Home » Archived » XML Schema Definition (XSD) » MinFacet, MaxFacet of xs:int with values 2147483647
MinFacet, MaxFacet of xs:int with values 2147483647 [message #70624] Mon, 13 November 2006 05:37 Go to next message
Originally posted by: mgonzalez.ibit.org
When we make getFacetContents() of an element of type xs:int we get the
MinFacet and MaxFacet with values like 2147483647, -2147483647 and the
element doesn't have fixed these facets.
There is a way of getting the real facets that are really fixed?
The XML is
<xs:element name="codiAdreca" type="xs:int" minOccurs="0" maxOccurs="1"/>
this element is inside a sequence in a complex type.
Thanks.
Marilen.
Re: MinFacet, MaxFacet of xs:int with values 2147483647 [message #70642 is a reply to message #70624] Mon, 13 November 2006 07:22 Go to previous messageGo to next message
Marilen,
You're asking for the facets of the type "int" which definitely has
those facets, but elements themselves don't have facets. If you want to
know about the mixOccurs and maxOccurs values, you have too look for
that information on the XSDParticle containing the element not on the
element's type.
> the MinFacet and MaxFacet with values like 2147483647, -2147483647 and
> the element doesn't have fixed these facets.
> The XML is
> Thanks.
> Marilen.
Re: MinFacet, MaxFacet of xs:int with values 2147483647 [message #70659 is a reply to message #70642] Tue, 14 November 2006 03:13 Go to previous message
Originally posted by: Mgonzalez.ibit.org
Thanks for the answer, yes you are right. I am getting the facets from the
type int. I will ignore these facets.
Re: MinFacet, MaxFacet of xs:int with values 2147483647 [message #599136 is a reply to message #70624] Mon, 13 November 2006 07:22 Go to previous message
Marilen,
element's type.
> The XML is
> Thanks.
> Marilen.
Re: MinFacet, MaxFacet of xs:int with values 2147483647 [message #599142 is a reply to message #70642] Tue, 14 November 2006 03:13 Go to previous message
Previous Topic:MinFacet, MaxFacet of xs:int with values 2147483647
Next Topic:Referenced attributes
Current Time: Mon Jul 14 08:53:30 EDT 2025
Powered by FUDForum. Page generated in 0.30435 seconds
