adding an import to a schema and validating [message #69690] |
Fri, 08 September 2006 10:45  |
Originally posted by: x86core.yahoo.com
I was wondering how I should add an import to a XSDSchema object and
validate the schema with the added import. I have looked up the newsgroup
but could not get much. The example code was not helpful in this regard
either. I have been trying to execute the following code without much
avail.
<code>
private void addImport(String nameSpace, String absolutePath,
XSDSchema resolvedSchema) {
XSDSchema schema = null;
XSDImport impDirective = XSDFactory.eINSTANCE.createXSDImport();
impDirective.setNamespace(nameSpace);
impDirective.setSchemaLocation(absolutePath);
impDirective.setResolvedSchema(resolvedSchema);
// schema.getReferencingDirectives().add(impDirective); //this does not
// work either
schema.getContents().add(impDirective); // this result in an error The
// sdDiagnostics say the import is not allowed by constraint
// expecting type......
schema.clearDiagnostics();
schema.validate();
<code/>
Thanks and regards,
Nero.
Re: adding an import to a schema and validating [message #69730 is a reply to message #69711] |
Fri, 08 September 2006 13:36  |
Thanks.I will try out your suggestion and post back.Regarding the
resolving of schemas.Totally agree with you that its something that i
should leave the schema to do.But I have certainly noticed some problems
with resolution of imports/includes....some problems with schemalocations
and relative paths.I may not be able to illustrate this....as this was
some time back.....so I would justify it by saying i have a small
mechanism to ensure things ....just to be sure.If i can recollect the
problem i'll try to produce some sample files and the exact problem.
Re: adding an import to a schema and validating [message #598743 is a reply to message #69690] |
Fri, 08 September 2006 11:23  |
Nero,
Note that imports must appear before any definitions or declarations in
the schema's contents. So probably doing schema.getContents().add(0,
impDirective) will do the trick. And typically the resolved schema is
computed from the schemaLocation in the context of the containing schema
to which you add the directive, i.e., it's not something you usually set
directly.
> newsgroup but could not get much. The example code was not helpful in
> this regard either. I have been trying to execute the following code
> without much avail.
> <code>
> does not
> // work either
> error The
> schema.validate();
> <code/>
> Thanks and regards,
> Nero.
Re: adding an import to a schema and validating [message #598748 is a reply to message #69711] |
FUDForum. Page generated in 0.14209 seconds
