Home » Modeling » OCL » OCL type checking
OCL type checking [message #70497] Thu, 07 May 2009 08:50 Go to next message
--------------060801010002030201060707
I recently looked at the changes introduced in OCL with the inclusion of
the TypeChecker interface ( through bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673 ).
This gives third-party plugins a great deal of capabilities in dynamic
typing of custom operations and the such, yet I think some of the
standard operations could also benefit from this. The most obvious
example I have in mind would be something like this :
"randomList->select(oclIsKindOf(Type))"
At current, a user doing such a select operation will need to cast the
result in order to use its specific operations. Consider something like
this :
"randomList-> select(oclIsKindOf(ENamedElement)).oclAsType(ENamedElement). name "
I know there are way more complicated things than this that can happen
in an iterate; but at least those cases are obvious... and pretty
frequent. If I am not mistaken, the impossibility to type the result of
a select comes from line 3709 of AbstractOCLAnalyzer :
3708 } else if (name.equals("select") || name.equals("reject"))
{//$NON-NLS-2$//$NON-NLS-1$
3709 astNode.setType(source.getType());
Would there be any way to leverage the new TypeChecker in such cases or
was that a deliberate overlook?
Laurent Goubet
Obeo
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------060801010002030201060707--
Re: OCL type checking [message #70559 is a reply to message #70497] Thu, 07 May 2009 09:15 Go to previous messageGo to next message
--=-umL2vLUXNSDqBSTH3CCk
Hi, Laurent,
If I'm not mistaken, there was some discussion of this in the context of
QVT's need to modify the semantics of the OCL library. But, I think
those changes are incompatible from an API contract perspective, so they
were taken back to OMG as spec issues.
Unfortunately, changing the result type of a standard library operation
would be quite a deviation from the spec. It would be much nicer to be
able to define, in OCL or Java, a "typeSelect" operation for collections
(a la Xtend/Xpand). That isn't possible currently, as the specification
of type arguments in oclAsType (and consequently an hypothetical
typeSelect) is flawed. The changes already adopted by OMG for the OCL
2.1 revision should address that problem (specifically, doing away with
TypeType metaclass and OclType, using the Classifier metaclass instead).
Christian
On Thu, 2009-05-07 at 14:50 +0200, laurent Goubet wrote:
> this :
> Laurent Goubet
> Obeo
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Laurent,<BR>
<BR>
If I'm not mistaken, there was some discussion of this in the context of QVT's need to modify the semantics of the OCL library.&nbsp; But, I think those changes are incompatible from an API contract perspective, so they were taken back to OMG as spec issues.<BR>
<BR>
Unfortunately, changing the result type of a standard library operation would be quite a deviation from the spec.&nbsp; It would be much nicer to be able to define, in OCL or Java, a &quot;typeSelect&quot; operation for collections (a la Xtend/Xpand).&nbsp; That isn't possible currently, as the specification of type arguments in oclAsType (and consequently an hypothetical typeSelect) is flawed.&nbsp; The changes already adopted by OMG for the OCL 2.1 revision should address that problem (specifically, doing away with TypeType metaclass and OclType, using the Classifier metaclass instead).<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673">https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673</A> ).
&quot;randomList-&gt;select(oclIsKindOf(Type))&q uot;
this :
&quot;randomList-&gt;select(oclIsKindOf(ENamedElemen t)).oclAsType(ENamedElement).name&quot;
3708 } else if (name.equals(&quot;select&quot;) || name.equals(&quot;reject&quot;))
Laurent Goubet
Obeo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-umL2vLUXNSDqBSTH3CCk--
Re: OCL type checking [message #70578 is a reply to message #70559] Thu, 07 May 2009 09:28 Go to previous messageGo to next message
--------------030704030602000600090908
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Christian,
Indeed, this can be seen as a deviation from the spec, didn't really
look at it that way :p.
Thanks for the insight.
