Stack trace error with Struts tag libraries [message #70513] |
Mon, 31 January 2005 11:53  |
Originally posted by: jstansell.fhcp.com
I have been having a problem with my Eclipse every so often hanging for a
few seconds (as much as 20 seconds some times). I think I may have found my
problem. In the log file located at ..\eclipse\workspace\.metadata I see a
stack trace. It seams to be having a problem with the Struts tag libraries.
I am running 3.0.1 with MyEclipse installed, but no other plugins for
Struts. Could someone
take a look and let me know what might be causing it?
stack trace........ I have one for each tab library
!ENTRY com.genuitec.eclipse.j2eedt.core 1 1 Jan 31, 2005 09:47:34.616
!MESSAGE
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource is out of
sync with the file system: /pai/build/WEB-INF/tags/struts-bean.tld.
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:508)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:262)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:251)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibLocator.get TLDDigester(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibLocator.cre ateTaglibForTLD(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.JavaProjectTaglibLocator. searchTLDFile(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.JavaProjectTaglibLocator. searchFile(Unknown
Source)
at com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibLocator$1.v isit(Unknown
Source)
at org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:108)
org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:55)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:78)
org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:123)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:65)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:106)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:85)
at com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibLocator.sea rch(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.se archForTaglibs(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.pr ocessFile(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry$1. visit(Unknown
Source)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:82)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.ha ndleResourceModified(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.ha ndleResourceAdded(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.re fresh(Unknown
Source)
at com.genuitec.eclipse.j2eedt.taglib.AbstractTaglibRegistry.<init >(Unknown
Source)
at com.genuitec.eclipse.j2eedt.taglib.JavaTaglibRegistry.<init >(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.TaglibRegistryManager.cre ateNewRegistry(Unknown
Source)
com.genuitec.eclipse.j2eedt.taglib.TaglibRegistryManager.get TaglibRegistry(Unknown
Source)
com.genuitec.eclipse.j2eedt.core.J2EEProjectUtil.getTaglibUR IStream(Unknown
Source)
at com.genuitec.eclipse.integration.Integrator.projectResolver_ NA1(Unknown
Source)
at com.ibm.sse.model.util.ProjectResolver.getURIStream(Unknown Source)
com.ibm.sse.model.jsp.contentmodel.tld.TLDCMDocumentManager. loadTaglib(Unknown
Source)
com.ibm.sse.model.jsp.contentmodel.tld.TLDCMDocumentManager. getCMDocument(Unknown
Source)
com.ibm.sse.model.jsp.contentmodel.tld.TLDCMDocumentManager$ DirectiveStructuredDocumentRegionHandler.enableTaglibFromURI (Unknown
Source)
com.ibm.sse.model.jsp.contentmodel.tld.TLDCMDocumentManager$ DirectiveStructuredDocumentRegionHandler.processTaglib(Unkno wn
Source)
Source)
com.ibm.sse.model.jsp.contentmodel.tld.TLDCMDocumentManager$ DirectiveStructuredDocumentRegionHandler.nodeParsed(Unknown
Source)
com.ibm.sse.model.xml.internal.parser.XMLSourceParser.fireNo deParsed(Unknown
Source)
at com.ibm.sse.model.jsp.parser.JSPSourceParser.parseNodes(Unkn own Source)
com.ibm.sse.model.xml.internal.parser.XMLSourceParser.getDoc umentRegions(Unknown
Source)
at com.ibm.sse.model.internal.text.BasicStructuredDocument.setT ext(Unknown
Source)
at com.ibm.sse.model.internal.text.BasicStructuredDocument.set( Unknown
Source)
com.ibm.sse.model.jsp.modelquery.ModelQueryAdapterFactoryFor JSP$TaglibSupportModelLifecycleListener.setDocument(Unknown
Source)
com.ibm.sse.model.jsp.modelquery.ModelQueryAdapterFactoryFor JSP$TaglibSupportModelLifecycleListener.processPostModelEven t(Unknown
Source)
com.ibm.sse.model.LifecycleNotificationManager.signalLifecyc leEvent(Unknown
Source)
at com.ibm.sse.model.AbstractStructuredModel.signalLifecycleEve nt(Unknown
Source)
at com.ibm.sse.model.AbstractStructuredModel.setStructuredDocum ent(Unknown
Source)
com.ibm.sse.model.xml.internal.document.XMLModelImpl.setStru cturedDocument(Unknown
Source)
at com.ibm.sse.model.AbstractModelLoader.load(Unknown Source)
at com.ibm.sse.model.ModelManagerImpl._commonGetModel(Unknown Source)
at com.ibm.sse.model.ModelManagerImpl.getModelForEdit(Unknown Source)
at com.ibm.sse.editor.FileModelProvider.selfCreateModel(Unknown Source)
at com.ibm.sse.editor.FileModelProvider.createModelInfo(Unknown Source)
at com.ibm.sse.editor.FileModelProvider.createElementInfo(Unkno wn Source)
org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:397)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:2869)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:173)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1073)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:287)
at com.ibm.sse.editor.StructuredTextEditor.doSetInput(Unknown Source)
at com.ibm.sse.editor.jsp.StructuredTextEditorJSP.doSetInput(Un known
Source)
org.eclipse.ui.texteditor.AbstractTextEditor$15.run(Abstract TextEditor.java:2233)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:588)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:585)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1653)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:2247)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:2265)
at com.ibm.sse.editor.StructuredTextEditor.init(Unknown Source)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:117)
com.genuitec.eclipse.webdesigner.htmleditor.HTMLMultiPageEdi torPart.createSourcePage(Unknown
Source)
com.genuitec.eclipse.webdesigner.jspeditor.JSPMultiPageEdito rPart.createSourcePage(Unknown
Source)
com.genuitec.eclipse.webdesigner.htmleditor.HTMLMultiPageEdi torPart.createPages(Unknown
Source)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:187)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
org.eclipse.ui.internal.EditorStack.setVisibleEditor(EditorS tack.java:200)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:338)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:268)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:779)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:137)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:110)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 0)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:212)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:289)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:490)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:429)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:427)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:635)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:731)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:211)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:206)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:238)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!SUBENTRY 1 org.eclipse.core.resources 4 274 Jan 31, 2005 09:47:34.616
!MESSAGE Resource is out of sync with the file system:
Re: Stack trace error with Struts tag libraries [message #70657 is a reply to message #70513] |
Mon, 31 January 2005 15:47  |
Well, here is what I found out.
The build directory was only used during my ant build. I moved that
directory to NOT be in the same path as my project. This seems to fix the
problem. Not sure why a build directory that only changes when I do a build
would be causing this problem, but, anyway, this is a work around. Thanks
for the info.
"jstanell" <jstansell@fhcp.com> wrote in message
news:ctlnhh$7tv$2@www.eclipse.org...
> my
> a
> libraries.
> Thanks
> !MESSAGE
> !STACK 1
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.05129 seconds
