Home » Language IDEs » PHP Development Tools (PDT) » XDebug with path mapper problem
XDebug with path mapper problem [message #6240] Sun, 18 March 2007 01:08 Go to next message
Originally posted by: apaz.yahoo.com
I'm using the XDebug plugin with the path mapper (v 0.1.4).
I found out that if there are multiple files with the same name and you
put a breakpoint on one of them file, when the breakpoint is reached
Eclipse doesn't necessarily open the correct file, but the first one it
finds on that project with the given name.
So for example, I have these files
Project/add/index.php
Project/test/index.php
And I put a breakpoint in Project/test/index.php, when the breakpoint is
reached, Eclipse shows the source code of "Project/add'index.php"
Is this a known issue? Will it be fixed in the next release? If not any
suggestions what might be causing this and where should I start looking
to fix it?
I think something similar (if not the same) was fixed on previous releases.
Thanks!
-a.
Re: XDebug with path mapper problem [message #6256 is a reply to message #6240] Sun, 18 March 2007 14:11 Go to previous messageGo to next message
Originally posted by: johan.bobsworld.be
Hello Andres
The same problem happend with me. It's a known bug but I'm not sure if
this get's fixed because the path mapper is only "quick hack" made by an
enthousiast.
The next version of XDebug will have an extension point for path mappers
and a simple path mapper example. Maybe Dave Kelsey can forsee this bug
for his next release of the XDebug plugin.
Johan Vandeweerd
Andres Paz wrote:
> to fix it?
> Thanks!
> -a.
Re: XDebug with path mapper problem [message #7535 is a reply to message #6256] Mon, 19 March 2007 06:38 Go to previous messageGo to next message
I suspect the problem with the PathMapper version is that it remaps the outbound
file name, but doesn't remap the inbound file name.
The extension point requires the implementer to handle both directions and the
sample one I have locates the correct file when you have 2 of the same name so
hopefully max will be able to re-implement his pathmapper to this interface and
this will resolve the problem.
I am still waiting for PDT 0.7 to be released so I provide a version that works
with that release.
regards
Dave Kelsey
Johan Vandeweerd wrote:
> Hello Andres
> enthousiast.
> Regards
> Johan Vandeweerd
> Andres Paz wrote:
>> you put a breakpoint on one of them file, when the breakpoint is
>> reached Eclipse doesn't necessarily open the correct file, but the
>> first one it finds on that project with the given name.
>> looking to fix it?
>> releases.
>> Thanks!
>> -a.
Re: XDebug with path mapper problem [message #8970 is a reply to message #7535] Fri, 23 March 2007 08:35 Go to previous message
Originally posted by: dominic.clifton.gr-tech.net
Hey Dave!
>outbound
That's where I was going to suggest the problem was. It definately appears
to make sense as pdt has to map the path when setting break points (before
the script is executed on the server (and while paused in the debugger,
before resuming) and in reverse when those breakpoints are hit by the php
interpreter.
Dom
Previous Topic:newbe again - lost auto variables
Next Topic:XDebug can't find my sources for remote launch
Current Time: Tue Jul 22 01:36:53 EDT 2025
Powered by FUDForum. Page generated in 0.03290 seconds
