Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo: Yet another DuplicateMappingException problem
teneo: Yet another DuplicateMappingException problem [message #69718] |
Wed, 31 January 2007 16:42  |
I too am having a problem with a Duplicate<appingException being thrown. I have added the QUALIFY_ENTITY_NAME property with the value QUALIFY_ENTITY_NAME_NSPREFIX and still get the duplicate mapping exception. The complete exception trace is:
Exception in thread "main" org.hibernate.DuplicateMappingException: duplicate import: InterfaceCard refers to both cisco3800.InterfaceCard and types.InterfaceCard (try using auto-import="false")
at org.hibernate.cfg.Mappings.addImport(Mappings.java:141)
at org.hibernate.cfg.HbmBinder.bindPersistentClassCommonValues( HbmBinder.java:614)
at org.hibernate.cfg.HbmBinder.bindClass(HbmBinder.java:527)
at org.hibernate.cfg.HbmBinder.bindJoinedSubclass(HbmBinder.jav a:848)
at org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2202)
at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:153)
at org.hibernate.cfg.Configuration.add(Configuration.java:424)
at org.hibernate.cfg.Configuration.addXML(Configuration.java:38 4)
at org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:364)
at org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:156)
at org.ziptie.cisco.cs3800Load.doLoadDoc(cs3800Load.java:63)
There are two XSDs (one included by the other) with different namespaces, each with a type definition for InterfaceCard. The including XSD extends the type of the included namespace. When I look at the mapping, the entity-name fields are unique (they have the namespaces prefixed) and the descriminator fields are unique (again, the namespace is prefixed). In fact, everything is unique with the exception of the meta tag for "eclassName" - they are both InterfaceCard without any namespace prefixes.
I tried both the default and the "JOINED" Inheritance mapping strategies and both result in the same exception although the mappings are obviously a bit different. Here is the mapping for these types using the default inheritance strategy:
<subclass entity-name="types.InterfaceCard" abstract="false" lazy="false" extends="types.Card" discriminator-value="types.InterfaceCard">
<meta attribute="eclassName">InterfaceCard</meta>
<meta attribute="epackage">http://www.ziptie.org/1.0/zipTypes</meta>
<list name="port" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`interfacecard_port_id`" not-null="false" unique="false"/>
</key>
<list-index column="`interfacecard_port_idx`"/>
<one-to-many entity-name="types.Port"/>
</list>
</subclass>
<subclass entity-name="cisco3800.InterfaceCard" abstract="false" lazy="false" extends="types.InterfaceCard" discriminator-value="cisco3800.InterfaceCard">
<meta attribute="epackage">http://www.ziptie.org/cisco3800</meta>
<property name="icType" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`ictype`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass">org.ziptie.cisco3800.IcTypeType</param>
</type>
</property>
</subclass>
And here is the mapping for the JOINED strategy:
<joined-subclass entity-name="types.InterfaceCard" abstract="false" lazy="false" extends="types.Card" table="`interfacecard`">
<key>
<column name="`card_id`"/>
</key>
<key update="true">
</key>
</list>
</joined-subclass>
<joined-subclass entity-name="cisco3800.InterfaceCard" abstract="false" lazy="false" extends="types.InterfaceCard" table="`interfacecard`">
<key>
<column name="`interfacecard_id`"/>
</key>
</type>
</property>
</joined-subclass>
Like the default inheritance strategy, the entity-names are unique and the meta attribute eclassName is not. However, note that the table names are the same. That is probably bad mojo.
Outside of hand editing the generated hbm file, is there some other way to fix or control this behavior?
Brian
Re: teneo: Yet another DuplicateMappingException problem [message #69741 is a reply to message #69718] |
Wed, 31 January 2007 16:59   |
I looked in the hibernate source and it seems that auto-import="false" can get rid of this error.
