Home » Modeling » GMF (Graphical Modeling Framework) » Gmf rcp lite ...resize/move problem
Gmf rcp lite ...resize/move problem [message #70154] Thu, 26 October 2006 09:21 Go to next message
Originally posted by: matroska.libero.it
in gmf lite rich client application movement and resizing of figures is
only through fixed step (for example 5 pixels). I need single pixel
precision...What do i have to modify?
Thanks in advance
Tobia Loschiavo
Re: Gmf rcp lite ...resize/move problem [message #70174 is a reply to message #70154] Thu, 26 October 2006 09:32 Go to previous messageGo to next message
Hi John,
Please file a bugzilla. I will investigate and let you know when it is
fixed.
Boris
"John Slave" <matroska@libero.it> wrote in message
news:ehqcp7$c9a$1@utils.eclipse.org...
> Thanks in advance
> Tobia Loschiavo
Re: Gmf rcp lite ...resize/move problem [message #72621 is a reply to message #70154] Wed, 01 November 2006 08:27 Go to previous messageGo to next message
Hi John,
It turns out that this is a feature, not a bug :). (Moreover, it is present
in both lite and runtime-based versions. I was a bit misled by assuming it
is a lite-only problem).
You may have single-pixel precision by pressing ALT when dragging.
An alternative way is to modify the generated code (method getAdapter() in
the edit part for the diagram and compartments) to return null when being
adapted to SnapToHelper.class
Boris
> Thanks in advance
> Tobia Loschiavo
Re: Gmf rcp lite ...resize/move problem [message #72693 is a reply to message #72621] Wed, 01 November 2006 09:46 Go to previous messageGo to next message
Boris, John:
I think the behavior you are seeing is the "snap to grid" behavior. If
you turn "snap to grid" off in the "Rulers & Grid" properties section
does it work as you would like?
- Cherie
Boris Blajer wrote:
> Hi John,
> Best regards,
> Boris
>> Thanks in advance
>> Tobia Loschiavo
Re: Gmf rcp lite ...resize/move problem [message #72716 is a reply to message #72693] Wed, 01 November 2006 10:14 Go to previous message
Hi Cherie,
Unfortunately, your advice, while definitely helpful, does not apply to the
lite rcp version.
Boris
"Cherie Revells" <crevells@ca.ibm.com> wrote in message
news:eiac7k$f2h$2@utils.eclipse.org...
> Boris, John:
> you turn "snap to grid" off in the "Rulers & Grid" properties section does
> - Cherie
> Boris Blajer wrote:
>> Hi John,
>> present in both lite and runtime-based versions. I was a bit misled by
>> assuming it is a lite-only problem).
>> in the edit part for the diagram and compartments) to return null when
>> being adapted to SnapToHelper.class
>> Best regards,
>> Boris
>>> Hi,
>>> Thanks in advance
>>> Tobia Loschiavo
Previous Topic:Cannot modify resource set without a write transaction
Next Topic:Custom Actions
Current Time: Sun Jul 13 13:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.03004 seconds
