Home » Eclipse Projects » Equinox » SQL Editor
SQL Editor [message #70614] Tue, 25 July 2006 12:28 Go to next message
Originally posted by: francine.grimmer.ncr.com
I am trying to display DDL in the SQL Editor frame from within the
DataSource Explorer. I have written my own SQLEditorStorageEditorInput
that generates the DDL and calls the setStorage with the text and
setConnectionInfo with the connection profile. Then I have my own
ObjectActionDelegate that has a run method that does the page.openEditor
and provides the input text. The DDL is displayed but I am getting the
following Null Pointer exception:
Error occurred while trying to install sql updater
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater.rememberAnnotations(SQLUpdater.java:358)
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater.removeMarkers(SQLUpdater.java:404)
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater.update(SQLUpdater.java:188)
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater.access$000(SQLUpdater.java:62)
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater$1.run(SQLUpdater.java:132)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.datatools.sqltools.sqleditor.internal.editor.SQL Updater.run(SQLUpdater.java:128)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.installSQ LUpdater(SQLEditor.java:795)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.getAdapte r(SQLEditor.java:459)
org.eclipse.ui.views.contentoutline.ContentOutline.doCreateP age(ContentOutline.java:128)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:399)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:743)
org.eclipse.ui.views.contentoutline.ContentOutline.partBroug htToTop(ContentOutline.java:209)
org.eclipse.ui.internal.PartListenerList$2.run(PartListenerL ist.java:87)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
org.eclipse.ui.internal.PartListenerList.firePartBroughtToTo p(PartListenerList.java:85)
org.eclipse.ui.internal.PartService.firePartBroughtToTop(Par tService.java:87)
org.eclipse.ui.internal.WorkbenchPagePartList.firePartBrough tToTop(WorkbenchPagePartList.java:75)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActiveEdit orChanged(WorkbenchPagePartList.java:51)
at org.eclipse.ui.internal.PartList.setActiveEditor(PartList.ja va:152)
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1181)
org.eclipse.ui.internal.WorkbenchPage.updateActivePart(Workb enchPage.java:1126)
org.eclipse.ui.internal.WorkbenchPage.partAdded(WorkbenchPag e.java:1524)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:210)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:819)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:718)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:679)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2586)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2470)
com.ncr.teradata.datatools.dtp.catalog.popup.actions.Generat eDDLActionDelegate.run(GenerateDDLActionDelegate.java:78)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
When stepping through the code, it appears that the _annotationModel is
not getting set in SQLUpdater and then dereferenced in
SqlUpdater.rememberAnnotations(). I am not sure what I am missing???
I am calling page.openEditor, passing in the ID for the Eclipse SQLEditor.
I have also tried the SQLScrapebookEditor ID as well. Here is the code
snippet:
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
try {
page.openEditor(new ShowDDLSQLEditorInput(schema.getName(),
database.getName(), table, connectionProfile),
"org.eclipse.datatools.sqltools.sqleditor.SQLEditor");
} catch (PartInitException e) {
System.out.println("CreateTableActionDelegate.run, PartInitException,
can't open editor - " + e.getMessage());
regards,
Francine Grimmer
Re: SQL Editor [message #70635 is a reply to message #70614] Tue, 25 July 2006 13:08 Go to previous message
This is a bug that should be reported against the data tools project:
https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=D ataTools
"Francine" <francine.grimmer@ncr.com> wrote in message
news:107fd6e7df9f26515b3c1e869312dfa8$1@www.eclipse.org...
> java.lang.NullPointerException
> at
> at
> at
QLUpdater.java:188)
> at
> at
LUpdater.java:132)
> at
pdater.java:128)
> at
or.java:795)
> at
:459)
> at
ne.java:128)
> at
utline.java:209)
> at
> at
> at
st.java:85)
> at
> at
> at
> at
81)
> at
26)
> at
> at
> at
> at
..java:718)
> at
> at
va:2586)
> at
> at
> at
> at
> at
> at
> at
> at
tem.java:488)
> at
tionItem.java:400)
> at
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> snippet:
> try {
> regards,
> Francine Grimmer
Previous Topic:Quiestion about Remote Management?
Next Topic:The LogReaderService is not registered.
Current Time: Sat Jul 26 01:46:28 EDT 2025
Powered by FUDForum. Page generated in 0.49056 seconds
