Home » Newcomers » Newcomers » IntelliJ migration and key bindings
IntelliJ migration and key bindings [message #69331] Wed, 25 May 2005 14:43 Go to next message
Originally posted by: joel.patterson.comcast.net
Two questions:
1 ) Is there any utility which will help migrate an IntelliJ project to
Eclipse 3.0? There are several applications which have many external
jars and having to re-enter them all in very problematic and
time-consuming.
2 ) Is there any set of key-bindings which can be loaded to give Eclipse
more of an IntelliJ feel for those users who are migrating from IntelliJ?
Thanks!
Joel Patterson
Re: IntelliJ migration and key bindings [message #69692 is a reply to message #69331] Thu, 26 May 2005 01:27 Go to previous message
"Joel Patterson" <joel.patterson@comcast.net> wrote in message
news:824dcacf6d7a7c892a59ca1a6574166e$1@www.eclipse.org...
> Two questions:
> time-consuming.
If you have an ant script and use 3.1M7 you should be able to import from
ant.
If that does not work for you, what about trying to write a small plugin to
do the import?
Tha would be cool!
If you ever come with a set of IJ key bindings you coudl bundle with your
IntelliJ importer plugin.
Previous Topic:add .so to project
Next Topic:Free DB Design Plug-in
Current Time: Thu Jul 17 10:21:47 EDT 2025
Powered by FUDForum. Page generated in 0.50710 seconds
