Home » Newcomers » Newcomers » Ant problemos
Ant problemos [message #70332] Fri, 27 May 2005 09:47 Go to next message
Originally posted by: paulcohen.ozemail.com.au
I have a problem that is really killing me.
I recently installed Eclipse3.1M7. JDK is V1.5.0_01
Ant builds ran fine in 3.1M6, but now every time I try to run an ant task
I get a popup with:
Title: Java Virtual Machine Launcher
Message: Could not find the main class. Program will exit.
Build and Executes/debugs of the project all work fine...Ant just does not
want to run.
I've checked the tools.jar and jre...all looks fine.
Any ideas...anyone..please?
Help....
ty,
pc
Re: Ant problemos [message #70431 is a reply to message #70332] Fri, 27 May 2005 11:41 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95611
Workaround listed in comment #2
HTH
Darins
"Paul" <paulcohen@ozemail.com.au> wrote in message
news:93f467da0e26b04e0494e2aa1a5ddadd$1@www.eclipse.org...
> I get a popup with:
> want to run.
> Help....
> ty,
> pc
Re: Ant problemos [message #70487 is a reply to message #70431] Fri, 27 May 2005 12:31 Go to previous messageGo to next message
thanks...thought I was going crazy for a while.
The proposed solution does not appear to work for me either.
Any clues?
ty,
pc
Re: Ant problemos [message #70504 is a reply to message #70487] Fri, 27 May 2005 12:36 Go to previous messageGo to next message
and I have no quotes in any Path entries
Re: Ant problemos [message #70522 is a reply to message #70504] Fri, 27 May 2005 12:55 Go to previous messageGo to next message
Can you provide the command line information: Right click on your failed
build process>Process Information>Command Line
Darins
news:7eb9fe17bfce2596f547058182e08755$1@www.eclipse.org...
Re: Ant problemos [message #70541 is a reply to message #70504] Fri, 27 May 2005 12:55 Go to previous messageGo to next message
And does running in the same JRE (set on the JRE tab of your Ant launch
config) solve any problems?
Darins
Re: Ant problemos [message #70560 is a reply to message #70541] Fri, 27 May 2005 13:06 Go to previous messageGo to next message
Interesting...my main jre is set to the jdk
If I set the Ant to JRE (different one) I get the original error.
If I set it to same as workspace I now get
Dialog: Failure of Background Ant Build
Message: Could not find one or more classes:
"org.apache.tools.ant.buidlexception"
PLease check ant classpath
ty,pc
Re: Ant problemos [message #70577 is a reply to message #70522] Fri, 27 May 2005 13:08 Go to previous messageGo to next message
I'm not sure what you mean here as I don't see any of these options.
right clicking on build.xml or any of the targets.
ty,
pc
Re: Ant problemos [message #70595 is a reply to message #70577] Fri, 27 May 2005 13:32 Go to previous messageGo to next message
Sorry...more explict instructions:
Run the build that fails
Go to the debug view, right click on the terminated process>Process
Also in your plugins directory you do not have either
org.eclipse.ant.core_3.1.0 or org.eclipse.ant.ui_3.1.0 do you?
That is you did your M7 install in a new location...not over your old M6
install?
Darins
news:3b44f0fd9e0d39e66c720b97abca3aef$1@www.eclipse.org...
> ty,
> pc
Re: Ant problemos [message #70775 is a reply to message #70595] Fri, 27 May 2005 13:59 Go to previous messageGo to next message
ant "-Declipse.home=c:\eclipse " "-Declipse.running=true "
"-DJAVA_HOME=C:\Java\jdk1.5.0_01 "
"-Dant.home=c:\eclipse\plugins\org.apache.ant_1.6.3" -logger
org.eclipse.ant.internal.ui.antsupport.logger.AntProcessBuil dLogger
-buildfile "C:\eclipse\workspace2\LightStone\build.xml"
re: install. No I deleted all the M6 and did a clean install with just the
workspaces in the directory.
