Home » Language IDEs » PHP Development Tools (PDT) » Runtime error in the browser output view
Runtime error in the browser output view [message #6213] Sat, 17 March 2007 12:00 Go to next message
Hi all,
Every time I switch back into eclipse after running/debugging a site I get
a pop dialog box saying:
Error: A runtime error has occurred. Do you wish to debug? Error on line
1. Error: syntax error.
The site launches and operates as expected. Is there anyway to prevent
output from going to the browser output view or setup this out to work
correctly? I am using an external browser (firefox) for output so I don't
know why there's output in the browser output view in the first place.
Nathan.
Re: Runtime error in the browser output view [message #6225 is a reply to message #6213] Sat, 17 March 2007 13:16 Go to previous messageGo to next message
Update:
It turns out that the error isn't stemming from the browser output view
but the debug output view. Is there a way to turn this automatic behavior
off?
Thanks.
Nathan.
Re: Runtime error in the browser output view [message #20525 is a reply to message #6225] Tue, 15 May 2007 06:00 Go to previous messageGo to next message
Originally posted by: eclipse.milesoft.de
maybe you already fixed your problem - please let me know.
I got javascript errors and ugly pages due to the fact that the
html-header (including the style sheets and js files) was not loaded into
the browser output (looks kind of).
So one possibiltiy to fix the problem is to close the (debug or browser)
output view and store the perspective.
At least it works for me.
Hope that helps,
Martin
Re: Runtime error in the browser output view [message #91693 is a reply to message #20525] Fri, 23 January 2009 19:50 Go to previous messageGo to next message
Anyone know how to fix this problem? I try closing the debug and
browser view but still the same "Runtime error" message comes up.
Re: Runtime error in the browser output view [message #91735 is a reply to message #91693] Fri, 23 January 2009 20:34 Go to previous messageGo to next message
Originally posted by: nickboldt.gmail.com
Anything in the console or error view? You gotta give a little to get a
little.
http://wiki.eclipse.org/IRC_FAQ#How_do_I_debug_Eclipse.3F_Ho w_can_I_see_what_plugins_are_being_started.3F_How_do_I_start _the_OSGi_console.3F
What are you doing to cause this error?
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: Runtime error in the browser output view [message #91821 is a reply to message #91735] Sat, 24 January 2009 01:21 Go to previous messageGo to next message
I'm sorry my message is out of context. I was trying to reply to this
thread:
http://dev.eclipse.org/newslists/news.eclipse.tools.pdt/msg0 0046.html
I just start debugging, the debugger stop at the first line. I hit
Resume(F8). Then I reload the page the second time at the browser,
the debugger again stop at the first line. I hit Resume(F8) again. Now
this time reload the page, and there after, I get this "Runtime Error
.... Syntax Error" message. Keep clicking "No" makes it go away and
debugger is at the first line. From this point on, everytime the
debugger stop at first line or any break point, this "Runtime
Error...Syntax Error" comes up.
I added "-consolelog
-debug
-console" to eclipse.ini and restart PDT. Where is the "Equinox OSGi
console"? I don't see it. How do I bring it up to see the log?
Re: Runtime error in the browser output view [message #91836 is a reply to message #91821] Sat, 24 January 2009 04:20 Go to previous messageGo to next message
If you are using xdebug as your debugger you can turn off the ability to capture output and send it
to the debug and browser views.
Go to window-->preferences
expand PHP
expand Debug
select Installed Debuggers
select xdebug and press configure
change the Output Capture Settings from Copy to Off
and see if that helps. If it does then the problem is probably the Browser view.
For more info on using xdebug with PDT please check out the guide in the document section
http://www.eclipse.org/pdt/docs.php
Dave Kelsey
> thread:
> -debug
Re: Runtime error in the browser output view [message #91894 is a reply to message #91836] Sat, 24 January 2009 15:44 Go to previous message
Bingo! turning "Output Capture" to "Off" got rid of the problem!
I actually downloaded that last night and read about half way. Very
thorough document. Thank you!
Previous Topic:How to work with javascript?
Next Topic:How to install PDT using "Software Updates"?
Current Time: Mon Sep 01 08:00:17 EDT 2025
Powered by FUDForum. Page generated in 0.29508 seconds
