Home » Language IDEs » Java Development Tools (JDT) » Folder Structure
Folder Structure [message #69566] Sun, 29 June 2003 02:56 Go to next message
Originally posted by: mmaru.visiontv.ca
When I was using BlueJ all my files are stored in a folder I specify. I am
not sure whether I can do the same in Eclipse and what is the best way to
delete a project?
I am new to Eclipse and if I am asking a stupid question please forgive me.
Re: Folder Structure [message #69649 is a reply to message #69566] Sun, 29 June 2003 12:54 Go to previous messageGo to next message
> delete a project?
> me.
When you invoke the new java project wizard , you will see a check box
"Use Default" uncheck the same a browse to a folder where you want to create
the project and store the project files.
For deleting a project right click on the project and say "Delete" and
choose the option "Also delete the contents under <project>"
Hopw this helps
Re: Folder Structure [message #70222 is a reply to message #69649] Mon, 30 June 2003 10:54 Go to previous messageGo to next message
> > delete a project?
> > me.
> Hopw this helps
Many thanks. It is easy to use I just did not look closely. Eclipse is a
wonderful product. I just wish there is a user manual either online or in
print form.
Thanks again.
Re: Folder Structure [message #70525 is a reply to message #70222] Mon, 30 June 2003 15:48 Go to previous message
Try Opening Help from the Menubar
On Mon, 30 Jun 2003 14:54:55 +0000 (UTC), Mulugeta <mmaru@visiontv.ca>
wrote:
> Zabil CM wrote:
>> I am
>> to
>> > delete a project?
>> forgive
>> > me.
>> create the project and store the project files.
>> Hopw this helps
> print form.
> Thanks again.
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Previous Topic:ant build script generator?
Next Topic:User Manual
Current Time: Sat Jul 26 10:19:34 EDT 2025
Powered by FUDForum. Page generated in 0.03680 seconds