Laurent Goubet
Obeo
Christian W. Damus a écrit :
> Hi, Laurent,
> Cheers,
> Christian
>> this :
>> Regards,
>> Laurent Goubet
>> Obeo
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------030704030602000600090908--
Re: OCL type checking [message #70598 is a reply to message #70578] Thu, 07 May 2009 09:42 Go to previous messageGo to next message
--=-8jPJ4+XcA8/rwM8OmdDA
Content-Type: text/plain; charset="UTF-8"
Hi, Laurent,
On the flip side, sometimes deviation is good because it is practically
useful. :-) Especially with in the case of some specs. :-D
Goodness knows that the MDT OCL implementation already has more than its
share of deviations, some intended and more not. The problem with
deviation from spec is, of course, portability of models to other
implementations. So, it would be more beneficial for everyone to
improve the spec by the addition of capabilities like "typeSelect" but
that is more difficult than just implementing them :-(
cW
On Thu, 2009-05-07 at 15:28 +0200, laurent Goubet wrote:
> Hi Christian,
>=20
> Indeed, this can be seen as a deviation from the spec, didn't really=20
>=20
>=20
> Laurent Goubet
> Obeo
>=20
> Christian W. Damus a =C3=A9crit :
> > Hi, Laurent,
> >=20
> > If I'm not mistaken, there was some discussion of this in the context o=
f=20
> > QVT's need to modify the semantics of the OCL library. But, I think=20
> > those changes are incompatible from an API contract perspective, so the=
y=20
> >=20
> > Unfortunately, changing the result type of a standard library operation=
=20
> > would be quite a deviation from the spec. It would be much nicer to be=
=20
> > able to define, in OCL or Java, a "typeSelect" operation for collection=
s=20
> > (a la Xtend/Xpand). That isn't possible currently, as the specificatio=
n=20
> > of type arguments in oclAsType (and consequently an hypothetical=20
> > typeSelect) is flawed. The changes already adopted by OMG for the OCL=20
> > 2.1 revision should address that problem (specifically, doing away with=
=20
> > TypeType metaclass and OclType, using the Classifier metaclass instead)=
> >=20
> > Cheers,
> >=20
> > Christian
> >=20
> >> Hi,
> >> I recently looked at the changes introduced in OCL with the inclusion =
of=20
> >> the TypeChecker interface ( through bug=20
> >> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D233673 ).
> >> This gives third-party plugins a great deal of capabilities in dynamic=
=20
> >> typing of custom operations and the such, yet I think some of the=20
> >> standard operations could also benefit from this. The most obvious=20
> >> At current, a user doing such a select operation will need to cast the=
=20
> >> result in order to use its specific operations. Consider something lik=
e=20
> >> this :
> >> "randomList->select(oclIsKindOf(ENamedElement)).oclAsType(ENamedElemen=
t).name"=20
> >> I know there are way more complicated things than this that can happen=
=20
> >> in an iterate; but at least those cases are obvious... and pretty=20
> >> frequent. If I am not mistaken, the impossibility to type the result o=
f=20
> >> 3708 } else if (name.equals("select") || name.equals("reject"))=20
> >> Would there be any way to leverage the new TypeChecker in such cases o=
r=20
> >> Regards,
> >> Laurent Goubet
> >> Obeo
>=20
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Laurent,<BR>
<BR>
On the flip side, sometimes deviation is good because it is practically useful.&nbsp; :-)&nbsp; Especially with in the case of some specs.&nbsp; :-D<BR>
<BR>
Goodness knows that the MDT OCL implementation already has more than its share of deviations, some intended and more not.&nbsp; The problem with deviation from spec is, of course, portability of models to other implementations.&nbsp; So, it would be more beneficial for everyone to improve the spec by the addition of capabilities like &quot;typeSelect&quot; but that is more difficult than just implementing them&nbsp; :-(<BR>
<BR>
cW<BR>
<BR>
<PRE>
Hi Christian,
Laurent Goubet
Obeo
Christian W. Damus a &#233;crit :
&gt; Hi, Laurent,
&gt;
&gt; If I'm not mistaken, there was some discussion of this in the context of
&gt; QVT's need to modify the semantics of the OCL library. But, I think
&gt; those changes are incompatible from an API contract perspective, so they
&gt; were taken back to OMG as spec issues.
&gt;
&gt; Unfortunately, changing the result type of a standard library operation
&gt; would be quite a deviation from the spec. It would be much nicer to be
&gt; able to define, in OCL or Java, a &quot;typeSelect&quot; operation for collections
&gt; (a la Xtend/Xpand). That isn't possible currently, as the specification
&gt; of type arguments in oclAsType (and consequently an hypothetical
&gt; typeSelect) is flawed. The changes already adopted by OMG for the OCL
&gt; 2.1 revision should address that problem (specifically, doing away with
&gt; TypeType metaclass and OclType, using the Classifier metaclass instead).
&gt;
&gt; Cheers,
&gt;
&gt; Christian
&gt;
&gt; On Thu, 2009-05-07 at 14:50 +0200, laurent Goubet wrote:
&gt;&gt; Hi,
&gt;&gt;
&gt;&gt; I recently looked at the changes introduced in OCL with the inclusion of
&gt;&gt; the TypeChecker interface ( through bug
&gt;&gt; <A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673">https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673</A> ).
