Home » Archived » Service Component Architecture (SCA) Tools » Using the SCA Designer as an abstract modeling tool
Re: Using the SCA Designer as an abstract modeling tool [message #6295 is a reply to message #6265] |
Mon, 02 March 2009 09:21   |
Mischa a écrit :
> Hi all,
> I want to use the SCA Designer as a kind of abstract modeling tool. This
> way I don't want to have any dependencies to SCA implementations like
> the "Apache Tuscany".
> The SCA Designer generates a interface description like the following
> one as default:
> <tuscany:interface.wsdl
> xmlns:tuscany="http://tuscany.apache.org/xmlns/sca/1.0"
> interface="http://www.itemis.com/BLABLUB#wsdl.interface(BLUB)"/>
> Why I'm forced to use tusacany? Is there a way to remove this
> impl-specific namespace (or to change to it to a spring specific one) in
> the designer?
> regards,
> Mischa
Hi Mischa,
Currently the WSDL interface element is defined in the Open SOA
namespace and not in the Tuscany one. It was a bug that we fixed in the
last build [0]. Can you try the last version of the designer?
The following bindings (WebService, EJB, JMS), interfaces (Java, WSDL,
C++, BPEL Partner Link), and implementations (Java, SCA, BPEL, C++, EJB,
Spring, Web) are defined in the OSOA namespace, because they are defined
by the Open SOA consortium.
The others bindings, implementations and interfaces are defined in the
namespace of the SCA runtime that defines them. It's conceivable to have
the same SCA element (for example the RMI binding) defined in a way by
Tuscany and in another way by Frascati. So, the namespace is important.
If the namespace information isn't useful for you in your assembly file
you can use an XSLT transformation that remove this information when you
save the assembly file and an other transformation that add this
information when you load the assembly file. Because, the SCA tools (xml
editor, designer, tree viewer) need this information to work correctly.
In the plugin org.eclipse.stp.sca, in the directory xslt, you have two
samples of XSLT transformations, one for the transformation sca to
tuscany and an other for tuscany to sca. These transformations are not
maintenained.
Stephane Drapeau
Obeo
[0]: http://download.eclipse.org/stp/updates/galileo/site.xml
Re: Using the SCA Designer as an abstract modeling tool [message #7566 is a reply to message #6295] |
Mon, 02 March 2009 10:03  |
Hi Stephane,
thanks a lot for this detailed explanation. Since I'm not going to use any
"not Open SOA conform" elements I should be able to work with the Open SOA
namespaces only, which was my initial intention. (At least after updating to
the lasted build:-)).
Regrads,
Mischa
"Stephane Drapeau" <Stephane.Drapeau@obeo.fr> schrieb im Newsbeitrag
news:49ABEB7C.5010701@obeo.fr...
> Mischa a écrit :
>> Hi all,
>> way I don't want to have any dependencies to SCA implementations like the
>> "Apache Tuscany".
>> The SCA Designer generates a interface description like the following one
>> as default:
>> the designer?
>> regards,
>> Mischa
> Hi Mischa,
> Currently the WSDL interface element is defined in the Open SOA namespace
> and not in the Tuscany one. It was a bug that we fixed in the last build
> samples of XSLT transformations, one for the transformation sca to tuscany
> maintenained.
> Stephane Drapeau
> Obeo
Re: Using the SCA Designer as an abstract modeling tool [message #574717 is a reply to message #6265] |
Mischa a écrit :
> Hi all,
> one as default:
> the designer?
> regards,
> Mischa
Hi Mischa,
maintenained.
Stephane Drapeau
Obeo
Re: Using the SCA Designer as an abstract modeling tool [message #574740 is a reply to message #6295] |
Hi Stephane,
Regrads,
Mischa
> Mischa a écrit :
>> Hi all,
>> "Apache Tuscany".
>> as default:
>> the designer?
>> regards,
>> Mischa
> Hi Mischa,
> maintenained.
> Stephane Drapeau
> Obeo
Current Time: Sun Jul 27 06:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.04222 seconds