the only ant ones I have are:
C:\eclipse\plugins\org.apache.ant_1.6.3
C:\eclipse\plugins\org.eclipse.emf.ant_2.1.0
ty,pc
Re: Ant problemos [message #70789 is a reply to message #70775] Fri, 27 May 2005 14:01 Go to previous messageGo to next message
previous message was eclipse and ant using same JRE
THis is from different ones, where the message is the original "Failed to
find Main class message"
C:\Java\jre1.5.0_01\bin\javaw.exe
-Dant.library.dir=c:\eclipse\plugins\org.apache.ant_1.6.3\li b -classpath
G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6. 2\lib\ant.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.a pache.ant_1.6.2\lib\ant-antlr.jar;G:\eclipse-SDK-3.0-win32\e clipse\plugins\org.apache.ant_1.6.2\lib\ant-apache-bcel.jar; G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6. 2\lib\ant-apache-bsf.jar;G:\eclipse-SDK-3.0-win32\eclipse\pl ugins\org.apache.ant_1.6.2\lib\ant-apache-log4j.jar;G:\eclip se-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\an t-apache-oro.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\or g.apache.ant_1.6.2\lib\ant-apache-regexp.jar;G:\eclipse-SDK- 3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-apach e-resolver.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org. apache.ant_1.6.2\lib\ant-commons-logging.jar;G:\eclipse-SDK- 3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-commo ns-net.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apac he.ant_1.6.2\lib\ant-icontract.jar;G:\eclipse-SDK-3.0-win32\ eclipse\plugins\org.apache.ant_1.6.2\lib\ant-jai.jar;G:\ecli pse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\a nt-javamail.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org .apache.ant_1.6.2\lib\ant-jdepend.jar;G:\eclipse-SDK-3.0-win 32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-jmf.jar;G:\e clipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\li b\ant-jsch.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org. apache.ant_1.6.2\lib\ant-junit.jar;G:\eclipse-SDK-3.0-win32\ eclipse\plugins\org.apache.ant_1.6.2\lib\ant-launcher.jar;G: \eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\ lib\ant-netrexx.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins \org.apache.ant_1.6.2\lib\ant-nodeps.jar;G:\eclipse-SDK-3.0- win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-starteam. jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_ 1.6.2\lib\ant-stylebook.jar;G:\eclipse-SDK-3.0-win32\eclipse \plugins\org.apache.ant_1.6.2\lib\ant-swing.jar;G:\eclipse-S DK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-tr ax.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.a nt_1.6.2\lib\ant-vaj.jar;G:\eclipse-SDK-3.0-win32\eclipse\pl ugins\org.apache.ant_1.6.2\lib\ant-weblogic.jar;G:\eclipse-S DK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-xa lan1.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache .ant_1.6.2\lib\ant-xslp.jar;C:\eclipse\configuration\org.ecl ipse.osgi\bundles\6\1\.cp\lib\remoteAnt.jar;C:\Java\jdk1.5.0 _01\lib\tools.jar;C:\eclipse\plugins\org.junit_3.8.1\junit.j ar
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner
"\"-Declipse.connect.port=1352 \""
"\"-Dorg.eclipse.ant.core.ANT_PROCESS_ID=1117216524500 \""
"\"-DJAVA_HOME=C:\Java\jdk1.5.0_01 \""
\"-Dant.home=c:\eclipse\plugins\org.apache.ant_1.6.3\" -logger
org.eclipse.ant.internal.ui.antsupport.logger.RemoteAntBuild Logger
-buildfile \"C:\eclipse\workspace2\LightStone\build.xml\"
Re: Ant problemos [message #70813 is a reply to message #70789] Fri, 27 May 2005 14:11 Go to previous messageGo to next message
Can you verify that
C:\eclipse\configuration\org.eclipse.osgi\bundles\6\1\.cp\li b\remoteAnt.jar
is present.
Also it is very strange that your Ant home is pointing to
c:\eclipse\plugins\org.apache.ant_1.6.3 yet you are using all the Ant JARs
from G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6. 2?
Run>External Tools>External Tools...
Go to the classpath tab
Click Restore Defaults
Run
news:93d26f115712250cc649b010abea1474$1@www.eclipse.org...
