Home » Eclipse Projects » Remote Application Platform (RAP) » RAP update site down?
RAP update site down? [message #69602] Wed, 09 January 2008 18:23 Go to next message
Originally posted by: karlpfeil.yahoo.com
Today I wanted to install eclipse SDK 3.4M4 together with RAP.
But when I download RAP from
http://download.eclipse.org/technology/rap/update-site as described in the
GettingStarted documentation, a dialog opens: "No features found on the
selected site(s). Choose a different site or category". What may be the
problem?
- update site down?
- 3.4M4 incompatible with RAP?
- previously I used the sun JDK, now gcj (ubuntu linux).
How can I get more output than this short dialog?
Is there another way to install RAP without using the update site? I
downloaded
http://www.eclipse.org/downloads/download.php?file=/technolo gy/rap/rap-sdk-1.1-M1-site-20080107-1838.zip,
and copied everything below the plugin/ and features/ directory from the
zip file into the corresponding directories of the eclipse installation.
Causing some 100 errors...
Karl
Re: RAP update site down? [message #69639 is a reply to message #69602] Thu, 10 January 2008 02:32 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Karl,
thanks for the hint. The RAP Tooling works with Eclipse 3.3 and 3.4M4. I
assume that something is wrong with the update-site and will look into
this as soon as possible.
Meanwhile you can use the zipped download-site you mentioned. To install
it,
- unzip the download into a convenient location
- start Eclipse
- Help menu > Software Updates > Find and Install...
- in hte upcoming wizard dialog, choose "Search for new Features..."
and click "Next"
- click the "New local site" button and choose the directory in
which you unzipped the download
- in the upcoming dialog, confirm the name for the update-site
from here on proceed as before.
Rüdiger
> the GettingStarted documentation, a dialog opens: "No features found on
> the selected site(s). Choose a different site or category". What may be
> the problem?
> - update site down?
> downloaded
> Karl
Re: RAP update site down? [message #69679 is a reply to message #69602] Thu, 10 January 2008 03:04 Go to previous message
Karl,
the update-site is back to work.
again, thanks for your hint,
Rüdiger
> the problem?
> - update site down?
> downloaded
> Karl
Previous Topic:Strike through font?
Next Topic:Nebula widgets in RAP
Current Time: Sun Aug 31 19:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.03270 seconds
