Home » Language IDEs » AspectJ » Keep getting NoClassDefFoundError when AspectJ Capability is active
Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69444] Thu, 22 February 2007 08:32 Go to next message
Keep getting "NoClassDefFoundError" when AspectJ Capability is active.
Exception in thread "main" java.lang.NoClassDefFoundError:
se/stickybit/licensetracker/server/TestMissingRBKey
When I remove AspectJ Capability it does not happen.
Using a freshly installed Eclipse 3.2.2 with AJDT1.4.1.200611230655 (same old
workspace though).
Jimisola
*** Date: Sun Feb 11 14:42:04 CET 2007
*** Platform Details:
*** System properties:
eclipse.buildId=M20070212-1330
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/usr/local/tools/eclipse/eclipse-platform-3.2.2/linux-gtk/ec lipse
-name
Eclipse
-showsplash
600
-exitdata
80004
-vm
/usr/local/tools/java/jdk1.5.0_06/linux/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1171187973066
eclipse.vm=/usr/local/tools/java/jdk1.5.0_06/linux/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/usr/local/tools/eclipse/eclipse-platform-3.2.2/linux-gtk/st artup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/local/tools/eclipse/eclipse-platform-3. 2.2/linux-gtk/startup.jar
java.class.version=49.0
java.endorsed.dirs=/usr/local/tools/java/jdk1.5.0_06/linux/j re/lib/endorsed
java.ext.dirs=/usr/local/tools/java/jdk1.5.0_06/linux/jre/li b/ext
java.home=/usr/local/tools/java/jdk1.5.0_06/linux/jre
java.io.tmpdir=/tmp
java.library.path=/usr/local/tools/java/jdk1.5.0_06/linux/jr e/lib/i386/client:/usr/local/tools/java/jdk1.5.0_06/linux/jr e/lib/i386:/usr/local/tools/java/jdk1.5.0_06/linux/jre/../li b/i386:/usr/local/tools/java/jdk1.5.0_06/linux/jre/lib/i386/ server:/usr/local/tools/java/jdk1.5.0_06/linux/jre/lib/i386/ client
java.protocol.handler.pkgs=org.apache.axis.transport|
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.13-15.12-default
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/home/jimisola/.eclipse/org.eclipse.platfor m_3.2.0/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/jimisola/.eclipse/org.ecl ipse.platform_3.2.0/configuration/
osgi.framework=file:/usr/local/tools/eclipse/eclipse-platfor m-3.2.2/linux-gtk/plugins/org.eclipse.osgi_3.2.2.R32x_v20070 118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/usr/local/tools/eclipse/eclipse-plat form-3.2.2/linux-gtk/
osgi.instance.area=file:/home/jimisola/workspace/3.2/
osgi.instance.area.default=file:/home/jimisola/workspace/
osgi.logfile=/home/jimisola/workspace/3.2/.metadata/.log
osgi.manifest.cache=/home/jimisola/.eclipse/org.eclipse.plat form_3.2.0/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.sharedConfiguration.area=file:/usr/local/tools/eclipse/ eclipse-platform-3.2.2/linux-gtk/configuration/
osgi.splashLocation=/usr/local/tools/eclipse/eclipse-platfor m-3.2.2/linux-gtk/plugins/org.eclipse.platform_3.2.2.r322_v2 0070117b/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/local/tools/eclipse/eclipse-platform-3.2.2 /linux-gtk/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/local/tools/java/jdk1.5.0_06/linux/ jre/lib/rt.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/l ib/i18n.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/lib/ sunrsasign.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/l ib/jsse.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/lib/ jce.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/lib/char sets.jar:/usr/local/tools/java/jdk1.5.0_06/linux/jre/classes
sun.boot.library.path=/usr/local/tools/java/jdk1.5.0_06/linu x/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/jimisola
user.home=/home/jimisola
user.language=en
user.name=jimisola
user.timezone=Europe/Stockholm
*** Features:
com.perforce.p4wsad (2005.2.3644) "P4WSAD - Perforce Team Provider"
org.eclipse.ajdt (1.4.1.200611230655) "AspectJ Development Tools"
org.eclipse.ajdt.source (1.4.1.200611230655) "Eclipse AspectJ Development Tools
Source Code"
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java Development
Tools"
org.eclipse.jem (1.2.1.v20060815_M----6zXJJzKIRGVU) "Java EMF Model"
org.eclipse.jst (1.5.3.v200701251935-kW-NqztJbMj98Vy) "J2EE Standard Tools (JST)"
org.eclipse.mylar_feature (2.0.0.v20070216) "Mylar Plug-in"
org.eclipse.mylar.bugzilla_feature (2.0.0.v20070216) "Mylar Plug-in"
org.eclipse.mylar.ide_feature (2.0.0.v20070216) "Mylar Plug-in"
org.eclipse.mylar.jira_feature (2.0.0.v20070216) "Mylar Plug-in"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fxM-0vSdc) "Visual Editor"
org.eclipse.wst (1.5.3.v200701251935-X3Tn7ug44nfs8AE) "Web Standard Tools (WST)"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.maven.ide.eclipse.feature (0.0.10) "Maven 2.0 integration"
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69467 is a reply to message #69444] Thu, 22 February 2007 09:01 Go to previous messageGo to next message
Do you have a full stack trace for the error? Can you check in the error
log?