&gt;&gt;
&gt;&gt; This gives third-party plugins a great deal of capabilities in dynamic
&gt;&gt; typing of custom operations and the such, yet I think some of the
&gt;&gt; standard operations could also benefit from this. The most obvious
&gt;&gt; example I have in mind would be something like this :
&gt;&gt; &quot;randomList-&gt;select(oclIsKindOf(Type))&q uot;
&gt;&gt;
&gt;&gt; At current, a user doing such a select operation will need to cast the
&gt;&gt; result in order to use its specific operations. Consider something like
&gt;&gt; this :
&gt;&gt; &quot;randomList-&gt;select(oclIsKindOf(ENamedElemen t)).oclAsType(ENamedElement).name&quot;
&gt;&gt;
&gt;&gt;
&gt;&gt; I know there are way more complicated things than this that can happen
&gt;&gt; in an iterate; but at least those cases are obvious... and pretty
&gt;&gt; frequent. If I am not mistaken, the impossibility to type the result of
&gt;&gt; a select comes from line 3709 of AbstractOCLAnalyzer :
&gt;&gt; 3708 } else if (name.equals(&quot;select&quot;) || name.equals(&quot;reject&quot;))
&gt;&gt; {//$NON-NLS-2$//$NON-NLS-1$
&gt;&gt; 3709 astNode.setType(source.getType());
&gt;&gt;
&gt;&gt; Would there be any way to leverage the new TypeChecker in such cases or
&gt;&gt; was that a deliberate overlook?
&gt;&gt;
&gt;&gt; Regards,
&gt;&gt;
&gt;&gt; Laurent Goubet
&gt;&gt; Obeo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-8jPJ4+XcA8/rwM8OmdDA--
Re: OCL type checking [message #70613 is a reply to message #70598] Thu, 07 May 2009 11:32 Go to previous messageGo to next message
--------------070506020506030503090400
I was investigating this in the scope of the Acceleo project and yes,
we've also tried pushing things in the MTL specification. That sometimes
seem like an hopeless task :p.
As a side note, is there a reason why none of the "default"
UMLReflection implementations (both for UML and ecore environments)
aren't open API? I understand that this makes even more API to maintain
but UMLReflection is the typical exemple of hard and tedious to
reimplement interface. Especially when we only need to override one of
its 54 methods :p.
Laurent Goubet
Obeo
> Hi, Laurent,
> cW
>> Hi Christian,
>> Laurent Goubet
>> Obeo
>> > Hi, Laurent,
>> > Cheers,
>> > Christian
>> >> Hi,
>> >> this :
>> >> Regards,
>> >> Laurent Goubet
>> >> Obeo
--------------070506020506030503090400--
Re: OCL type checking [message #70646 is a reply to message #70613] Fri, 08 May 2009 08:26 Go to previous messageGo to next message
--=-fuFDBUcT+o55AlfSi3ZK
Hi, Laurent,
Much of the OCL code was published as API before it was truly ready.
The component went to release 1.0 in EMFT in the early days before the
Modeling Project came into being and before the now well-established
pattern of running up to 1.0 with 0.7, 0.8, and 0.9 releases. So, I
tried in recent years to be extra careful about adding new API, and
sitting down to figure out how much of a UMLReflection implementation
class should be public or protected API for clients/subclasses to use
just never fit into the plan.
Of course, that doesn't mean that you can't re-use the existing
implementation. Delegation may work well in this case.
Christian
On Thu, 2009-05-07 at 17:32 +0200, laurent Goubet wrote:
> I was investigating this in the scope of the Acceleo project and yes,=20
> we've also tried pushing things in the MTL specification. That sometimes=20
>=20
> As a side note, is there a reason why none of the "default"=20
> UMLReflection implementations (both for UML and ecore environments)=20
> aren't open API? I understand that this makes even more API to maintain=20
> but UMLReflection is the typical exemple of hard and tedious to=20
> reimplement interface. Especially when we only need to override one of=20
> its 54 methods :p.
