Setting up a project make [message #69724] |
Sun, 11 May 2003 18:10  |
Originally posted by: chris.javadisciple.com
Under Windows XP I've installed the CDT into Eclipse. Everything seems
to be installed and functional, but I am not sure how to configure the
project make functions.
I have installed cygwin, giving me a compiler, make, and debug utility.
I can invoke these from a command line and they work fine. From inside
Eclipse, "Build Project" produces:
*** No rule to make target 'clean'.
I added a "clean" section to the makefile, but that didn't seem to help.
Any guidance would be appreciated.
I've done my best to comb through the instructions that I can find, but
I must be just missing this.
Chris Rehm
chris@javadisciple.com
Thou shalt not avenge, nor bear any grudge against the children of thy
people, but shalt love thy neighbour as thyself. [Lev. 19:18]
Re: Setting up a project make [message #69744 is a reply to message #69724] |
Sun, 11 May 2003 22:52   |
Originally posted by: billhao.hotmail.com
this is one of my makefile, maybe some help to you
objects = hello.o
LIB_DIR = D:\MinGW\lib\gcc-lib\mingw32\3.2
GCC = gcc
COMPILE_OPTS = -Wno-deprecated
#COMPILE_OPTS = -Wno-deprecated/#
hello : $(objects) header.o
$(GCC) -o hello $(objects) header.o -L $(LIB_DIR) -lstdc++ $(COMPILE_OPTS)
@echo build finish
$(objects) : main.cpp
$(GCC) -c main.cpp $(COMPILE_OPTS)
header.o : header.h header.cpp
$(GCC) -c header.cpp $(COMPILE_OPTS)
all : hello
..PHONY : clean
clean :
-del hello.exe
-del hello.o
-del header.o
bill
e-mail: billhao@hotmail.com
MSN Messenger: billhao@hotmail.com
Web: http://www.minivoice.com
"Chris Rehm" <chris@javadisciple.com> ????
news:3EBECA67.7090303@javadisciple.com...
> Chris Rehm
Re: Setting up a project make [message #69878 is a reply to message #69744] |
Mon, 12 May 2003 12:29  |
Bill,
I think I've found the problem. When I created my test project to try
out the eclipse/CDT environment, I created a folder in the test project
and put my source in that folder.
It seems that make won't run correctly unless I move the source into the
project and out of my subfolder.
I'd only created the subfolder because I don't have any idea how things
end up looking after lots of sources are added and I thought I'd try for
some organization.
Thanks for the help!
Chris Rehm
FUDForum. Page generated in 0.32377 seconds
