to previous messageGo to next message
The figure used by notes is called NoteFigure it is public in the
plugin org.eclipse.gmf.runtime.diagram.ui. You can use it or subclass it
to do any customizations you need
The way to use change the figure created by the edit part is to change
the code in the your edit part's createFigure() method to create
NoteFigure or a sub class of it
> Michael
Re: How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #71104 is a reply to message #70898] Fri, 27 October 2006 16:58 Go to previous messageGo to next message
For the benefit of others: the class is in package "figures" of said
plugin, i.e.:
org.eclipse.gmf.runtime.diagram.ui.figures.NoteFigure
My next question: the constructor of that figure requires additional
parameters, it is defined as:
public NoteFigure(int width, int height, Insets insets) { ... }
Without these parameters the code generated does not compile. How does
one define such parameters???
Or is the onl;y way to define a derived class that hard-codes these
parameters, i.e. something like
public MySpecialNoteFigure() extends NoteFigure {
super(50, 70, null);
Michael
"Mohammed Mostafa" <mmostafa@ca.ibm.com> wrote in message
news:eht5tn$m3t$1@utils.eclipse.org...
> it to do any customizations you need
Re: How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #71381 is a reply to message #70898] Sun, 29 October 2006 10:57 Go to previous messageGo to next message
This NoteFigure has a life of its own! I have created a sub-class of
NoteFigure:
public MyNotesFigure extends NoteFigure {
super(50, 75, new Insets(5,5,5,5));
but for some strange reason NoteFigure ignores the width and height
parameters that I pass into the super-constructor. The figure is always
displayed with a size of (I would estimate) 100x100. It also seems to
ignore child items! I added a label to it and this label is not
displayed.
So, this internal figure seems not very useful for derivation of custom
figures. Or has anybody else managed to extend this class properly?
Michael
Re: How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #71571 is a reply to message #71104] Mon, 30 October 2006 09:46 Go to previous messageGo to next message
If you check the java doc of the note figure constructor you will find
that the extra parameter is :
* @param insets <code>Insets</code> that is the empty margin inside the
note figure in logical units
you should not pass null, you pass whatever value suitable in your case
and keep in mind it is in logical coordinates (if you do not use Map
mode then forget about logical and physical modes they both are the same)
> plugin, i.e.:
> Michael
Re: How to create a rectangle-with-dog-ear figure? Gallery anywhere? [message #71590 is a reply to message #71381] Mon, 30 October 2006 09:55 Go to previous message
I've tried a very simple case with the generated code where i use the
note figure instead of the generated figure , and noticed that width and
height works as i expect. It respect the value i pass (as long as I just
drop the shape on the diagram surface, otherwise it will use the exact
rectangle i draw on the diagram surface)
this is the way i create my figure :
* @generated Not
protected IFigure createNodeShape() {
Insets insets = new Insets(getMapMode().DPtoLP(30),
getMapMode().DPtoLP(30), getMapMode().DPtoLP(30), getMapMode().DPtoLP(45));
primaryShape = new MyFigure(getMapMode().DPtoLP(300),
getMapMode().DPtoLP(400), insets);
return primaryShape;
i have not tried to add labels though ; (I'll try it when i have free time)
> NoteFigure:
> ignore child items! I added a label to it and this label is not displayed.
> Michael
Previous Topic:Re: Ecore diagram bugs with Linux Kubuntu Edgy
Next Topic:changing connection color programtically
Current Time: Wed Jul 16 02:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.04637 seconds
