Home » Eclipse Projects » Remote Application Platform (RAP) » Nebula widgets in RAP
Nebula widgets in RAP [message #69699] Thu, 10 January 2008 04:43 Go to next message
Originally posted by: benedikt.arnold.beyondsoft.de
I filed a feature request against the nebula project. I asked if they could
use Import-Package instead of Require-Bundle.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214867
With Import-Package it would be easy to use nebula widgets in RAP in the
future. Ok there are some limitations because RWT has not a 100% compatible
SWT-Api, but thats not a nebula problem. The limitations that I encountered
are missing key listeners, but implementing this is targeted for RAP 1.1M2
if the Plan is correct.
Greetings,
Ben
Benedikt Arnold
wadenkrampf.blogspot.com
Re: Nebula widgets in RAP [message #69795 is a reply to message #69699] Fri, 11 January 2008 06:35 Go to previous messageGo to next message
Originally posted by: lars.martin.smb-tec.com
Benedikt Arnold wrote:
> Greetings,
> Ben
This would be a nice extension. Is anyone willing to work on this?
Regards, Lars
Re: Nebula widgets in RAP [message #70425 is a reply to message #69699] Thu, 17 January 2008 02:28 Go to previous messageGo to next message
Hi Benedikt,
at least the DateChooser widget should be no problem.
As there is a working DateChooser widget in qooxdoo
(i.e. the underlying javascript framework for RAP) it is possible
to implement such a widget in RAP.
We've already done this in our project.
You can check the forum and the RAP Project site for any help on how
to implement your own custom widgets.
Oliver
Benedikt Arnold schrieb:
> Greetings,
> Ben
Re: Nebula widgets in RAP [message #70645 is a reply to message #70425] Fri, 18 January 2008 02:49 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
Hi Oliver,
do I understand you answer correctly that you have a RAP DateChooser widget
based on the qooxdoo DateChooser? Is there any chance to open this
implementation to others?just asking :-)
Ciao
Frank
"Poncho" <sasfatu@gmx.de> schrieb im Newsbeitrag
news:fmn023$59p$1@build.eclipse.org...
> Hi Benedikt,
> Regards
> Oliver
>> could use Import-Package instead of Require-Bundle.
>> compatible SWT-Api, but thats not a nebula problem. The limitations that
>> I encountered are missing key listeners, but implementing this is
>> targeted for RAP 1.1M2 if the Plan is correct.
>> Greetings,
>> Ben
Re: Nebula widgets in RAP [message #70692 is a reply to message #70645] Fri, 18 January 2008 03:56 Go to previous message
Hi Frank,
Positive. Allthough it is working there's still some work to do.
I will ask big chief of our tribe ;-)
Oliver
Frank Appel schrieb:
> Hi Oliver,
> Ciao
> Frank
>> Hi Benedikt,
>> Regards
>> Oliver
>>> Hi,
>>> Greetings,
>>> Ben
Previous Topic:RAP update site down?
Next Topic:How to iterate from all components in a shell in org.eclipse.jface.dialogs.dialog
Current Time: Thu Jul 17 04:49:38 EDT 2025
Powered by FUDForum. Page generated in 0.06907 seconds
