Home » Language IDEs » C / C++ IDE (CDT) » Clearcase
Clearcase [message #70177] Thu, 15 May 2003 09:59 Go to next message
Originally posted by: alan.richardson.ubsw.com
I've recently installed the cdt for eclipse and now I've installed the
clearcase plugin but eclipse does not pick up the plugin when I start
eclipse.
Any ideas.
Re: Clearcase [message #70197 is a reply to message #70177] Thu, 15 May 2003 11:39 Go to previous messageGo to next message
Originally posted by: rselrahc.nospam.hotmail.com
On Thu, 15 May 2003 13:59:04 +0000 (UTC), alan.richardson@ubsw.com
>eclipse.
>Any ideas.
>Thanks
Which ClearCase plugin did you install? The one from Rational or the
one from SourceForge?
/Charles
And I was told to add: "The opinions expressed in this message do not reflect the views of my employer."
Re: Clearcase [message #70215 is a reply to message #70177] Thu, 15 May 2003 11:41 Go to previous message
Hi Alan,
You do not mention specifically mention which versions of Eclipse and CDT
you are using which may be important.
There are installation instructions related to the ClearCase plug in at:
http://www.rational.com/support/downloadcenter/addins/clearc ase/plugins/index.jsp
Apparently the Team Interface has not changed between Eclipse 2.0 and
Eclipse 2.1, but I will verify this.
Cory
> eclipse.
> Any ideas.
> Thanks
Previous Topic:Getting OpenWatcom C++ to work under Eclipse??
Next Topic:GDB output onto eclipse console
Current Time: Sun Aug 31 18:20:17 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