>=20
> Laurent Goubet
> Obeo
>=20
> > Hi, Laurent,
> >=20
> > On the flip side, sometimes deviation is good because it is practically=
=20
> >=20
> > Goodness knows that the MDT OCL implementation already has more than it=
s=20
> > share of deviations, some intended and more not. The problem with=20
> > deviation from spec is, of course, portability of models to other=20
> > implementations. So, it would be more beneficial for everyone to=20
> > improve the spec by the addition of capabilities like "typeSelect" but=20
> >=20
> > cW
> >=20
> >> Hi Christian,
> >> Laurent Goubet
> >> Obeo
> >> > Hi, Laurent,
> >> >=20
> >> > If I'm not mistaken, there was some discussion of this in the contex=
t of=20
=20
> >> > those changes are incompatible from an API contract perspective, so =
they=20
> >> >=20
> >> > Unfortunately, changing the result type of a standard library operat=
ion=20
> >> > would be quite a deviation from the spec. It would be much nicer to=
be=20
> >> > able to define, in OCL or Java, a "typeSelect" operation for collect=
ions=20
> >> > (a la Xtend/Xpand). That isn't possible currently, as the specifica=
tion=20
> >> > typeSelect) is flawed. The changes already adopted by OMG for the O=
CL=20
> >> > 2.1 revision should address that problem (specifically, doing away w=
ith=20
> >> > TypeType metaclass and OclType, using the Classifier metaclass inste=
ad).
> >> >=20
> >> > Cheers,
> >> >=20
> >> > Christian
> >> >=20
> >> >> Hi,
> >> >> I recently looked at the changes introduced in OCL with the inclusi=
on of=20
> >> >> This gives third-party plugins a great deal of capabilities in dyna=
mic=20
> >> >> At current, a user doing such a select operation will need to cast =
the=20
> >> >> result in order to use its specific operations. Consider something =
like=20
> >> >> this :
> >> >> "randomList->select(oclIsKindOf(ENamedElement)).oclAsType(ENamedEle=
ment).name"=20
> >> >> I know there are way more complicated things than this that can hap=
pen=20
> >> >> frequent. If I am not mistaken, the impossibility to type the resul=
t of=20
> >> >> Would there be any way to leverage the new TypeChecker in such case=
s or=20
> >> >> Regards,
> >> >> Laurent Goubet
> >> >> Obeo
>=20
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Laurent,<BR>
<BR>
Much of the OCL code was published as API before it was truly ready.&nbsp; The component went to release 1.0 in EMFT in the early days before the Modeling Project came into being and before the now well-established pattern of running up to 1.0 with 0.7, 0.8, and 0.9 releases.&nbsp; So, I tried in recent years to be extra careful about adding new API, and sitting down to figure out how much of a UMLReflection implementation class should be public or protected API for clients/subclasses to use just never fit into the plan.<BR>
<BR>
Of course, that doesn't mean that you can't re-use the existing implementation.&nbsp; Delegation may work well in this case.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
As a side note, is there a reason why none of the &quot;default&quot;
its 54 methods :p.
Laurent Goubet
Obeo
&gt; Hi, Laurent,
&gt;
&gt; On the flip side, sometimes deviation is good because it is practically
&gt; useful. :-) Especially with in the case of some specs. :-D
&gt;
&gt; Goodness knows that the MDT OCL implementation already has more than its
&gt; share of deviations, some intended and more not. The problem with
&gt; deviation from spec is, of course, portability of models to other
&gt; implementations. So, it would be more beneficial for everyone to
&gt; improve the spec by the addition of capabilities like &quot;typeSelect&quot; but
&gt; that is more difficult than just implementing them :-(
&gt;
&gt; cW
&gt;
&gt; On Thu, 2009-05-07 at 15:28 +0200, laurent Goubet wrote:
&gt;&gt; Hi Christian,
&gt;&gt;
&gt;&gt; Indeed, this can be seen as a deviation from the spec, didn't really
&gt;&gt; look at it that way :p.
&gt;&gt;
&gt;&gt; Thanks for the insight.
&gt;&gt;
&gt;&gt; Obeo
&gt;&gt;
&gt;&gt; Christian W. Damus a &#233;crit :
&gt;&gt; &gt; Hi, Laurent,
&gt;&gt; &gt;
&gt;&gt; &gt; If I'm not mistaken, there was some discussion of this in the context of
&gt;&gt; &gt; QVT's need to modify the semantics of the OCL library. But, I think
&gt;&gt; &gt; those changes are incompatible from an API contract perspective, so they
&gt;&gt; &gt; were taken back to OMG as spec issues.
&gt;&gt; &gt;
&gt;&gt; &gt; Unfortunately, changing the result type of a standard library operation
&gt;&gt; &gt; would be quite a deviation from the spec. It would be much nicer to be
&gt;&gt; &gt; able to define, in OCL or Java, a &quot;typeSelect&quot; operation for collections
&gt;&gt; &gt; (a la Xtend/Xpand). That isn't possible currently, as the specification
&gt;&gt; &gt; of type arguments in oclAsType (and consequently an hypothetical
&gt;&gt; &gt; typeSelect) is flawed. The changes already adopted by OMG for the OCL
&gt;&gt; &gt; 2.1 revision should address that problem (specifically, doing away with
&gt;&gt; &gt; TypeType metaclass and OclType, using the Classifier metaclass instead).
