Home » Language IDEs » PHP Development Tools (PDT) » XDebug remote debugging problem
XDebug remote debugging problem [message #69978] Fri, 09 May 2008 18:43 Go to next message
Originally posted by: mokunk.gmail.com
I cannot get XDebug remote debugger working. The browser launches but the
server keeps executing beyond breakpoints. Eclipse does not seem to
receive any messages from the server.
XDebug local tracing works.
eclipse.exe is listening on 9000, which is open, but the connection never
gets established.
The environment is as follows:
Server
Windows NT 5.1
IIS 6.0
PHP 5.2.5
Xdebug php_xdebug-2.0.2-5.2.5.dll
Client
eclipse 3.3.1.1
Windows XP Firewall port 9000 open
Web Browser: Fire Fox 2.0.0.14 launches with
?XDEBUG_SESSION_START=ECLIPSE_DBGP&KEY=(some number)
xdebug.remote_enable="On"
xdebug.remote_host="xxx.xxx.xxx.ca"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
xdebug.remote_log="d:\xxx\xdebug.log" (It does not write any logs)
zend_extension_ts="c:\xxx\xxx\php_xdebug-2.0.2-5.2.5.dll"
Does it work with IIS? Does zend_extension_ts entry need to be before the
xdebug.remote_xxx entries?
I would appreciate it very much if anyone could help me.
Thank you,
Tomo
Re: XDebug remote debugging problem [message #70146 is a reply to message #69978] Mon, 12 May 2008 10:04 Go to previous messageGo to next message
Just to be sure, run a script on your remote server that executes phpinfo() to ensure xdebug is
actually being loaded and that the xdebug parameters are what you expect.
If they are correct, then your server is not able to establish a connection with your client, so
check that the server filewall is not blocking port 9000 outbound
Dave Kelsey
Tomo wrote:
> the server keeps executing beyond breakpoints. Eclipse does not seem to
> XDebug local tracing works. eclipse.exe is listening on 9000, which is
> open, but the connection never gets established.
> Server
> Windows NT 5.1
> IIS 6.0
> PHP 5.2.5
> Client
> eclipse 3.3.1.1
> the xdebug.remote_xxx entries?
> Thank you,
> Tomo
Re: XDebug remote debugging problem [message #70458 is a reply to message #70146] Tue, 13 May 2008 12:57 Go to previous messageGo to next message
phpinfo() displays what I expect. XDebug is loaded and I see all the
options for XDebug are set correctly. The port 9000 is open on the server.
Tomo
Re: XDebug remote debugging problem [message #70476 is a reply to message #70458] Tue, 13 May 2008 13:43 Go to previous messageGo to next message
I seem to remember that there are zend extensions that conflict with xdebug, but I can't remember
which ones did. There may be more info over at
http://www.xdebug.org
Dave Kelsey
> Tomo
Re: XDebug remote debugging problem [message #70823 is a reply to message #70476] Wed, 14 May 2008 15:35 Go to previous message
Hi Dave,
It worked after we changed the remote host name to the IP address.
Thank you for your help,
Tomo
Previous Topic:Re: Biggest Eclipse bug ever about Java?
Next Topic:Newbie Getting "print" output to browser during debug?
Current Time: Sun Jul 27 08:38:37 EDT 2025
Powered by FUDForum. Page generated in 0.04294 seconds
