problem using AJDT in Eclipse [message #70264] |
Thu, 19 July 2007 01:29 |
I am just begining to use Aspect J in Eclipse and having some basic issues.
May be I do not understand the integration. I installed the ajdt pluggin
from eclipse site.
But when I am trying to run some of the example aspects, the Eclipse
launcher gives internal error saying it can not find main method of an
aspect.
I get
java.lang.NoClassDefFoundError: tracing/version1/TraceMyClasses
Exception in thread "main"
I thought when I installed AJDT, ajc and other related tools are also
installed. So when I use Run.. command to create a launcher with Aspect
name
to run, it should find ASpect's main
method is not it? May be I am missing something here. Do I need to make any
changed to configuratio
to be able to do that? How does Ecplise chose to run the commands with
Aspect J compiler/runtime v.s reggular Java JRE/JDK?
thanks for the help
Srini
FUDForum. Page generated in 0.04416 seconds