&gt;&gt; &gt;
&gt;&gt; &gt; Cheers,
&gt;&gt; &gt;
&gt;&gt; &gt; Christian
&gt;&gt; &gt;
&gt;&gt; &gt; On Thu, 2009-05-07 at 14:50 +0200, laurent Goubet wrote:
&gt;&gt; &gt;&gt; Hi,
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; I recently looked at the changes introduced in OCL with the inclusion of
&gt;&gt; &gt;&gt; the TypeChecker interface ( through bug
&gt;&gt; &gt;&gt; <A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673">https://bugs.eclipse.org/bugs/show_bug.cgi?id=233673</A> ).
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; This gives third-party plugins a great deal of capabilities in dynamic
&gt;&gt; &gt;&gt; typing of custom operations and the such, yet I think some of the
&gt;&gt; &gt;&gt; standard operations could also benefit from this. The most obvious
&gt;&gt; &gt;&gt; example I have in mind would be something like this :
&gt;&gt; &gt;&gt; &quot;randomList-&gt;select(oclIsKindOf(Type))&q uot;
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; At current, a user doing such a select operation will need to cast the
&gt;&gt; &gt;&gt; result in order to use its specific operations. Consider something like
&gt;&gt; &gt;&gt; this :
&gt;&gt; &gt;&gt; &quot;randomList-&gt;select(oclIsKindOf(ENamedElemen t)).oclAsType(ENamedElement).name&quot;
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; I know there are way more complicated things than this that can happen
&gt;&gt; &gt;&gt; in an iterate; but at least those cases are obvious... and pretty
&gt;&gt; &gt;&gt; frequent. If I am not mistaken, the impossibility to type the result of
&gt;&gt; &gt;&gt; a select comes from line 3709 of AbstractOCLAnalyzer :
&gt;&gt; &gt;&gt; 3708 } else if (name.equals(&quot;select&quot;) || name.equals(&quot;reject&quot;))
&gt;&gt; &gt;&gt; {//$NON-NLS-2$//$NON-NLS-1$
&gt;&gt; &gt;&gt; 3709 astNode.setType(source.getType());
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; Would there be any way to leverage the new TypeChecker in such cases or
&gt;&gt; &gt;&gt; was that a deliberate overlook?
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; Regards,
&gt;&gt; &gt;&gt;
&gt;&gt; &gt;&gt; Laurent Goubet
&gt;&gt; &gt;&gt; Obeo
&gt;&gt;
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-fuFDBUcT+o55AlfSi3ZK--
Re: OCL type checking [message #70722 is a reply to message #70646] Wed, 13 May 2009 05:19 Go to previous messageGo to next message
--------------030205020201030106030306
Hi Christian,
Yup, delegation is the choice I ended up making (UMLReflection is just
too tedious to reimplement, and I am a lazy bum :p). I understand the
problem you faced with this "API or not API" question ... and I won't
try to push into making it API as I know how much work it can be to
maintain. Especially so since it can be worked around through delegation.
Laurent Goubet
Obeo
> Hi, Laurent,
> Cheers,
> Christian
>> its 54 methods :p.
>> Laurent Goubet
>> Obeo
>> > Hi, Laurent,
>> > cW
>> >> Hi Christian,
>> >> Laurent Goubet
>> >> Obeo
>> >> > Hi, Laurent,
>> >> > Cheers,
>> >> > Christian
>> >> >> Hi,
>> >> >> this :
>> >> >> Regards,
>> >> >> Laurent Goubet
>> >> >> Obeo
--------------030205020201030106030306--
Re: OCL type checking [message #71371 is a reply to message #70722] Wed, 10 June 2009 10:36 Go to previous message
Hi Laurent
Evolution to MDT OCL 1.3.0 imposes heavy API compliance restrictions that
prevent enhancements being quite as clean as they might.
I'm fairly sure we will go to 2.0.0 rather than 1.4.0 next which allows us
to break some APIs (responsibly). It is quite amazing that QVT has been
accommodated without breaking APIs completely.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237438 discusses ideas
for MDT OCL 2.0. This discussion should become a new bugzilla referenced
from 237438.
I'm sure there is some scope for rationalising the UMLReflection, TypeChecker,
Environment APIs.
Ed Willink
Previous Topic:Error on RCP product export, when OCL validation is used
Next Topic:Eclispe compatibility
Current Time: Mon Jul 14 05:45:26 EDT 2025
Powered by FUDForum. Page generated in 0.06202 seconds
