Home » Archived » M2M (model-to-model transformation) » ATL and RSA
ATL and RSA [message #6264] Thu, 11 January 2007 03:13 Go to next message
Originally posted by: anna.ruokonen.gmail.com
How can ATL results be loaded to Rational Software Architect? ATL seems
to output non-standard XMI format. Is there a converter available from
ATL XMI to standard XMI?
thanks,
Anna
Re: ATL and RSA [message #6308 is a reply to message #6264] Thu, 11 January 2007 07:03 Go to previous messageGo to next message
If you used the MDR model handler then RSA won't understand this format.
I have used ATL with RSA version 6 using the EMF model handler so I know
that the output of ATL was usable in RSA 6 (although it was a little while
ago).
Dave Kelsey
> thanks,
> Anna
Re: ATL and RSA [message #7789 is a reply to message #6308] Mon, 15 January 2007 07:24 Go to previous messageGo to next message
could you explain some more? What was the output format then (um2, xmi,
ecore)?
> ago).
> Dave Kelsey
>> thanks,
>> Anna
Re: ATL and RSA [message #7830 is a reply to message #7789] Mon, 15 January 2007 09:19 Go to previous message
In my case I was using ATL inside of RSA, so they were both using the same
version of EMF and UML2. UML2 uses EMF to serialise and I thought that EMF
uses xmi v2.0 as its serialisation format.
I used the EMF model handler so xmi v2 was used. There may be an issue if
you use a different version of EMF with ATL than the one used by RSA of course.
Dave Kelsey
> ecore)?
>> ago).
>> Dave Kelsey
>>> thanks,
>>> Anna
Previous Topic:[ATL] ATL and JAVA
Next Topic:[ATL] How to create non existent Class in new model
Current Time: Thu Jul 17 21:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.08583 seconds