For now this has to be done manually, in the top-tag in the hbm.xml set the attribute
auto-import="false":
<hibernate-mapping
schema="schemaName" (1)
default-cascade="none|save-update" (2)
auto-import="true|false" (3)
package="package.name" (4)
Let me know if this works then I'll add this as an option in Teneo.
gr. Martin
> at
> at
> at
> at
> namespace prefixes.
> <meta
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </subclass>
> <type
> <param
> </type>
> </property>
> </subclass>
> <meta
> <key>
> </key>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </joined-subclass>
> <key>
> </key>
> <type
> <param
> </type>
> </property>
> </joined-subclass>
> Brian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo: Yet another DuplicateMappingException problem [message #69761 is a reply to message #69741] |
Wed, 31 January 2007 18:13   |
I changed to use the statically built hbm.xml file and set auto-import to false. Hibernate was able to load the mapping file and create the tables. So if you can let us set auto-import to false as a persistence option or automatically set it for cases when QUALIFY_ENTITY_NAME is set to use the namespace prefix, that would be cool.
I still have one problem. When I use the JOINED inheritance strategy, it specifies the same table name for the two types. The latter definition overrides the former and I only get a single table.
Brian
> the attribute auto-import="false":
> <hibernate-mapping
> gr. Martin
>> at
>> at
>> at
>> at
>> <meta
>> <key update="true">
>> </key>
>> </list>
>> </subclass>
>> <type
>> <param
>> </type>
>> </property>
>> </subclass>
>> <meta
>> <key>
>> </key>
>> <key update="true">
>> </key>
>> </list>
>> </joined-subclass>
>> <key>
>> </key>
>> <type
>> <param
>> </type>
>> </property>
>> </joined-subclass>
>> Thanks,
>> Brian
Re: teneo: Yet another DuplicateMappingException problem [message #69801 is a reply to message #69780] |
Thu, 01 February 2007 00:49   |
I'll change the following:
set auto-import to false when qualify-entity names is set to nsprefix
include nsprefix in the default table name in case of qualify entity name
In the meantime you can use a table annotation on the eclass to set a different table name.
Btw, the meta eclass tag is not unique because it also has an accompanying epackage tag.
gr. Martin
Brian Vetter wrote:
> BTW, I'd like the behavior to be that the name of the tables were
> prefixed with the namespace prefix. If this isn't the default, I'd like
> to have a way to control/force it.
> Brian
>> Brian
The Netherlands
Teneo: Persistence Mapping XML files for multiple namespaces; was: Yet another DuplicateMappingExcep [message #69840 is a reply to message #69801] |
Thu, 01 February 2007 12:55   |
I'd like to maintain the persistence mappings outside of the original XSD files if possible. I believe I can do this using the PERSISTENCE_XML option to provide a resource file. However, I have some questions on how this will work if there are multiple XSDs with multiple namespaces. Here are the scenarios:
- Each "resource" type has its own XSD and namespace.
- There are several namespaces that are common to all of the resource types. These common namespaces and their type/element definitions are imported into each of the resource type XSDs.
- Resource types can be added dynamically to a system (through either importing new Jars or perhaps in the future, the use of dynamic APIs).
- Each resource type may have their own persistence mapping strategies for the types they introduce.
- Two separate installations/deployments may want to use the core XSDs for resource typing, but may want to have different persistence strategies.
Because of this last point, we want to keep the persistence mapping directives out of the core XSDs and potentially replace the mapping strategies for each of the resource XSDs. Sharing of the XSDs is important. Sharing the persistence mappings is less important and perhaps not possible.
In looking through the example persistence mapping file examples, it wasn't clear to me first if it was possible to have multiple active mapping files. Second, it wasn't clear to me how it would deal with multiple namespaces, especially when the base type names may be the same for two types in different namespaces.
Also, it appears that the separate XML examples are using the mapped ecore types although the modeling dudes here are using XSDs.
Am I missing something important? Any suggestions on how I might best organize the mapping files and the XSDs?
