Strike through font? [message #69580] |
Wed, 09 January 2008 18:18  |
Originally posted by: juergen.schlierf.eu
I need a strike through font (for TableViewer). Does anybody have an idea how to create it?
Jürgen
Re: Strike through font? [message #71669 is a reply to message #71176] |
Thu, 24 January 2008 16:40   |
Originally posted by: jkrause.innoopract.com
Hi Jürgen,
As Ed pointed out the is no API available for this, as RWT is a subset
of SWT. In SWT you would need to use GC, which we do not support. In
HTML you could set either a style or mark the text with <s>.
There are several ways to achieve striking, none is simple :-(
But if you let us know a little more about your use case we will try to
help you.
In general you could use the same workaround that you would be using
with SWT, overlaying the text with a graphic. But instead of drawing a
line with GC you could try to either take a composite with a border or
an image.
Jochen
Ed Merks wrote:
> Jürgen,
> I think SWT only support normal, bold, italic, and bold italic, so
> likely this is not supported (unless there is a special font face/family
> where "normal" is strike through).
> Jürgen Schlierf wrote:
>> Regards,
>> Jürgen
Re: Strike through font? [message #71761 is a reply to message #71669] |
Fri, 25 January 2008 17:16  |
Hi Jochen,
I want to use it in a TableViewer for a simple webamil application. All messages which are flaged as deleted should be striked out (subject, from, size etc).
To use an overlaying composite or border is an interesting idea. I guess it won't be easy to handle this for a Table or TableItems. My LabelProvider implements ITableLabelProvider, ITableFontProvider and ITableColorProvider.
Any help or hint would be appreciated.
Thanks in advance,
Jürgen
Jochen Krause schrieb:
> Hi Jürgen,
> help you.
> an image.
> Jochen
> Ed Merks wrote:
>> Jürgen,
>> face/family where "normal" is strike through).
>>> Hi,
>>> Regards,
>>> Jürgen
FUDForum. Page generated in 0.04251 seconds