Jimisola Laursen wrote:
> (same old workspace though).
> Jimisola
> linux
> -ws
> gtk
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 80004
> -vm
> -Xmx256m
> -jar
> eof=eof
> file.encoding=UTF-8
> file.separator=/
> java.io.tmpdir=/tmp
> line.separator=
va
Any
> os.arch=i386
> os.name=Linux
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=linux
> osgi.ws=gtk
> path.separator=:
> sun.cpu.isalist=
> user.country=US
> user.language=en
> user.name=jimisola
> *** Features:
> Development Tools Source Code"
> Objects (SDO)"
> Development Tools"
> Tools (JST)"
> Platform"
> Tools (WST)"
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69486 is a reply to message #69467] Thu, 22 February 2007 09:43 Go to previous messageGo to next message
> log?
The only output I get is "Exception in thread "main"
java.lang.NoClassDefFoundError: se/stickybit/licensetracker/server/TestMissingRBKey"
which shows in the console view.
I cannot reproduce now for some strange reason (Murphy most likely) as it's been
showing 9 out of 10 times for the last couple of days and been causing me a lot
of headache.
I think that this stacktrace is related:
!ENTRY org.eclipse.ui 4 0 2007-02-11 14:34:02.244
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.ajdt.internal.utils.AJDTUtils.includeAJfiles(AJD TUtils.java:625)
org.eclipse.ajdt.internal.utils.AJDTUtils.internal_addAspect JNature(AJDTUtils.java:211)
at org.eclipse.ajdt.internal.utils.AJDTUtils.access$1(AJDTUtils .java:173)
at org.eclipse.ajdt.internal.utils.AJDTUtils$1.execute(AJDTUtil s.java:163)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.ajdt.internal.utils.AJDTUtils.addAspectJNature(A JDTUtils.java:167)
org.eclipse.ajdt.internal.ui.actions.AddAJNatureAction.run(A ddAJNatureAction.java:48)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2856)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
/J
>> Regards,
>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69504 is a reply to message #69486] Thu, 22 February 2007 09:57 Go to previous messageGo to next message
You only see the NoClassDefFoundError error in the console, not the
error log? That suggests it only occurs when you launch something?
I can't say for sure if the NullPointerException is related, but that is
a clearly AJDT bug. I've raised this in bugzilla, and should have it
fixed soon:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175123
--Matt
>> error log?
> it's been showing 9 out of 10 times for the last couple of days and been
> causing me a lot of headache.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> /J
>>> Hi,
>>> Regards,
>>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69524 is a reply to message #69504] Thu, 22 February 2007 12:40 Go to previous messageGo to next message
The console output shows when I try to run/debug the application.
Come to think of it it could be that I used Run As Java Application initially
and not AspectJ/Java Application.
Anyway, I manage to test what I wanted and probably won't run the code again for
a while. If I see it again I'll get back to you. I found one bug at least :)
Jimisola
> fixed soon:
> --Matt
>>> error log?
>> been causing me a lot of headache.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> /J
>>>> Hi,
>>>> Regards,
>>>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #69544 is a reply to message #69524] Fri, 23 February 2007 04:44 Go to previous message
> initially and not AspectJ/Java Application.
> again for a while. If I see it again I'll get back to you. I found one
> bug at least :)
FYI, the NPE (bug 175123) is now fixed in the latest dev builds of 1.4.2
for Eclipse 3.2 and 1.5.0 for Eclipse 3.3M5.
--Matt
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #595828 is a reply to message #69444] Thu, 22 February 2007 09:01 Go to previous message
log?
> Jimisola
> linux
> -ws
> gtk
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 80004
> -vm
> -Xmx256m
> -jar
> eof=eof
> file.encoding=UTF-8
> file.separator=/
> java.io.tmpdir=/tmp
> line.separator=
va
Any
> os.arch=i386
> os.name=Linux
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=linux
> osgi.ws=gtk
> path.separator=:
> sun.cpu.isalist=
> user.country=US
> user.language=en
> user.name=jimisola
> *** Features:
> Objects (SDO)"
> Development Tools"
> Tools (JST)"
> Platform"
> Tools (WST)"
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #595842 is a reply to message #69467] Thu, 22 February 2007 09:43 Go to previous message
> log?
of headache.
!STACK 0
/J
>> Regards,
>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #595849 is a reply to message #69486] Thu, 22 February 2007 09:57 Go to previous message
fixed soon:
--Matt
>> error log?
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> /J
>>> Hi,
>>> Regards,
>>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #595858 is a reply to message #69504] Thu, 22 February 2007 12:40 Go to previous message
Jimisola
> fixed soon:
> --Matt
>>> error log?
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> /J
>>>> Hi,
>>>> Regards,
>>>> Jimisola
Re: Keep getting NoClassDefFoundError when AspectJ Capability is active [message #595865 is a reply to message #69524] Fri, 23 February 2007 04:44 Go to previous message
> bug at least :)
--Matt
Previous Topic:Keep getting NoClassDefFoundError when AspectJ Capability is active
Next Topic:New to AspectJ
Current Time: Fri Jul 18 23:17:59 EDT 2025
Powered by FUDForum. Page generated in 0.06544 seconds
