emf model importer: prefix names are always "type" [message #70325] |
Fri, 02 February 2007 17:58  |
When I use the emf model importer to pull in an XSD into an ecore model, the name prefix placed in the ecore model for all of the referenced/imported types are the same: "types". While it doesn't seem to bother the emf internals too much, it causes much grief when I use Teneo to map these types to database tables. The prefix names are used to scope the table names.
I think the proper behavior would be to use the prefix names as defined in the XSDs (either the including XSDs or perhaps the ones where the types are actually created). Is this a reasonable request or is there something that keeps this from working this way?
I can work around this temporarily by doing this by hand for now, but ultimately, I need to do this completely programmatically.
Brian
Re: emf model importer: prefix names are always "type" [message #70366 is a reply to message #70325] |
Sat, 03 February 2007 07:34  |
Brian,
You can use the ecore:nsPrefix annotation as described in
http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf
to control this.
> Brian
Re: emf model importer: prefix names are always "type" [message #602115 is a reply to message #70325] |
Brian,
to control this.
> Brian
FUDForum. Page generated in 0.04648 seconds
