Home » Eclipse Projects » Eclipse Platform » Sun's JDI and Eclipse ?
Sun's JDI and Eclipse ? [message #70561] Wed, 11 June 2003 04:32 Go to next message
Originally posted by: bluecoder.elivefree.net
Hi All,
I am trying to get "com.sun.jdi.*;" working inside my Eclipe plugin. The
problem is when I try to:
VirtualMachineManager mgr = Bootstrap.virtualMachineManager();
This causes an error that says the view cannot be created when I try
running the plugin in run-time workbench.
My question is, is it possible to use the Sun's JDI libraries within an
Eclipse plugin, e.g. to launch a program and monitor it ?? If not, what
alternatives are there ? I know Eclipse has its own version of JDI but
this doesnt have all the features I need. Thanks for your time :)
B.
Re: Sun's JDI and Eclipse ? [message #71035 is a reply to message #70561] Wed, 11 June 2003 11:29 Go to previous messageGo to next message
What error are you getting?
We are also interested in which features of the Eclipse JDI you are missing?
Darins
"B.C." <bluecoder@elivefree.net> wrote in message
news:bc6pe5$6ue$1@rogue.oti.com...
> Hi All,
> B.
Re: Sun's JDI and Eclipse ? [message #73206 is a reply to message #71035] Fri, 13 June 2003 05:13 Go to previous messageGo to next message
Thanks for your reply. I want to draw something everytime an object is
created so I am writing it as a plugin with a view. When I run as run-time
workbench I get the dialog box error:
\"Unable to create Part: ObjectView\"
Then in the view I get the error \"An error has occurred while creating
this view\"
The error log file says:
\"java.lang.NoClassDefFoundError: com/sun/jdi/Bootstrap
ie.ul.vcr.visplugins.visobj.views.Shannon.startMonitor(Shann on.java:58)
ie.ul.vcr.visplugins.visobj.views.DynObj.createPartControl(D ynObj.java:80)\ "
I have included the dt.jar and tools.jar as external jar files so it
should work ? The error is occuring when I try to bootstrap the JVM:
\"VirtualMachineManager mgr = Bootstrap.virtualMachineManager();\"
Well I have a stand alone java appplication developed and it seemed
quicker to stay with Sun\'s JDI and instead of trying to get used to
Eclipse\'s. The reason I said that was I found it hard to get
doc\'s/tutorials on Eclipse JDI, but since a couple of profilers use it,
it must have most of the functionality. I will be looking for object
creation/deletion, method entry/exit, threads, and corresponding line
numbers as I need to build up Control Flow and Data FLow views.
I would be very grateful if I could find out why Sun\'s JDI won\'t
bootstrap inside an Eclipe plugin. Is this possible ? Thanks for all your
time :)
B.
> Darins
> \"B.C.\" <bluecoder@elivefree.net> wrote in message
> > Hi All,
> > I am trying to get \"com.sun.jdi.*;\" working inside my Eclipe plugin. The
> > My question is, is it possible to use the Sun\'s JDI libraries within an
> > B.
Re: Sun's JDI and Eclipse ? [message #73391 is a reply to message #73206] Fri, 13 June 2003 08:45 Go to previous messageGo to next message
Originally posted by: darin_swanson.oti.com
Have you correctly configured your plugin.xml requirements?
<requires>
<import plugin="org.eclipse.jdt.debug."/>
...etc.
</requires>
Darins
"B." <bluecoder@elivefree.net> wrote in message
news:bcc4j8$qpk$1@rogue.oti.com...
> this view\"
> at
> at
> time :)
> B.
missing?
> > Darins
> > > Hi All,
plugin. The
an
what
> > > B.
Re: Sun's JDI and Eclipse ? [message #73638 is a reply to message #73391] Fri, 13 June 2003 10:35 Go to previous messageGo to next message
I don't have these but I thought that they would not be needed since I am
using Sun's JDI libs and not Eclipse's, would they not conflict ?
I tried putting these in the plugin.xml after your reccemendation but it
fails to load the plugin and gives "error reading plugin registry"
problems.
I look forward to your help :) Thanks
> <requires>
> ...etc.
> </requires>
> Darins
> > Hi,
> > this view\"
> > at
> > at
> > time :)
> > B.
> missing?
> > > Darins
> > > > Hi All,
> plugin. The
> an
> what
> > > > B.
Re: Sun's JDI and Eclipse ? [message #73674 is a reply to message #73391] Fri, 13 June 2003 11:05 Go to previous message
When I add to the plugin.xml:
<import plugin="org.eclipse.jdt.core"/>
<import plugin="org.eclipse.jdt.ui"/>
<import plugin="org.eclipse.jdt.debug"/>
<import plugin="org.eclipse.jdt.debug.ui"/>
<import plugin="org.eclipse.jdt.launching"/>
I get the following error:
java.lang.IncompatibleClassChangeError
for this line:
Since this works as a stand alone app I am wondering why it doesnt work
within eclipse ?
B.C.
Previous Topic:[q] feature.xml problem
Next Topic:Problem displaying markers in class file editor ruler
Current Time: Mon Sep 01 05:19:23 EDT 2025
Powered by FUDForum. Page generated in 0.08015 seconds
