Home » Language IDEs » C / C++ IDE (CDT) » Setting up a project make
Setting up a project make [message #69724] Sun, 11 May 2003 18:10 Go to next message
Originally posted by: chris.javadisciple.com
Under Windows XP I've installed the CDT into Eclipse. Everything seems
to be installed and functional, but I am not sure how to configure the
project make functions.
I have installed cygwin, giving me a compiler, make, and debug utility.
I can invoke these from a command line and they work fine. From inside
Eclipse, "Build Project" produces:
*** No rule to make target 'clean'.
I added a "clean" section to the makefile, but that didn't seem to help.
Any guidance would be appreciated.
I've done my best to comb through the instructions that I can find, but
I must be just missing this.
Chris Rehm
chris@javadisciple.com
Thou shalt not avenge, nor bear any grudge against the children of thy
people, but shalt love thy neighbour as thyself. [Lev. 19:18]
Re: Setting up a project make [message #69744 is a reply to message #69724] Sun, 11 May 2003 22:52 Go to previous messageGo to next message
Originally posted by: billhao.hotmail.com
this is one of my makefile, maybe some help to you
objects = hello.o
LIB_DIR = D:\MinGW\lib\gcc-lib\mingw32\3.2
GCC = gcc
COMPILE_OPTS = -Wno-deprecated
#COMPILE_OPTS = -Wno-deprecated/#
hello : $(objects) header.o
$(GCC) -o hello $(objects) header.o -L $(LIB_DIR) -lstdc++ $(COMPILE_OPTS)
@echo build finish
$(objects) : main.cpp
$(GCC) -c main.cpp $(COMPILE_OPTS)
header.o : header.h header.cpp
$(GCC) -c header.cpp $(COMPILE_OPTS)
all : hello
..PHONY : clean
clean :
-del hello.exe
-del hello.o
-del header.o
bill
e-mail: billhao@hotmail.com
MSN Messenger: billhao@hotmail.com
Web: http://www.minivoice.com
"Chris Rehm" <chris@javadisciple.com> ????
news:3EBECA67.7090303@javadisciple.com...
> Chris Rehm
Re: Setting up a project make [message #69763 is a reply to message #69744] Mon, 12 May 2003 02:07 Go to previous messageGo to next message
Thank you for the example, Bill. I appreciate having it and will keep it
handy. I'm not getting any further, though. Can you tell me what you
have for your build command in the project settings?
Chris Rehm
Re: Setting up a project make [message #69878 is a reply to message #69744] Mon, 12 May 2003 12:29 Go to previous message
Bill,
I think I've found the problem. When I created my test project to try
out the eclipse/CDT environment, I created a folder in the test project
and put my source in that folder.
It seems that make won't run correctly unless I move the source into the
project and out of my subfolder.
I'd only created the subfolder because I don't have any idea how things
end up looking after lots of sources are added and I thought I'd try for
some organization.
Thanks for the help!
Chris Rehm
Previous Topic:Help on GDBMI Interface
Next Topic:An unexpected exception in native code outside the VM
Current Time: Mon Sep 22 15:32:10 EDT 2025
Powered by FUDForum. Page generated in 0.06614 seconds
