Home » Modeling » TMF (Xtext) » Unordered group problem(Unordered group followed by same element does not behave as I expect)
Unordered group problem [message #695243] Mon, 11 July 2011 07:14 Go to next message
I have the following fragment in my grammar:
SeqConfig: op=ART_ID ((',' config_elements+=SeqConfigElement)* & (',' labref=LabRef)? )
                     (',' config_elements+=SeqConfigElement)* ;
The intent is that the DSL allows a single LabRef within a set of SeqConfigElement's
This input works (where NOP is a valid ART_ID and x=y is a valid SeqConfigElement:
NOP x=y, lab
But this does not
NOP x=y, lab, a=b
The error marker given in the generated editor is attached to the 'a' in a=b and appears to relate to a separate fragment of the grammar.
I have not yet tried to test my understanding of unordered groups and their interaction with other elements as I wanted to check with more experienced users where I might be going wrong.
Cheers and thanks for any help you can give,
- Dyson
Re: Unordered group problem [message #695246 is a reply to message #695243] Mon, 11 July 2011 07:20 Go to previous messageGo to next message
you don't need unordered groups for that. Something like
SeqConfig: op=ART_ID ((',' config_elements+=SeqConfigElement)* (',' labref=LabRef) )?
should work
Alex
Re: Unordered group problem [message #695273 is a reply to message #695246] Mon, 11 July 2011 08:12 Go to previous message
Good point Alex, thanks? Sometimes ones has to step back and look at these things from a different stance.
- Dyson
Previous Topic:[Xtext 2.0] Problem referencing sub entities
Next Topic:Using element define in one grammar into another
Current Time: Sat Jul 12 06:59:36 EDT 2025
Powered by FUDForum. Page generated in 0.02873 seconds
