VE confuses SWT with AWT [message #70180] |
Sat, 06 November 2004 03:26  |
Originally posted by: jens.albrecht.gmx.net
here is my problem:
Created a new 'Visual Class' with style 'SWT Application'.
Opened it in Visual Editor and a nice empty shell shows up.
First strange thing - Moving the mouse over the shell shows a message
'java.lang.IllegalArgumentException (Object is not an instance of =
declaring class)'
Doesn't mean much to me, so I ignore it. I select 'Button' from the 'SWT=
Controls' section on the palette and insert one on the shell.
The generated code references the correct SWT packages, but in the =
properties page for the button the entries rather correspond to an =
AWT-Button. E.g. there is 'Label' instead of 'Text'.
All in all I have the feeling that VE is somewhat undecided if I'm doing=
AWT or SWT.
Any idea what's going wrong?
Jens
Re: VE confuses SWT with AWT [message #70220 is a reply to message #70202] |
Sat, 06 November 2004 15:53  |
Hi Jeff,
it's cured. I need to have different Java versions on my machine but =
thought it would be enough to put 1.4.2 first in my path before starting=
eclipse. However, when I checked the project build path I indeed found a=
reference to an earlier jre.
Thanks for the quick help!
Jens
On Sat, 06 Nov 2004 10:08:53 -0500, Jeff Myers <myersj@nospam.gmail.com>=
wrote:
> Jens Albrecht wrote:
>> here is my problem:
>> First strange thing - Moving the mouse over the shell shows a message=
>> declaring class)'
>> Doesn't mean much to me, so I ignore it. I select 'Button' from the =
>> 'SWT Controls' section on the palette and insert one on the shell.
>> All in all I have the feeling that VE is somewhat undecided if I'm =
>> doing AWT or SWT.
>> Thanks
>> Jens
> Hi Jens,
> You must run a JRE 1.4.2 or higher when working with SWT. Prior to th=
at =
> there was a bug in Sun's bean info implementation that makes it use th=
e =
> first bean info for a class with the name it finds, regardless of =
> whether it is in the correct package. So it uses the bean info for =
> java.awt.Button when it should be using the bean info for =
> org.eclipse.swt.widgets.Button.
> So basically, you need to be using Java 1.4.2.
> - Jeff
Re: VE confuses SWT with AWT [message #602667 is a reply to message #70180] |
Sat, 06 November 2004 10:08  |
> here is my problem:
> declaring class)'
> doing AWT or SWT.
> Thanks
> Jens
Hi Jens,
You must run a JRE 1.4.2 or higher when working with SWT. Prior to that
there was a bug in Sun's bean info implementation that makes it use the
- Jeff
Re: VE confuses SWT with AWT [message #602675 is a reply to message #70202] |
Hi Jeff,
Jens
>> here is my problem:
>> declaring class)'
>> doing AWT or SWT.
>> Thanks
>> Jens
> Hi Jens,
at =
e =
> - Jeff
FUDForum. Page generated in 0.03359 seconds