\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\ lib\ant-antlr.ja
r;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1. 6.2\lib\ant-apac
he-bcel.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apa che.ant_1.6.2\li
b\ant-apache-bsf.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugin s\org.apache.ant
_1.6.2\lib\ant-apache-log4j.jar;G:\eclipse-SDK-3.0-win32\ecl ipse\plugins\org
..apache.ant_1.6.2\lib\ant-apache-oro.jar;G:\eclipse-SDK-3.0 -win32\eclipse\pl
ugins\org.apache.ant_1.6.2\lib\ant-apache-regexp.jar;G:\ecli pse-SDK-3.0-win3
2\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-apache-resolv er.jar;G:\eclips
e-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant -commons-logging
..jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.an t_1.6.2\lib\ant-c
ommons-net.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org. apache.ant_1.6.2
\lib\ant-icontract.jar;G:\eclipse-SDK-3.0-win32\eclipse\plug ins\org.apache.a
nt_1.6.2\lib\ant-jai.jar;G:\eclipse-SDK-3.0-win32\eclipse\pl ugins\org.apache
..ant_1.6.2\lib\ant-javamail.jar;G:\eclipse-SDK-3.0-win32\ec lipse\plugins\org
..apache.ant_1.6.2\lib\ant-jdepend.jar;G:\eclipse-SDK-3.0-wi n32\eclipse\plugi
ns\org.apache.ant_1.6.2\lib\ant-jmf.jar;G:\eclipse-SDK-3.0-w in32\eclipse\plu
gins\org.apache.ant_1.6.2\lib\ant-jsch.jar;G:\eclipse-SDK-3. 0-win32\eclipse\
plugins\org.apache.ant_1.6.2\lib\ant-junit.jar;G:\eclipse-SD K-3.0-win32\ecli
pse\plugins\org.apache.ant_1.6.2\lib\ant-launcher.jar;G:\ecl ipse-SDK-3.0-win
32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-netrexx.jar; G:\eclipse-SDK-3
..0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-nodep s.jar;G:\eclipse-
SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\lib\ant-s tarteam.jar;G:\e
clipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_1.6.2\li b\ant-stylebook.
jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache.ant_ 1.6.2\lib\ant-sw
ing.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apache. ant_1.6.2\lib\an
t-trax.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.apac he.ant_1.6.2\lib
\ant-vaj.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins\org.ap ache.ant_1.6.2\l
ib\ant-weblogic.jar;G:\eclipse-SDK-3.0-win32\eclipse\plugins \org.apache.ant_
1.6.2\lib\ant-xalan1.jar;G:\eclipse-SDK-3.0-win32\eclipse\pl ugins\org.apache
..ant_1.6.2\lib\ant-xslp.jar;C:\eclipse\configuration\org.ec lipse.osgi\bundle
s\6\1\.cp\lib\remoteAnt.jar;C:\Java\jdk1.5.0_01\lib\tools.ja r;C:\eclipse\plu
gins\org.junit_3.8.1\junit.jar
Re: Ant problemos [message #70940 is a reply to message #70813] Fri, 27 May 2005 14:43 Go to previous messageGo to next message
remoteant.jar is there.
Strange...the ant home does not seem to want to reset, even manually doing
it.
Is it set anywhere else?
ty,pc
Re: Ant problemos [message #70973 is a reply to message #70940] Fri, 27 May 2005 14:55 Go to previous messageGo to next message
Success!!
Thank you.
Had to go to window/preferences/ant/runtime/
and remove the old ones manually and add external jars.
Now works fine.
Strange how it did that because I dumped a whole directory from one G
drive to C, without running it on G first, unless there is a workspace
setting that held the ant home locations? These were also copied from G to
C drive?
So problem actually seemed to be just the ant home was screwed, as I just
tested the same/diff workspace with "set an input handler" checked and
it's all sweet.
Thanks again for your time in talking me through this.
Sometimes it's obvious, but an outside eye is what you need.
pc
Re: Ant problemos [message #70984 is a reply to message #70973] Fri, 27 May 2005 15:08 Go to previous message
Thank you.
There must be a bug in here somewhere...it should not have been soo hard to
figure this out.
I will attempt to play around with migration in this area to see what I can
find.
Darins
news:9bee63ae24ad182d588aa63a58c380c9$1@www.eclipse.org...
> Success!!
> Thank you.
> Now works fine.
> C drive?
> it's all sweet.
> Cheers,
> pc
Previous Topic:Report Tutorial
Next Topic:The old SWT Javadoc question
Current Time: Sat Jul 26 05:54:16 EDT 2025
Powered by FUDForum. Page generated in 0.11365 seconds
