XDebug remote debugging problem [message #69978] |
Fri, 09 May 2008 18:43  |
Originally posted by: mokunk.gmail.com
I cannot get XDebug remote debugger working. The browser launches but the
server keeps executing beyond breakpoints. Eclipse does not seem to
receive any messages from the server.
XDebug local tracing works.
eclipse.exe is listening on 9000, which is open, but the connection never
gets established.
The environment is as follows:
Server
Windows NT 5.1
IIS 6.0
PHP 5.2.5
Xdebug php_xdebug-2.0.2-5.2.5.dll
Client
eclipse 3.3.1.1
Windows XP Firewall port 9000 open
Web Browser: Fire Fox 2.0.0.14 launches with
?XDEBUG_SESSION_START=ECLIPSE_DBGP&KEY=(some number)
xdebug.remote_enable="On"
xdebug.remote_host="xxx.xxx.xxx.ca"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
xdebug.remote_log="d:\xxx\xdebug.log" (It does not write any logs)
zend_extension_ts="c:\xxx\xxx\php_xdebug-2.0.2-5.2.5.dll"
Does it work with IIS? Does zend_extension_ts entry need to be before the
xdebug.remote_xxx entries?
I would appreciate it very much if anyone could help me.
Thank you,
Tomo
FUDForum. Page generated in 0.05450 seconds
