Home » Eclipse Projects » Remote Application Platform (RAP) » How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog
How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog [message #69953] Mon, 14 January 2008 11:34 Go to next message
Originally posted by: augcampos.mailinator.com
Hi there,
The folloing code iterates for all components in a composite
for (int i = 0; i < this.getShell().getChildren().length; i++) {
final Control control = this.getShell().getChildren()[i];
control.setEnabled(false);
How can I do the same in a dialog (org.eclipse.jface.dialogs.dialog)
Augusto Campos
Critical Software
Re: How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog [message #69972 is a reply to message #69953] Mon, 14 January 2008 12:38 Go to previous messageGo to next message
as Dialog is a subclass of the JFace Window you can use
Window#getShell() in the same manner. Usually this is a question for the
rcp/newcomer/platform newsgroups.
Greets
Benny
Augusto Campos wrote:
> Hi there,
> Augusto Campos
> Critical Software
Re: How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog [message #69992 is a reply to message #69972] Mon, 14 January 2008 13:01 Go to previous messageGo to next message
Hi again...
I already try that but on configureShell but I get null! Do I have to user it on a different method
(is a modal dialog)
Thanks in advance.
Benjamin Muskalla wrote:
> Greets
> Benny
>> Hi there,
>> Augusto Campos
>> Critical Software
Re: How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog [message #70089 is a reply to message #69992] Tue, 15 January 2008 03:49 Go to previous message
Originally posted by: fappel.innoopract.com
I assume that configureShell is too early in the dialog's lifecycle. Maybe
you are luckier using createContents...
Ciao
Frank
"Augusto Campos" <augcampos@mailinator.com> schrieb im Newsbeitrag
news:fmg81e$iif$1@build.eclipse.org...
> Hi again...
> it on a different method (is a modal dialog)
> Thanks in advance.
>> as Dialog is a subclass of the JFace Window you can use Window#getShell()
>> Greets
>> Benny
>>> Hi there,
>>> Augusto Campos
>>> Critical Software
Previous Topic:Nebula widgets in RAP
Next Topic:Tomcat deployment without Equinox
Current Time: Sat Aug 16 15:09:03 EDT 2025
Powered by FUDForum. Page generated in 0.04452 seconds
