Home » Eclipse Projects » GEF » Problems with the example HelloGef2
Problems with the example HelloGef2 [message #69915] Thu, 13 March 2003 08:54 Go to next message
Originally posted by: grandan.tiscali.it
Dear GEF users
I've got a problem with the basic example named HelloGef2.
I followed the instructions to install this example, but I get this error
on the class "HelloConnectionEditPart.java":
Class must implement the inherited abstract method
org.eclipse.gef.editparts.AbstractEditPart.createEditPolicie s()
Is there someone who tried to implement this method? If yes, can you send
me the complete example, please?
How can I resolve this problem? Is it a problem of Eclipse/GEF version?
Can you tell me which version I have to use?
Thank you very much, I hope you can help me!
Daniele
Re: Problems with the example HelloGef2 [message #69994 is a reply to message #69915] Thu, 13 March 2003 10:17 Go to previous message
The HelloGef example was not written by the GEF development team. It
probably does not compile now due to API changes. You might be able to load
it as source and fix the errors yourself.
"Daniele" <grandan@tiscali.it> wrote in message
news:b4q2ib$jde$1@rogue.oti.com...
> Dear GEF users
> Daniele
Previous Topic:Simple Question about Create and Add commands in Logic example
Next Topic:GEF EditParts and SWT
Current Time: Sat Aug 30 21:27:38 EDT 2025
Powered by FUDForum. Page generated in 0.03584 seconds
