Home » Archived » XML Schema Definition (XSD) » Using XSD with XML for importing XML
Using XSD with XML for importing XML [message #69551] |
Wed, 06 September 2006 07:26  |
I'm a little stuck. I have the following scenario.
Within my runtime jar I have a set of xml schemas under the location
xml-schema/name.xsd and I wish to allow someone to submit a Document or
string representation of the document to an importing procedure. I'm
looking to obtain a footing, so that I may traverse the XML whilst
referencing the correct parts of the XSD schema to obtain application
information relevant.
What is the best way to load both these schemas allowing me to get all the
correct information via an API?
Where should I start?
Stuart
Re: Using XSD with XML for importing XML [message #69612 is a reply to message #69571] |
Wed, 06 September 2006 09:13   |
Hi Ed,
Loading the schema is fine, the problem is that I don't see any API help
to load an XML resource which helps you to relate it to the schema when
processing it.
The following code loads the XML and the schema file, this works ok. The
problem is that the hooks which are used to traverse the XML are rather
weakly typed.
How can I improve the runtime knowledge of where I am traversing the XML
and where to look in the xml schema? I don't see a clear link between the
two very much related technologies. Maybe I am missing something...
Stuart
SymbolTable sym = new
SymbolTable(XMLGrammarCachingConfiguration.BIG_PRIME);
XMLGrammarPoolImpl grammarPool = new XMLGrammarPoolImpl();
XMLGrammarPreparser preparser = new XMLGrammarPreparser(sym);
preparser.registerPreparser(XMLGrammarDescription.XML_SCHEMA , null);
XMLGrammarCachingConfiguration parserConfiguration = new
XMLGrammarCachingConfiguration(sym, grammarPool);
parserConfiguration.unlockGrammarPool();
parserConfiguration.setProperty(GRAMMAR_POOL, grammarPool);
parserConfiguration.setFeature(NAMESPACES_FEATURE_ID, true);
parserConfiguration.setFeature(VALIDATION_FEATURE_ID, true);
parserConfiguration.setFeature(SCHEMA_VALIDATION_FEATURE_ID, true);
parserConfiguration.setFeature(SCHEMA_FULL_CHECKING_FEATURE_ ID, true);
parserConfiguration.setFeature(HONOUR_ALL_SCHEMA_LOCATIONS_I D, true);
XMLReader xmlReader = new
org.apache.xerces.parsers.SAXParser(parserConfiguration);
xmlReader.setErrorHandler(new XmlErrorHandler());
xmlReader.setEntityResolver(new XmlEntityResolver());
xmlReader.setContentHandler(new XmlContentHandler());
try
xmlReader.parse(inputSource);
catch (IOException e)
throw new RuntimeException(e);
catch (SAXException e)
class XmlContentHandler implements ContentHandler
Locator locator = null;
public void startPrefixMapping(String prefix, String uri) throws
SAXException
return;
public void startElement(String uri, String localName, String name,
Attributes atts) throws SAXException
// System.out.print("<" + localName + ">");
// Reflectively load the DTO, if it is a DTO type of course,
otherwise we need to set the attribute value (characters method).
// getXsdSchema().getCorrespondingComponent(node)
return;
public void startDocument() throws SAXException
return;
public void skippedEntity(String name) throws SAXException
return;
public void setDocumentLocator(Locator locator)
this.locator = locator;
return;
public void processingInstruction(String target, String data) throws
SAXException
return;
public void ignorableWhitespace(char[] ch, int start, int length)
throws SAXException
return;
public void endPrefixMapping(String prefix) throws SAXException
return;
public void endElement(String uri, String localName, String name)
throws SAXException
// System.out.print("</" + localName + ">");
return;
public void endDocument() throws SAXException
return;
public void characters(char[] ch, int start, int length) throws
SAXException
String s = new String(ch, start, length);
// System.out.print("" + s + "");
if(s.trim().length() > 0)
// has a value.
return;
Re: Using XSD with XML for importing XML [message #598689 is a reply to message #69551] |
Wed, 06 September 2006 08:55  |
Stuart,
You could use Class.getResource to determine the URL for the schema and
then load the schema from that URL just as in
org.eclipse.xsd.example.XSDMainExample.java's loadAndPrint.
Stuart Stephen wrote:
> or string representation of the document to an importing procedure.
> I'm looking to obtain a footing, so that I may traverse the XML whilst
> the correct information via an API?
> Stuart
Re: Using XSD with XML for importing XML [message #598694 is a reply to message #69551] |
Wed, 06 September 2006 08:58  |
One of the problems I am facing is that the method EPackage
getPackageForURI(String uriString) in
org.eclipse.emf.ecore.xmi.impl.XMLHandler does not seem to load the XML
Schema as it does not try class.getResource("xml-schema/Name.xsd").
Can I override the XMLHandler or is this a bug?
My code is the following:
XMLResourceImpl xmlResource = new XMLResourceImpl();
try
xmlResource.doLoad(inputSource, null);
e.printStackTrace();
Re: Using XSD with XML for importing XML [message #598701 is a reply to message #69571] |
Hi Ed,
processing it.
weakly typed.
Stuart
try
SAXException
return;
return;
return;
return;
return;
SAXException
return;
throws SAXException
return;
return;
throws SAXException
return;
return;
SAXException
// has a value.
return;
Current Time: Tue Jul 22 21:23:52 EDT 2025
Powered by FUDForum. Page generated in 0.05077 seconds
