Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Generating EMF model with virtual attributes
Generating EMF model with virtual attributes [message #69417] Tue, 30 January 2007 09:04 Go to next message
Originally posted by: james.willans.xactium.com
My understanding is that an EMF generated model implementation can have
either java attributes, or virtual attributes. By virtual I mean
attributes that are not defined in java code, but give rise to accessible
slots in an EObject which can be accessed via eSet and eGet. Is it
possible to generate an EMF model implementation such that all the
generated attributes are virtual? Clearly this is not the most efficient
way of accessing slot values, but it does provide a more unified protocol
and it would remove the need to override eSet and eGet in subclasses of
EObject.
James
Re: Generating EMF model with virtual attributes [message #69438 is a reply to message #69417] Tue, 30 January 2007 09:19 Go to previous messageGo to next message
--------------000302030502050003060901
James,
Answering questions is less work for me if postings to multiple
newsgroup are done with a single posting. This way, an answer on any of
the newsgroups will appear on all of the newsgroups. Here's what I said
on the EMF newsgroup:
You can mark a feature as being volatile, and in that case the
generator will generate only stub methods that you must implement by
hand.
> have either java attributes, or virtual attributes. By virtual I mean
> accessible slots in an EObject which can be accessed via eSet and
> eGet. Is it possible to generate an EMF model implementation such
> that all the generated attributes are virtual? Clearly this is not
> the most efficient way of accessing slot values, but it does provide a
> more unified protocol and it would remove the need to override eSet
> and eGet in subclasses of EObject.
> James
<html>
<head>
http-equiv="Content-Type">
</head>
James,<br>
<br>
Re: Generating EMF model with virtual attributes [message #69698 is a reply to message #69438] Wed, 31 January 2007 06:21 Go to previous message
Sorry Ed. I intended to post to the EMF newsgroup, but posted here by
accident. I use the simple web newsgroup access and was unsure how to
remove this post.
Thanks for your answer - that was helpful.
James
Re: Generating EMF model with virtual attributes [message #601757 is a reply to message #69417] Tue, 30 January 2007 09:19 Go to previous message
James,
hand.
> James
<html>
<head>
</head>
James,<br>
<br>
Re: Generating EMF model with virtual attributes [message #601869 is a reply to message #69438] Wed, 31 January 2007 06:21 Go to previous message
remove this post.
James
Previous Topic:teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported?
Next Topic:teneo: Yet another DuplicateMappingException problem
Current Time: Fri Jul 18 12:59:47 EDT 2025
Powered by FUDForum. Page generated in 0.04334 seconds