Brian
Re: Teneo: Persistence Mapping XML files for multiple namespaces; was: Yet another DuplicateMappingE [message #69861 is a reply to message #69840] |
Thu, 01 February 2007 15:00   |
Hi Brian,
Yes keeping the annotations outside of the xsd is a good approach. It keeps your model clean.
Currently you can only specify one xml file with additional mapping directives. Please enter a
bugzilla if you require support for multiple xml annotation files.
The xml annotation file can contain multiple epackages so this should work fine (see the xsd) for
your case (having eclasses with the same name).
Regarding the mapped ecore type use in the annotation xml. There is no other way but normally you
should be able to easily determine the eclass/efeature name from the xsd element definitions (the
names should be the same).
Btw, the build of today should solve your auto-import and tablename issue.
gr. Martin
> Brian
The Netherlands
Re: teneo: Yet another DuplicateMappingException problem [message #70142 is a reply to message #70125] |
Fri, 02 February 2007 09:48   |
In case of the same eclass name occuring in different epackages then you need to set the
PersistenceOptions.QUALIFY_ENTITY_NAME option to PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX.
This will also qualify the table name for all eclasses (added in the release yesterday).
What I understand is that you use a single table inheritance mapping. In this case the table
annotation does not work for a subclass as a subclass is stored in the same table as its superclass.
The table annotation is usefull for joined-subclass inheritance mapping and in case of single-table
for the roots of the inheritance hierarchy.
Teneo should not add a table attribute to a subclass tag (maybe report a warning if a table
annotation is found). Can you enter a bugzilla for that?
gr. Martin
> And from one of Brian's messages:
> I believe I stumbled across exactly this problem. I have two classes
> named "Attribute" intwo different packages. When I simply use Teneo's
> default mapping, I get this error:
> [INFO ] duplicate import: Attribute->Attribute
> [INFO ] Mapping subclass: Attribute -> instance
> Duplicate class/entity mapping Attribute
> at org.hibernate.cfg.Mappings.addClass(Mappings.java:118)
> at org.hibernate.cfg.HbmBinder.handleSubclass(HbmBinder.java:22 12)
> at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:149)
> at org.hibernate.cfg.Configuration.add(Configuration.java:669)
> at org.hibernate.cfg.Configuration.addXML(Configuration.java:44 0)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:367)
> at
> at paladin.TeneoTest.main(TeneoTest.java:51)
> So I figured that Teneo does not qualify the table names, and looked for
> a way to influence the mapping. I did this:
> <persistence-mapping xmlns="http://www.eclipse.org/emft/teneo">
> <epackage namespace-uri="http:///p/m/xml.ecore">
> <eclass name="Attribute">
> <table name="XMLAttribute"/>
> </eclass>
> </epackage>
> </persistence-mapping>
> I set the PERSISTENCE_XML property accordingly and got this one:
> DEBUG] located
> [http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd] in classpath
> [ERROR] Error parsing XML: XML String(1253) Attribute "table" must be
> declared for element type "subclass".
> Exception in thread "main" org.hibernate.MappingException: invalid mapping
> at org.hibernate.cfg.Configuration.addXML(Configuration.java:43 8)
> at
> at
> Caused by: org.xml.sax.SAXParseException: Attribute "table" must be
> So I looked at the mapping file that was generated... of all subclass
> elements, only ONE actually had a table attribute, the one for my
> Attribute that I wanted to rename. All others didn't. So i looked at the
> Hibernate-Mapping DTD and was surprised to see that subclass elements
> are not even supposed to have table elements.
> What am I missing here? Am I using the wrong way to rename the table for
> conflicting entities?
> I actually would prefer manual conflict resolution instead of having the
> table names be qualified (I understand that this is the solution you
> have been working on).
