Home » Eclipse Projects » Eclipse Platform » Writable files after CVS commit
Writable files after CVS commit [message #70447] Wed, 11 June 2003 02:29 Go to next message
Originally posted by: marcincak.vsl.sk
I would like to ask two questions concerning CVS and 'edit':
1. in normal case when I am at the office and connected to CVS
repository it is perfect, that Eclipse sends edit command to server when I
try to edit a file and write-enables the file. But there are situations,
when I am with the notebook somewhere off and need to edit some file. I such
situation I just write-enable file manually (from the properties tab), but
when I return to the office both 'edit' and 'unedit' options are disabled
for the file. Is this a bug?
2. when I commit newly-added files to the CVS, Eclipse adds them to the
repository automatically, but after commit the files are still writable. For
me it is not good because files are writable and I am not marked as editor.
And again both 'edit' and 'unedit' actions for these files are disabled.
Even when I make them readonly (from properties tab; file by file, because
properties are disabled in multiple file selection) icon decorations still
shows 'little person' (writable) and I have to restart Eclipse.
peter.
Re: Writable files after CVS commit [message #70919 is a reply to message #70447] Wed, 11 June 2003 10:28 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
peter wrote:
Did you try to perform an 'edit' when you were disconnected. Performing
an edit when you are disconnected should work but the notification to
the server is held until you connect successfully. If this doesn't work,
then there is a bug.
This is a known issue (https://bugs.eclipse.org/bugs/show_bug.cgi?id=36470)
Re: Writable files after CVS commit [message #72365 is a reply to message #70919] Thu, 12 June 2003 13:40 Go to previous message
Thanks a lot Michael
"Michael Valenta" <Michael_Valenta@oti.com> wrote in message
news:3EE73CA6.9070709@oti.com...
> peter wrote:
> > Hi,
I
such
but
disabled
the
For
editor.
because
still
Previous Topic:Ant & Eclipse javac problem
Next Topic:Xml Rpc plugin problem
Current Time: Fri Jul 18 07:21:37 EDT 2025
Powered by FUDForum. Page generated in 0.11549 seconds
