Teneo and java.util.Calendar [message #70709] |
Wed, 07 February 2007 02:54  |
Originally posted by: pascal.pugatsch.inventage.com
I have attributes of "java.util.Calendar" in the model.
So far Teneo generates the mapping "timestamp" for that type by default. I
would though prefer using hibernates "calendar" or "calendar_date" as
target mapping. Is there a way to define this in the model similar to the
annotation @temporal but in the context of calendar (sql type in my db is
"datetime")?
Thanks for any suggestions.
Cheers, Pascal
Re: Teneo and java.util.Calendar [message #602278 is a reply to message #70709] |
Wed, 07 February 2007 03:24  |
Hi Pascal,
You can use the @Type(type="calendar") annotation (=hibernate specific) on the eattribute. This
annotation can also be set on the EDataType (more practical if all the calendar eattributes use the
same EDataType).
There will also be an option to set the default temporal mapping globally. If you like that feature
then please enter a bugzilla so that I will pick it up quicker.
gr. Martin
Pascal Pugatsch wrote:
> I have attributes of "java.util.Calendar" in the model. So far Teneo
> generates the mapping "timestamp" for that type by default. I would
> though prefer using hibernates "calendar" or "calendar_date" as target
> is "datetime")?
> Cheers, Pascal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.47649 seconds
