Home » Eclipse Projects » Equinox » The LogReaderService is not registered.
The LogReaderService is not registered. [message #70668] Tue, 25 July 2006 13:37
Originally posted by: simon.kaegi.cognos.com
[moved from Bugzilla]
teamalwayswins wrote:
I checked out the Eclipsecon06.tutorial(based on osgi Component
developement)
from the CVS Repository.And tried working with the sample
"helloworld.component.log".Its an example for how to use a simple Log
service.
As per the tutorial.if we give the command "log" in the OSGI> prompt.when
the
helloworld.component.log plug-in is running.The logging should be done.But
in
my case the following message appears.
"The LogReaderService is not registered"
How it should be resolved
Thanks in advance
I'm not familiar with that specific tutorial, but it sounds like you'll need
to install and start the Log Service bundle
( e.g. org.eclipse.equinox.log from
http://download3.eclipse.org/eclipse/equinox/drops/R-3.2-200 606291905/index.php )
-Simon
Previous Topic:SQL Editor
Next Topic:Questions on rbac (role based access control) in an RCP
Current Time: Sat Jul 26 08:29:40 EDT 2025
Powered by FUDForum. Page generated in 0.03387 seconds
