Stuck with WTP Tutorial [message #70411] |
Fri, 27 May 2005 10:40  |
I'm trying to get to grips with using eclipse (I'm a netbeans 3.6 fan
who's hacked off with the way netbeans 4 has gone...)
I'm looking at the "WTP Tutorials – Building and Running a Web
Application" document, and all is well initially. But when I get to
trying to create the new project, I don't have the "J2EE Web Project"
option visible under the web projects headers - only the "Simple Web
Project" option.
What have I missed?
Cheers
Pete Ford
Re: Stuck with WTP Tutorial [message #71860 is a reply to message #71690] |
Wed, 01 June 2005 06:13   |
Philippe Ombredanne wrote:
> Try to check your perspective under Window/Customize perspective.
> Check the J2EE, server, web, weeb services, XML and EJB under the
> new/shortcut categories.
> The projects will show up under the File/New.
> WTP is not yet foolproof, this is just milestones code for now ;-)
> Add a bug if this does not work
> "Pete Ford" <pete@justcroft.com> wrote in message
> news:d77bnf$t59$1@news.eclipse.org...
>>Hi,
>>Project" option.
>>What have I missed?
>>Cheers
>>Pete Ford
I only get a J2EE Web Module shortcut under File/New. There is still no
"J2EE Web Project" option as indicated in the tutorial.
Looks like it is alreadty reported in bug 96147 so I'll vote on that...
I think I can get started anyway.
Peter Ford phone: 01580 893333
Developer fax: 01580 893399
Justcroft International Ltd., Staplehurst, Kent
Re: Stuck with WTP Tutorial [message #72105 is a reply to message #71860] |
Wed, 01 June 2005 13:21  |
news:d7k22q$qbm$1@news.eclipse.org...
Can you access the J2EE perspective ?
From the explorer there you should be able to create J2EE projects.
FUDForum. Page generated in 0.07994 seconds