> Regards
> Jürgen
The Netherlands
Re: Another issue: hibernate.cfg.xml ignored? [message #70182 is a reply to message #70162] |
Fri, 02 February 2007 10:59  |
Hmm the hibernate.cfg.xml should work afaics (I would need to look in more detail to see why this
would not work). You can also pass all the hibernate configuration properties programmatically using
the setHibernateProperties on the HbDataStore or place a hibernate.properties file in the root of
the classpath. See here:
http://www.elver.org/hibernate/tutorialone/tutorial1_2.html
gr. Martin
JG wrote:
>> need to set the PersistenceOptions.QUALIFY_ENTITY_NAME option to
>> PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX. This will also qualify
>> this case the table annotation does not work for a subclass as a
> Funny thing is, some thought like that had already crossed my mind
> ("Hey, there's only one table, how should that work."), but I thought
> that it was a conflict with the type tag in the single table, and that
> setting the table override would do the trick.
>> and in case of single-table for the roots of the inheritance hierarchy.
>> warning if a table annotation is found). Can you enter a bugzilla for that?
> Done. :-)
> I got another issue: I placed a hibernate.cfg.xml into the root of my
> EMF model package structure, in order to configure Hibernate.
> Apparently, this file is ignored. Do I have to set hibernate properties
> programmatically?
> Regards
> Jürgen
The Netherlands
Re: teneo: Yet another DuplicateMappingException problem [message #601887 is a reply to message #69718] |
<hibernate-mapping
gr. Martin
> at
> at
> at
> at
> namespace prefixes.
> <meta
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </subclass>
> <type
> <param
> </type>
> </property>
> </subclass>
> <meta
> <key>
> </key>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </joined-subclass>
> <key>
> </key>
> <type
> <param
> </type>
> </property>
> </joined-subclass>
> Brian
The Netherlands
Re: teneo: Yet another DuplicateMappingException problem [message #601893 is a reply to message #69741] |
Brian
> <hibernate-mapping
> gr. Martin
>> at
>> at
>> at
>> at
>> <meta
>> <key update="true">
>> </key>
>> </list>
>> </subclass>
>> <type
>> <param
>> </type>
>> </property>
>> </subclass>
>> <meta
>> <key>
>> </key>
>> <key update="true">
>> </key>
>> </list>
>> </joined-subclass>
>> <key>
>> </key>
>> <type
>> <param
>> </type>
>> </property>
>> </joined-subclass>
>> Thanks,
>> Brian
Re: teneo: Yet another DuplicateMappingException problem [message #601900 is a reply to message #69761] |
Wed, 31 January 2007 19:44  |
BTW, I'd like the behavior to be that the name of the tables were prefixed with the namespace prefix. If this isn't the default, I'd like to have a way to control/force it.
Brian
> Brian
Re: teneo: Yet another DuplicateMappingException problem [message #601907 is a reply to message #69780] |
gr. Martin
> Brian
>> Brian
The Netherlands
Teneo: Persistence Mapping XML files for multiple namespaces; was: Yet another DuplicateMappingExcep [message #601921 is a reply to message #69801] |
Brian
Re: Teneo: Persistence Mapping XML files for multiple namespaces; was: Yet another DuplicateMappingE [message #601928 is a reply to message #69840] |
Hi Brian,
gr. Martin
> Brian
The Netherlands
Re: teneo: Yet another DuplicateMappingException problem [message #602027 is a reply to message #69801] |
Fri, 02 February 2007 09:30  |
</eclass>
</epackage>
DEBUG] located
Jürgen
Re: teneo: Yet another DuplicateMappingException problem [message #602036 is a reply to message #70125] |
gr. Martin
> at
> at
> </eclass>
> </epackage>
> DEBUG] located
> at
> at
> Regards
> Jürgen
The Netherlands
Another issue: hibernate.cfg.xml ignored? (was: Re: teneo: Yet another DuplicateMappingException pro [message #602043 is a reply to message #70142] |
Fri, 02 February 2007 10:29  |
Done. :-)
programmatically?
Jürgen
Re: Another issue: hibernate.cfg.xml ignored? [message #602049 is a reply to message #70162] |
gr. Martin
> Done. :-)
> programmatically?
> Regards
> Jürgen
The Netherlands
Current Time: Tue Jul 08 23:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.22180 seconds
