Home » Eclipse Projects » Remote Application Platform (RAP) » Running RAP on Tomcat on Linux
Running RAP on Tomcat on Linux [message #70228] Wed, 16 January 2008 04:59 Go to next message
Originally posted by: robert.einsle.de
Hello List,
we are testing Eclipse RAP an it looks very good.
But while deploying the Eclipse RAP Project as .war on an Apache Tomcat
5.5.25 running on an Linux Server on Java 6, Tomcat Produces havy load and
logs on catalina.out the osgi-Prompt several Times a Minute.
We have the same running the eclipse RAP-Demo on the Application-Server.
Is it imposible to run RAP on Tomcat on Linux?
Thanks for Help.
Robert
Re: Running RAP on Tomcat on Linux [message #70390 is a reply to message #70228] Wed, 16 January 2008 19:57 Go to previous messageGo to next message
Originally posted by: leeguannan.msn.com
yes Eclipse RAP can running on Tomcat or Linux
"Robert" <robert@einsle.de> 写入消息
news:0a3194399f689f80e71679b44a4c83a5$1@www.eclipse.org...
> Hello List,
> Thanks for Help.
> Robert
Re: Running RAP on Tomcat on Linux [message #70410 is a reply to message #70228] Thu, 17 January 2008 01:32 Go to previous messageGo to next message
Originally posted by: mario.peham.etech.at
Robert schrieb:
> Hello List,
> and logs on catalina.out the osgi-Prompt several Times a Minute.
> Thanks for Help.
> Robert
You must disable the console in the web.xml
<param-name>commandline</param-name>
<param-value>-console</param-value>
Mario
Re: Running RAP on Tomcat on Linux [message #70463 is a reply to message #70410] Thu, 17 January 2008 03:52 Go to previous messageGo to next message
Hy Mario,
> Mario
here a snapshoot of my web.xml:
--- cut ---
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet </servlet-class>
<init-param>
</init-param>
<init-param>
<param-name>enableFrameworkControls</param-name>
<param-value>true</param-value>
</init-param>
<init-param>
<param-name>extendedFrameworkExports</param-name>
<param-value></param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
--- cut ---
I think, this parameter is set.
The Application-Server (Tomcat Apacht 5.5.25) run on an Debian Etch
Server, but, when deploying my RAP-Application, the Server reports me 100
% CPU-Load while none is fetching Webpages. And my catalina.out is growing
with "osgi".
Any other Idea?
Robert
Re: Running RAP on Tomcat on Linux [message #70482 is a reply to message #70390] Thu, 17 January 2008 03:54 Go to previous messageGo to next message
Hy Lign,
Yes, it runs, but 100 % CPU-Load and a fast growing catalina.out ....
Robert
Re: Running RAP on Tomcat on Linux [message #70500 is a reply to message #70463] Thu, 17 January 2008 04:31 Go to previous messageGo to next message
Robert schrieb:
> Hy Mario,
>> Mario
> --- cut ---
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </servlet>
> --- cut ---
> 100 % CPU-Load while none is fetching Webpages. And my catalina.out is
> growing with "osgi".
> Any other Idea?
> Thanks
> Robert
Hallo Robert
You must remove this line
<init-param>
</init-param>
from the web.xml
Mario
Re: Running RAP on Tomcat on Linux [message #70517 is a reply to message #70500] Thu, 17 January 2008 05:37 Go to previous messageGo to next message
Mario Peham wrote:
> Hallo Robert
> <init-param>
> </init-param>
> from the web.xml
> Mario
Oh, sorry, i miussunderstand it. Jes, now its working.
Thanks a lot.
Robert
Re: Running RAP on Tomcat on Linux [message #70611 is a reply to message #70482] Thu, 17 January 2008 21:00 Go to previous message
Hi Robert,
As noted in another branch of this thread 100% CPU utilization can occur
when the console is enabled but system.in is not available. Typically this
occurs because the process was launched with "javaw". The problem can be
recovered from and is fixed in 3.3.2 as well as the 3.4 HEAD.
-Simon
"Robert" <robert@einsle.de> wrote in message
news:a3c675bd004ba82b69d8425cf922bfc1$1@www.eclipse.org...
> Hy Lign,
> Robert
Previous Topic:Rap on mobile devices
Next Topic:Problem to free a ViewPart instance
Current Time: Mon Jul 21 21:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.36833 seconds
