Home » Eclipse Projects » Eclipse Platform » I have tried but can't get hold of ISourceViewer()
I have tried but can't get hold of ISourceViewer() [message #540] Mon, 21 April 2003 00:25 Go to next message
HI all,
I am using the following method to make the viewer uneditable,but I always
get a NULL value from viewer.But if I use the createPartControl I can get
it to work,but in my case I have to call this method with a button from
MessageDialog after the editor has been created.Is there any way I can get
it to work.
public void setEditable(boolean editable) {
ISourceViewer viewer = getSourceViewer();
if (viewer != null) {
viewer.setEditable(editable);
I get viewer as NULL,I have tried to use the same line
(ISourceViewer viewer = this.getSourceViwer();) in another code but It
also doesnot work.
While using the above method with createPartControl I can call this from
another class but I get a NullPointerException on the
super.createPartControl(composite parent).
I would really apprecaite any pointer.
Syed
Re: I have tried but can't get hold of ISourceViewer() [message #552 is a reply to message #540] Mon, 21 April 2003 04:54 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
The sourceViewer is created in createPartControl(). The value is not
available until super.createPartControl() has completed.
Bob
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:b7vrrp$nau$1@rogue.oti.com...
> HI all,
> it to work.
> also doesnot work.
> Syed
Re: I have tried but can't get hold of ISourceViewer() [message #640 is a reply to message #552] Mon, 21 April 2003 11:14 Go to previous messageGo to next message
Bob,
Alright that is what read also,but can you tell me how to get rid of the
runtime error "Argument can't be null" at line super.createPartControl
that I get after calling createPartControl from another class.I need to
get the sourceViewer for my method.Is there any other way to get this
done.
Syed
> Bob
> > HI all,
> > it to work.
> > also doesnot work.
> > Syed
Re: I have tried but can't get hold of ISourceViewer() [message #1643 is a reply to message #640] Tue, 22 April 2003 03:47 Go to previous messageGo to next message
Huh? This is in an editor plugin, right? You can't call createPartControl().
It gets called by the framework.
Bob
news:b811si$cso$1@rogue.oti.com...
> Bob,
> done.
> Thanks
> Syed
> > Bob
> > > HI all,
always
get
from
get
> > > it to work.
> > > also doesnot work.
from
> > > Syed
Is there a solution for this [message #5391 is a reply to message #1643] Tue, 22 April 2003 23:53 Go to previous messageGo to next message
Bob,
There must be a way to go around this or do something else to get the same
functionality.I would really appreciate any pointers
Syed
> Bob
> > Bob,
> > done.
> > Thanks
> > Syed
> > > Bob
> > > > HI all,
> always
> get
> from
> get
> > > > it to work.
> > > > also doesnot work.
> from
> > > > Syed
Re: Is there a solution for this [message #8851 is a reply to message #5391] Wed, 23 April 2003 20:48 Go to previous messageGo to next message
What's your hurry? The viewer isn't editable before it is created. Just set
a flag in your editor and when the part control is created, do whatever you
need to the source viewer.
Bob
news:b852ne$aop$1@rogue.oti.com...
> Bob,
> Thanks
> Syed
> > Bob
> > > Bob,
the
to
> > > done.
> > > Thanks
> > > Syed
> > > > Bob
> > > > > HI all,
I
> > always
can
> > get
> > from
can
> > get
> > > > > it to work.
but It
> > > > > also doesnot work.
this
> > from
> > > > > Syed
Re: Is there a solution for this [message #8957 is a reply to message #8851] Thu, 24 April 2003 01:20 Go to previous messageGo to next message
I understand what you are saying but I invoke setEditable method after the
editor is created,then according to what you are saying I should have the
viewer(I Think).
What actually happens is that I open up the editor frist then through the
Dialog I invoke this method.So if the editor has been opened up then there
should be a viewer.I tried to do the same for retriving text from the
editor and I was having the same problem then.
Or am I missing something here.
Thanks for all your help
Syed
> Bob
> > Bob,
> > Thanks
> > Syed
> > > Bob
> > > > Bob,
> the
> to
> > > > done.
> > > > Thanks
> > > > Syed
> > > > > Bob
> > > > > > HI all,
> I
> > > always
> can
> > > get
> > > from
> can
> > > get
> > > > > > it to work.
> but It
> > > > > > also doesnot work.
> this
> > > from
> > > > > > Syed
Re: Is there a solution for this [message #10323 is a reply to message #8957] Thu, 24 April 2003 10:11 Go to previous message
Notwithstanding Andrew's response, I believe the source viewer is not
available until after createPartControl() has been called. If you are trying
to get it beforehand, you can solve your problem with a hack like this:
private Boolean deferSetEditable = null;
if (viewer != null)
else
deferSetEditable = editable ? Boolean.TRUE : Boolean.FALSE;
public void createPartControl(Composite parent) {
super.createPartControl(parent);
if (deferSetEditable != null && getSourceViewer() != null) {
getSourceViewer.setEditable(deferSetEditable.booleanValue()) ;
Bob
news:b87s7n$926$1@rogue.oti.com...
> viewer(I Think).
> Syed
set
you
> > Bob
> > > Bob,
same
> > > Thanks
> > > Syed
> > > > Bob
> > > > > Bob,
of
> > the
need
> > to
this
> > > > > done.
> > > > > Thanks
> > > > > Syed
not
> > > > > > Bob
> > > > > > > HI all,
uneditable,but
> > I
> > > > always
createPartControl I
> > can
> > > > get
button
> > > > from
way I
> > can
> > > > get
> > > > > > > it to work.
code
> > but It
> > > > > > > also doesnot work.
call
> > this
> > > > from
> > > > > > > Syed
Previous Topic:Malformed file transmission
Next Topic:Does Eclipse provide a rich text widget that can display HTML?
Current Time: Thu Jul 17 12:13:09 EDT 2025
Powered by FUDForum. Page generated in 0.29404 seconds
