Home » Archived » Riena » event listener
event listener [message #6304] |
Fri, 25 July 2008 03:20  |
hi,
i'd like to know if there is a way for the riena server to inform client.
with some event listener on the client
in fact i'd like my clients to be informed by the server of some
modifications on my business objects
i've browsed the CVS code but don't find clue about that. i don't think
object transaction is the thing i need
TIA
David
Re: event listener [message #7576 is a reply to message #7554] |
Fri, 25 July 2008 12:11   |
hi ekke,
thanks for your answer
let me explain my scenario
the application i'm developping is a hotline call managment (with call crud
and answers)
the server is accessing a database with hibernate . i've a got some services
available (ListActivescalls, saveCall, updateCall, ...)
the client is an rcp application . it displays active calls, the user can
add new ones, close call, etc)
of course there are more than one client, entering calls, closing calls ,
by example if one client enter a new call, i want it to be propagated to the
other clients, and the view displaying active calls will refresh
automatically (adding the new one)
is it clearer ??
i've tried to use some JMS messaging between server and clients. but in my
opinion it is a very heavy solution
i thought riena could provide some help in this case
"ekke" <ekkehard@gentz-software.de> wrote in message
news:g6c397$igq$1@build.eclipse.org...
> david,
> using Riena's Remote OSGI services you're using your own OSGI services at
> client site. you can use your service to do this.
> ...if I understand right what you want to do...
> ekke
> david schrieb:
>> hi,
>> TIA
>> David
Re: event listener [message #7597 is a reply to message #7576] |
Mon, 28 July 2008 03:57   |
david schrieb:
> hi ekke,
> crud and answers)
> services available (ListActivescalls, saveCall, updateCall, ...)
> can add new ones, close call, etc)
> the other clients, and the view displaying active calls will refresh
> is it clearer ??
> my opinion it is a very heavy solution
>> david,
>> at client site. you can use your service to do this.
>> ekke
>> david schrieb:
>>> hi,
>>> client.
>>> think object transaction is the thing i need
>>> TIA
>>> David
David,
I think what you want is to push data to the client. Its pretty much like the highly hyphed pushmail but for your case
for your business objects. As you said, its a tough problem, because normally a client would poll for data and thats
also actually the way Riena is built currently. You can use local OSGi Services or OSGi Services on a remote computer
with the same API just if they were local. However remoting currently only works from client to server. So a client can
call an OSGi Service on the server.
Doing it the other way round is tricky but I dont think its impossible.
Tricky parts are:
- maintain a persistent connection to the client (which you normally dont)
- find the right client (there is only one server so finding that one is easy but there could be 10000 clients for a RPC
call)
- and others
To cut a long story short, we dont have it currently and have no date set when it could be done. Still its certainly an
interesting topic.
If you have any ideas of your own how to solve this problem, please share them with us. Riena is however meant to also
work over the Internet with HTTP/HTTPs connections. That probably rules out JMS for us I guess (dont know JMS well enough)
- christian
Re: event listener [message #7618 is a reply to message #7597] |
Mon, 28 July 2008 05:26  |
hi Christian,
i will investigate and try to find a light solution to this case
the first and easy one will be to activate an eclipse job at client-side to
refresh business objects and views
but that's not completly correct
thanks
"Christian Campo" <christian.campo@compeople.de> wrote in message
news:488D7BEC.4000106@compeople.de...
> david schrieb:
>> hi ekke,
>> crud and answers)
>> is it clearer ??
>>> david,
>>> ekke
>>> david schrieb:
>>>> hi,
>>>> client.
>>>> TIA
>>>> David
> David,
> the highly hyphed pushmail but for your case for your business objects. As
> data and thats also actually the way Riena is built currently. You can use
> local OSGi Services or OSGi Services on a remote computer with the same
> client to server. So a client can call an OSGi Service on the server.
> Tricky parts are:
> easy but there could be 10000 clients for a RPC call)
> - and others
> when it could be done. Still its certainly an interesting topic.
> them with us. Riena is however meant to also work over the Internet with
> - christian
Re: event listener [message #573043 is a reply to message #6304] |
Fri, 25 July 2008 04:35  |
Originally posted by: ekkehard.gentz-software.de
david,
....if I understand right what you want to do...
ekke
david schrieb:
> hi,
> TIA
> David
Re: event listener [message #573068 is a reply to message #7554] |
hi ekke,
and answers)
is it clearer ??
> david,
> ekke
> david schrieb:
>> hi,
>> TIA
>> David
Re: event listener [message #573083 is a reply to message #7576] |
david schrieb:
> hi ekke,
> crud and answers)
> is it clearer ??
>> david,
>> ekke
>> david schrieb:
>>> hi,
>>> client.
>>> TIA
>>> David
David,
Tricky parts are:
call)
- and others
interesting topic.
- christian
Re: event listener [message #573112 is a reply to message #7597] |
hi Christian,
thanks
> david schrieb:
>> hi ekke,
>> crud and answers)
>> is it clearer ??
>>> david,
>>> ekke
>>> david schrieb:
>>>> hi,
>>>> client.
>>>> TIA
>>>> David
> David,
> Tricky parts are:
> - and others
> - christian
Current Time: Tue Jul 22 01:33:41 EDT 2025
Powered by FUDForum. Page generated in 0.06490 seconds
